Toymods » Tech & Conversions » gtech installation
toof
gtech installation Wed, 10 November 2004 08:53 Go to next message
has anyone tried to permenantly mount their gtech pro,
i hate having it stuck up on the windshield and was considering moutning it permently.
two things ive thought of that may need to be considered
1) needs to be able to be tilted to enter weight of vehicle,
2) isolated from vibration ?
i was thknking of mounting it in the centre console under the stereo just wanted to see if anyone else has had any success with this sort of setup ?
white86
Re: gtech installation Wed, 10 November 2004 09:29 Go to previous messageGo to next message
I am thinking you could use the tiltable mounting bit from a gauge pod, and screw it somewhere on the dash via a suitably firm piece of rubber
toof
Re: gtech installation Wed, 10 November 2004 09:42 Go to previous messageGo to next message
well i was thinking making up a bracket with a pivot on each end with rubber grommets between the unit and the bracket,
the bolts between the unit and the bracket would be tight enouhg to hold it but loose enought to pivot it as nessecary.
any one tried this as fasr as vibration problems and what not..
oh and its the ye olde gtech pro model. (similar in size to a turbo timer)
bradl3
Re: gtech installation Wed, 10 November 2004 10:06 Go to previous messageGo to next message
it needs to be mountd on the centre of the windshield or it aint accurate... mine is permanently sittin there just leave the suction thing there and zip tie the gtech to it cauz that sticky shit comes off in the heat wen the car sits in the sun
toof
Re: gtech installation Thu, 11 November 2004 06:55 Go to previous messageGo to next message
it would still be mounted on the centre line of the vehicle, regardless reasing the manual it seems more like inaccuracies from not being on the centre of the windscreen are more caused by the curvature of the windscreen then anything else
Re: gtech installation Thu, 11 November 2004 08:35 Go to previous messageGo to next message
Why would you bother?
Its not like you use it every day.
Leighp
NY
Re: gtech installation Thu, 11 November 2004 12:20 Go to previous messageGo to next message
what car/motor are u gtechin and can u tell me the specs when u get it
toof
Re: gtech installation Thu, 11 November 2004 23:55 Go to previous message
i want to mount it into the mr2,
partly as i dont like the look of it sitting up on the winsdhiled, but also when its plugged into the lighter socket it sometimes wont power up or cuts out, im guessing it just dosne tlike the connection somwhere. its exactly the same in the celica. but every other car it works fine. all other accessories work fine in the socket so its not a loose wire to the socket or blown fuse.
Previous Topic:1UZ-FE into a SW20
Next Topic:Need Help Fast!!!
Current Time: Thu Nov 19 20:02:06 UTC 2026
Total time taken to generate the page: 0.0047211647033691 seconds
