Toymods » Tech & Conversions » 4agte oil cooler intstall
juzzo84
Hornsby, N.S.W
4agte oil cooler intstall Wed, 10 November 2004 12:26 Go to next message
heya guys, the time has come to fit the oil cooler i have had lying around for 6 months. So all you 4agte guys, i have a standard 4age oil cooler+sandwich plate and lines, whats the best way to set it up???
ps. would a bigger oil cooler be better due to the turbo factor???
thanks in advance!
Justin
[Updated on: Wed, 10 November 2004 12:26]
EVOSTi
cambo
      no
Re: 4agte oil cooler intstall Thu, 11 November 2004 06:02 Go to previous messageGo to next message
ummm just slap it on like you would any ge? it aint hard. i dont think a bigger cooler would be needed. gze never even came with one as opposed to a ge which is strange. fair enough a gte is gonna make the oil hotter, but i have seen many without any oil cooling.
i also have the stock ge cooler setup.
TE72_Turbo
Re: 4agte oil cooler intstall Thu, 11 November 2004 06:26 Go to previous messageGo to next message
Fitting a larger cooler than standard may not achieve much, as i'm 99% sure that the 4AGE oil cooler setup only cools the BYPASS oil from the pump relief, which would normally drain back to the sump otherwise. Therefore it is not a great volume that is passing through the core compared to a full-flow cooler system (like via an aftermarket remote system)
Its definately worth fitting what you have though, as a hard working GTE is pretty harsh on your oil. I have considered a larger capacity sump too, but I guess regular (max 5000km) oil changes should get rid of the oil before its too cooked Cool
Phil
juzzo84
Hornsby, N.S.W
Re: 4agte oil cooler intstall Thu, 11 November 2004 06:42 Go to previous message
thanks for that guys!!! looks like its oil cooler installing this weekend!!
Previous Topic:Rear Gearbox seal
Next Topic:Which engine to go???
Current Time: Tue Oct 20 06:40:07 UTC 2026
Total time taken to generate the page: 0.0039029121398926 seconds
