Toymods » Tech & Conversions » CAS question
Simon-AE86
Banned user
ADELAIDE - The Drift City
CAS question Tue, 08 October 2002 05:35 Go to next message
OK... heres the story
i need to adjust my cams to 98 - 98 degrees.. thats Intake set for max lift 98 degrees BTDC and exhaust set at 98 degrees max lift ATDC.
anyway Jazae86 and i did this sunday and basically it wouldnt even fire.. after much macking around.. we couldnt get it to run any better then what i have it at now. we couldnt work out why
basically today i remeber the CAS reads it at TDC.. and we have to move the exhaust cam a fair bit to get that 98 mark.. so thats putting the CAS out and giving an incorrect reading
so HOW do i keep the CAS at TDC while the crank is at TDC also?
http://www.pbase.com/image/5355688 theres a pic of my motor and CAS... have a look and tell me what i need to do.
TE72_Turbo
Re: CAS question Tue, 08 October 2002 11:34 Go to previous messageGo to next message
Thats a tidy looking motor you have there Smile
Surely if you set your cams, then position the motor at TDC #1, remove the CAS, set it to the alignment marker, re-install and then use the slider adjustment to set base timing, then it should all be ok?
By the way, do you mind if I ask where you got the adjustable cam gears, and the oil filter base? I'm after these for mine.
CHeers
Phil
Re: CAS question Tue, 08 October 2002 13:38 Go to previous messageGo to next message
I got my remote filter kit from the local speed shop (JRs auto sport in croydon), but I'd love to hear where theres some reasonably priced cam gears!
Simon-AE86
Banned user
Re: CAS question Tue, 08 October 2002 14:32 Go to previous message
im getting another open for 60 bucks, its a modded stock gear with the adjustabvle center turned up on a lathe!
cheap Smile
i got car going anyway... but now its not,... wiring issue now Sad
Previous Topic:mr2 lsd??
Next Topic:16valve or 20valve???
Current Time: Fri Nov 20 18:09:29 UTC 2026
Total time taken to generate the page: 0.0046429634094238 seconds
