Toymods » Tech & Conversions » Oil Filter Relocation - Line Thickness
takai
Oil Filter Relocation - Line Thickness Wed, 10 November 2004 02:39 Go to next message
Just curious as to what thickness line people used for their oil filter relocations. Ill be doing mine in a few days/a week and just getting reccomendations.
b1gb3n
south Melbourne/KL
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 04:18 Go to previous messageGo to next message
sick of all the stretching to get oil filter changed?? Mad Mad
tell me how it goes
1gt48u
newcastle
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 04:20 Go to previous messageGo to next message
proper hydraulic lines I hope Rolling Eyes
TE72_Turbo
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 08:05 Go to previous messageGo to next message
Why hydraulic? Full oil system pressure should not exceed more than 100psi, hydraulic fittings/lines would surely be an unneccesary cost? Confused
1/2" (12.5mm) lines should be sufficient, or the nearest (larger) speedflow dash size depending on your choice of fittings. Are you planning an oil cooler as well? Try and keep your bends/lengths to a minimum. I assume this is for a 4AG?
Phil
takai
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 08:52 Go to previous messageGo to next message
Yeah 4AG. RWD config, so ill be mounting the oil filter on the chassis rail and then the cooler around the front.
Thinking about doing my GZE at the same time, but thatll have to run to the side for a cooler only.
pro_ke
adelaide
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 09:28 Go to previous messageGo to next message
if i recall correctly i am using dash 12 lines for my oil lines
my fuel ones are dash 8 and i think the oil ones were 2 sizes larger
i havent had a look under the bonnet for months though so i cant quite recall... i do however recall the 90 and 120 degree speedflow fittings were fucking expensive in that size Sad
takai
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 09:58 Go to previous messageGo to next message
Yeah, even at -8 speedflow gear is exxy as. I think ill hit up Pirtek or somewhere else and use brass fittings.
10sec_rx7
Syndey
Re: Oil Filter Relocation - Line Thickness Wed, 10 November 2004 22:22 Go to previous messageGo to next message
dash 8 is 1/2"
dash 10 is 5/8
use dash 10 for oil cooler lines unless your oil cooler is a dash 12 one
a remote mount, hose fittings etc for that would probably be around $450-500 all in braided
Dale
TRD-ST162
Re: Oil Filter Relocation - Line Thickness Thu, 11 November 2004 02:22 Go to previous messageGo to next message
what are the advantages of oil filter relocation?
Re: Oil Filter Relocation - Line Thickness Thu, 11 November 2004 02:35 Go to previous messageGo to next message
Easier access is the only advantage. Most people do it as part of an oil cooler installation.
EvilJack
Sutho/Hills NSW
Re: Oil Filter Relocation - Line Thickness Thu, 11 November 2004 02:40 Go to previous messageGo to next message
what norbie said and basicly looks like this
http://www.chiefaircraft.com/Aircraft/OilSystem/Images/Airwolf_Lycoming_Install.jpg
takai
Re: Oil Filter Relocation - Line Thickness Thu, 11 November 2004 03:13 Go to previous message
In the case of the 4AG can also have the advantage of moving the oil filter away from the really hot exhaust manifold.
Previous Topic:2T-G fuel injected V 2TGEU with haltech f7b
Next Topic:understanding suspension for my ra40
Current Time: Sun Oct 18 11:54:35 UTC 2026
Total time taken to generate the page: 0.0071930885314941 seconds
