Toymods » Tech & Conversions » MX83 Timing Belt
newoldcar
MX83 Timing Belt Wed, 10 November 2004 11:39 Go to next message
I've just picked up a '91 Cressida that's done 155,000km and I don't know any of the history of the car.
How do I know whether the timing belt needs to be replaced?
It idles OK, but I do get a vibration that I feel through the seat when idling. Plus it seems to be down on power.
I did notice today that bubbles were coming up in the overflow reservoir. It hasn't been over heating. Do I really want to know what this means???
manmx83
Re: MX83 Timing Belt Wed, 10 November 2004 15:39 Go to previous messageGo to next message
Sounds lika a blown head gasket.My 7mge was running perfect withb 240000 on it,pulled it out a month ago to fit a 1j and manual.It is available cheap in Brisbane.
You probably have the option of repair or replace.Occasionally someone gives one away on this forum.Where are you? perhaps ask for a 7m in "wanted".you might get a good one close to home for 4 or 5 hundred.Or repair yours.
Best of Luck.Check out toyotacressida.com cheers.Pete.
DigitalAE86
Re: MX83 Timing Belt Thu, 11 November 2004 09:44 Go to previous messageGo to next message
Thanks for the advice. I'm in Melb.
I got a quote on repairing the BHG, they said it would be a max of $1,300. Just depends what they find when they pull it apart. She still drives fine (I've stopped driving now), so I suppose that the head is still OK.
The oil has been in the car for nearly 10k and it still looks clean - another good sign??
manmx83
Re: MX83 Timing Belt Thu, 11 November 2004 15:04 Go to previous message
I rremember reading that the solution to head gasket woes with the 7mge involved fitting the right gasket and doing the head bolts up quite tight.
please do some research on toyotacressida.com and become informed.
to me $1300 would mean "get the spanners out" but if you have to get a shop to fix it being informed may help you get a better result.
cheers.pete.
Previous Topic:A340E problems
Next Topic:20v Silver Top turbo Conversion
Current Time: Thu Nov 19 23:39:05 UTC 2026
Total time taken to generate the page: 0.0053448677062988 seconds
