Toymods » Tech & Conversions » 20V Idle Stability Problem
Statts
Adelaide, SA
20V Idle Stability Problem Tue, 08 October 2002 05:21 Go to next message
Friend has a factory 20V AE101 Levin GT Apex
On throttle back-off and at lights, now and then idle will drop, then pick back up. Sometimes it will eve stall. The car is auto if that makes a difference.
Throttle Position Sensor has been adjusted to no avail.
Any help greatly appreciated.
Chris
inertia
Re: 20V Idle Stability Problem Tue, 08 October 2002 08:15 Go to previous messageGo to next message
If your auto has a torque convertor with lockup.
Have it checked, to see that it is disengaging at appropriate times.
djb23_20v
Wollongong
Re: 20V Idle Stability Problem Tue, 08 October 2002 13:37 Go to previous messageGo to next message
My AE82 20v has this problem too - especially when there is a fair electrical load on the engine like headlights. Never found a solution to the problem though, may have something to do with the quad throttle bodies perhaps?
inertia
Re: 20V Idle Stability Problem Tue, 08 October 2002 14:53 Go to previous messageGo to next message
Some idle advanced thing isn't kicking in? *just throwing crap in the ring*
phill
Re: 20V Idle Stability Problem Wed, 09 October 2002 16:07 Go to previous messageGo to next message
Hi
I drive 90 model celica with 98 model 3SGE in it and I had exactly the same problem. It just got worst when I wash the engine then we find out it was the one of the spark plug lead now no hoping when u idle.
I didn't even put the original leads. Just put cheap ones to try to find out is that the problem or not I'm almost %100 sure that's what it is.
Good luck.
http://www.hotkey.net.au/~hbaydan/
Ben Wilson
Re: 20V Idle Stability Problem Wed, 09 October 2002 22:03 Go to previous messageGo to next message
I'd been chasing exactly the smae problem with my ZE for the past 6 months, eventually I fitted a new oxygen sensor and reset the ECU and all is well (touch wood).
Statts
Adelaide, SA
Re: 20V Idle Stability Problem Thu, 10 October 2002 00:23 Go to previous messageGo to next message
Thanks alot for your help guys
Might try the O2 sensor thing.
Anyone know how to reset a 20V ECU?
Chris
phill
Re: 20V Idle Stability Problem Thu, 10 October 2002 00:45 Go to previous messageGo to next message
this is lucky Phill. Just disconnect the battery for 5 minutes that will reset ever thing (computer ecu etc) but technically u can't reset ECU because it`s purpose is processing information nothing to reset there. U can only reset the computer.
Ben Wilson
Re: 20V Idle Stability Problem Thu, 10 October 2002 01:32 Go to previous messageGo to next message
In my car, there is a 7.5 Amp fuse labelled AM2 (I think), you just need to pull it out for about a minute or so. That way you don't loose the stereo, have to reset the alarm etc...
gt20v
Re: 20V Idle Stability Problem Fri, 11 October 2002 17:36 Go to previous messageGo to next message
I remember there is a device or valve that will bypass some air across the throttle body in case the throttle is closed abruptly, this "thing" is designed specially for automatic transmission because in manual, the engine will continue to be "pulled" by the inertia of the car, so the engine usually won't stall, whereas the torque converter will disconnect the engine as soon as the throttle is off.. that device may be the thing to check, but I forgot the actual name of this device, hope someone else on the forum can remember..
gt20v
Re: 20V Idle Stability Problem Fri, 11 October 2002 17:39 Go to previous message
just remembered as well, the function of the valve is to "slowly" cutoff the air intake so the fuel mixture won't "choke" the engine, hope someone know what's the device is, do some search on the internet and see what you can find...
Previous Topic:Sprinter shocks
Next Topic:cant find wire in sprinter
Current Time: Fri Nov 20 16:26:01 UTC 2026
Total time taken to generate the page: 0.0062010288238525 seconds
