Toymods » Tech & Conversions » 4A-GZE tacho connections help please!
4A-GTE
Rockhampton, Queensland
4A-GZE tacho connections help please! Wed, 10 November 2004 12:27 Go to next message
Hello all,
I was just wondering with the gze coil packs that i have on my MAP sensor GZE engine, Where do i get the "tach" signal from to install an aftermarket 5 inch tacho? the wiring diagram for the tacho illustrates that i connect it to the negative side of my coil, but i have coil packs so i have absolutely no idea where to connect it to? It also illustrates a computer connection?
Anyone able to help me with this issue please?
Many Thanks,
Daniel
Grant
Newcastle, NSW, Australia
Re: 4A-GZE tacho connections help please! Thu, 11 November 2004 05:20 Go to previous messageGo to next message
If you're running the factory ecu then the signal comes from the igniter. Alternatively you can take it from the "-ve" spade connector located on the outside of the diagnostics box. If you have aftermarket then there should be an output on the ecu.
EVOSTi
cambo
      no
Re: 4A-GZE tacho connections help please! Thu, 11 November 2004 05:50 Go to previous messageGo to next message
why dont you just use the stock tacho? not big enough for you? Rolling Eyes
if you want the diagram to make your stock tacho work with a gze, email me and i can send you a diagram.
4A-GTE
Re: 4A-GZE tacho connections help please! Thu, 11 November 2004 20:58 Go to previous messageGo to next message
i dont have a tach on my dash, it is in a ae92 rolla 4 door sedan. no tacho brother!
Re: 4A-GZE tacho connections help please! Thu, 11 November 2004 21:00 Go to previous messageGo to next message
a nice little CS-X tacho dash or very classy SX style dash would do the strick.
All thats needed is 3 small parts from Jaycar and you dont even need a "tacho booster".
If using aftermarket... then the output is from the ignitor, the ECU or the diagnostics connector....
4A-GTE
Re: 4A-GZE tacho connections help please! Thu, 11 November 2004 21:14 Go to previous message
thanks witzl, you da man!!!! *thumbs up*
Previous Topic:Need Help Fast!!!
Next Topic:How to make custom 1JZ Sump
Current Time: Thu Nov 19 22:33:47 UTC 2026
Total time taken to generate the page: 0.0066049098968506 seconds
