Toymods » Tech & Conversions » Help: front lower control arms rubbing on brake disc! Fixed
wagonist
Toymods Club Treasurer
icon5.gif  Help: front lower control arms rubbing on brake disc! Fixed Thu, 11 November 2004 01:09 Go to next message
I've fitted up my new DBA discs & now I've discovered under certain vehicle cornering loads, the part of the ball joint fixed to the lower control arm is rubbing against the brake disc.
sorry bout the large size
you can see the groove in the middle of the disc:
http://img46.exs.cx/img46/6992/PB110004a.jpg
It is not helped by the car being lowered, which swings the lower arm out a bit at the bottom.
The lower ball joint bolts onto the end of the arm.
Could this be bent slightly to pivot the ball joint away from the disc?
[Updated on: Mon, 15 November 2004 01:58]
munki
Gold Coast
Re: Help: front lower control arms rubbing on brake disc! Thu, 11 November 2004 01:31 Go to previous messageGo to next message
eeek thats gotta annoy you with new discs and all.
perhaps you can grind a small amount off the lca? and then weld a straight piece of metal in there to give 2 or 3mm clearance?
or maybe just bend the edge a little inwards?
good luck
Daniel
wagonist
Re: Help: front lower control arms rubbing on brake disc! Thu, 11 November 2004 01:41 Go to previous messageGo to next message
The lower control arm doesn't extend that far.
The ball joint bolts onto the end of it & sticks out past the end of the arm.
http://img117.exs.cx/img117/5214/PB110003a.jpg
I doubt I can grind off material from the ball joint.
Henn
Rosanna, Melb
Re: Help: front lower control arms rubbing on brake disc! Thu, 11 November 2004 04:42 Go to previous messageGo to next message
I had a similar problem a while ago and there were a few fixes I thought of. Some VERY dodgy, others not so bad:
grind/bash the end of the lower control arm in. Dodgy and no good in your case.
Fit offset RCAs, again no good in your case cos the ball joint would sit above these anyway.
Possibly space the caliper, rotor and wheel out from the strut 1-2mm. This is most likely illegal, and I am not too sure about the effects, but if you only need a bee's dick of extra room it may work. Also depends how the rotor and wheel attach to the hub.
Use a different offset rotor so it sits a few mm outboard, then modify the caliper or mount so it moves outboard the same amount.
Or rethink your entire brake setup.
May give you some options, but as I said be careful whatever you do, you don't want brakes or wheels falling off.
Hen
wagonist
Re: Help: front lower control arms rubbing on brake disc! Thu, 11 November 2004 04:54 Go to previous messageGo to next message
Can't bash the lower control arm in, becuase it doesn't extend that far out.
My ball joints bolt onto the end of the arm & then stick out past it.
In the last post, the pic shows 2 angled flat pieces bolted together. That's the end of the arm & start of the ball joint.
Ummm... what's RCAs?
The calipers have already got 1.5mm shaved off them to move outwards slightly. This is already 0.5mm into the "meat" of the caliper.
I'm probably going to grind off parts of the ball joint itself.
Spoke to the guy I've been dealing with at Racebrakes & they've done stuff to these for race cars to get clearance.
If this works, I might some new ones & repeat the process on them.
wagonist
Re: Help: front lower control arms rubbing on brake disc! Mon, 15 November 2004 01:57 Go to previous message
All fixed.
Don't know how legal grinding off parts of the ball joint is tho.
I wonder if there is a WST tool part number for an angle grinder? Laughing
Previous Topic:determaning what 18rg parts are from what engine..how???
Next Topic:Ageing W58 Gearbox
Current Time: Wed Nov 4 07:04:23 UTC 2026
Total time taken to generate the page: 0.11266088485718 seconds
