Toymods » Tech & Conversions » Sprinter boot lock loose
WHITCHY
Castle Hill
Sprinter boot lock loose Thu, 11 November 2004 06:14 Go to next message
hey,can someone please help me out?
I noticed that the boot lock (the bit attatched to the body not the hatch) was loose, so I tightened it with a screwdriver, then a week later it was loose again, only this time the left side was able to tighten back up, but the nut behind the right bolt has fallen off and I can't find it.
If I can manage to find it or get one off someone else, how would I go about bolting it back in? It doesn't appear as if I would be able to hold the nut in place with my fingers while I turn the bolt onto it??
And once I have managed to replace it what can I do to make sure is doesn't come loose again.
Thanks for any help.
-Whitchy-
genkin
Re: Sprinter boot lock loose Thu, 11 November 2004 07:52 Go to previous messageGo to next message
SOLUTION
get urself a coupe
4ageeza
Adelaide, drift capital
Re: Sprinter boot lock loose Thu, 11 November 2004 07:59 Go to previous messageGo to next message
genkin wrote on Thu, 11 November 2004 18:22
SOLUTION
get urself a coupe
You mean a 2 door? Wink
jesseT18
Castle Hill, Sydney
Re: Sprinter boot lock loose Thu, 11 November 2004 08:04 Go to previous messageGo to next message
once that plastic cover is off you should be able to get your nut back no worries, and if its anything like my car bolting it back on wont be hard at all
washers under the nuts will keep em there!
genkin
Re: Sprinter boot lock loose Thu, 11 November 2004 08:05 Go to previous message
yes, 2dr is coupe.
2dr
Translation:
Once u take the rubber off you should be able to blow your nuts all over the place no worries, and if its anything like blowing it by youself it wont be hard at all.
dont forget to wash under your nuts when ur done.
[Updated on: Thu, 11 November 2004 08:08]
Previous Topic:erratic idle
Next Topic:Spark Plug Leads for 18RGU
Current Time: Thu Nov 19 22:33:47 UTC 2026
Total time taken to generate the page: 0.012807130813599 seconds
