Toymods » Tech & Conversions » What to look for when buying an SV21 Camry?
alex_ta22
Newcastle, Hunter Valley
What to look for when buying an SV21 Camry? Wed, 10 November 2004 07:33 Go to next message
what are some common problems to look for? rust areas? mechanical issues?. Also what capacity is the 1s-c?
FOS53L
sydney, roselands
Re: What to look for when buying an SV21 Camry? Wed, 10 November 2004 07:56 Go to previous messageGo to next message
there shouldnt be much problems with sv21 camrys most of them will be in fair mechanical condition as toyota engines are prety strong and the engine that ud have in it would be a 3s-fe which is a 2 litre eceonomy based twin cam engine. look for typical rust spots like around the rear window, the bottoms of the doors, bottoms of guards and rear quarter panels. if your interested in this car for a project and dont mind it being front wheel drive u can botl in the celica 3s-GTE which is a direct fit into your car without much modification, this engine is a 2 litre high reving twin cam engine which is turbo charged, you can find them in celica gt4 front cuts yet use ur camry gearbox.
good luck
Jay Dee
alex_ta22
Re: What to look for when buying an SV21 Camry? Wed, 10 November 2004 09:51 Go to previous messageGo to next message
its definatly a 1s-c (id plate says 1s-c, its single cam, and its carby)
alex_ta22
Re: What to look for when buying an SV21 Camry? Wed, 10 November 2004 10:07 Go to previous messageGo to next message
actually its a 1s-u
Conquest
Sydney/Wollongong
Re: What to look for when buying an SV21 Camry? Wed, 10 November 2004 10:35 Go to previous messageGo to next message
Check the model code, sounds like one of the older hatch type Camrys (not an SV21) Btw engine capacity is 1.8L
http://www.toa-corp.co.jp/eg/360x3/taiou/camry.htm l
alex_ta22
Re: What to look for when buying an SV21 Camry? Wed, 10 November 2004 12:09 Go to previous messageGo to next message
Ok, its definatly a sv20 sedan, with a 1s-u in it. I have a few more questions.
# Do the sv20's have the same inerior as the sv21?
# Would the sv21 wiring and 3s-fe swap straight over into the sv20?
# Are Tacho dashes available, because the clock looks gay
alex_ta22
Re: What to look for when buying an SV21 Camry? Wed, 10 November 2004 12:13 Go to previous message
# Is power steering and air-con an option?
Previous Topic:7mgte ?
Next Topic:help with ae92 trd short shifter
Current Time: Wed Oct 14 09:48:23 UTC 2026
Total time taken to generate the page: 0.033312082290649 seconds
