Toymods » Tech & Conversions » ae71 inst panel on ke70
Phrostbyte
Frankston, Victoria
icon6.gif  ae71 inst panel on ke70 Thu, 11 November 2004 13:43 Go to next message
Like the topic kinda says, need to know whether the ae71 instrument panel will hook up to a ke70 ok, and with the 4kc will the tacho part on the inst panel hook up??
Thanks,
Kev.
[Updated on: Sat, 13 November 2004 13:22]
Re: ae71 inst panel on ke70 Fri, 12 November 2004 01:00 Go to previous messageGo to next message
compare the wiring on the two.
all the plugs are there, but more than likely the pin configuration will be different. Its real easy just to follow where the tracks go on the back of the cluster on the plastic circuit board thingy. compare the two and swap pins where necesary.
I had to do this when going from the AE71 -> TE72 4dr dash.
alex_ta22
Newcastle, Hunter Valley
Re: ae71 inst panel on ke70 Fri, 12 November 2004 07:38 Go to previous messageGo to next message
yes it does
Phrostbyte
Frankston, Victoria
Re: ae71 inst panel on ke70 Fri, 12 November 2004 10:05 Go to previous messageGo to next message
even the tachometer????
Gr33nM0nk3y
Re: ae71 inst panel on ke70 Fri, 12 November 2004 10:19 Go to previous messageGo to next message
take the one in the 70 out, plug the one from a 71 in.
done it twice Smile
cheap tacho upgrade.
-bc
Re: ae71 inst panel on ke70 Sat, 13 November 2004 09:31 Go to previous messageGo to next message
Yep worked in mine
Phrostbyte
Frankston, Victoria
Re: ae71 inst panel on ke70 Sat, 13 November 2004 12:52 Go to previous messageGo to next message
does the ke70 have like a plug just sitting behind its original inst panel for the tacho? or do u actually have to install a rpm sensor or sommin?
Re: ae71 inst panel on ke70 Sat, 13 November 2004 21:25 Go to previous messageGo to next message
erm.. im pretty sure that THREE of the answers above cover that question pretty concisely.
[Updated on: Sat, 13 November 2004 21:25]
Teddy_Csx
On Probation
Re: ae71 inst panel on ke70 Sat, 13 November 2004 21:52 Go to previous messageGo to next message
Ok, You can take your Ke70 / Ae71 / S / CS / SE / instrement panel out and replace it with an xx / CSX taco intresment panel. There are no wiring issues / problems. You liturally take out the non-tacko box thing ( 3 connections at back, all differenct sizes, so u cannot miss the size differences ) and then liturally just plug in the CSX one - everything works. Easy.
Gleno28
Re: ae71 inst panel on ke70 Sun, 07 August 2005 11:26 Go to previous messageGo to next message
It all sounds so simple... Smile just installed a 4AGE in KE70 pan van, everything works except the AE71 tacho dash! it does wierd things with the brake light and the indicator lights stay on all the time (just on the dash)?? The original dash still works fine though. Any ideas, bad earth in the new dash maybe??
Glen.
Re: ae71 inst panel on ke70 Sun, 07 August 2005 11:31 Go to previous messageGo to next message
Start checking some earths...
Gleno28
Re: ae71 inst panel on ke70 Sun, 07 August 2005 11:43 Go to previous messageGo to next message
Earths on the back of the new dash do you think?
The import pan van should be the same too i'd think
gearb0x
Re: ae71 inst panel on ke70 Sun, 07 August 2005 12:31 Go to previous messageGo to next message
slightly OT but.... does anyone know of any redily available instrument panels for these cars with clear plastic fronts i could swap over? after the T-18 dash the greeny ae71 sucks
Phrostbyte
Frankston, Victoria
Re: ae71 inst panel on ke70 Sun, 07 August 2005 13:10 Go to previous messageGo to next message
After pulling one apart, the green comes from little plastic inserts that are glued on the inside of the light fitting bits. My gut tells me you could probably just put some different colour cellophane or perspex in the position to colour the lights the way you want. I think the actual viewing window is just slightly yellowed, but pretty much clear.
Also, I've got a JDM KE70 dash and the plugs are different (Aswell as the way funkier display Smile) Too bad I don't have a tacho version of it or I would actually use it.
Kev.
COROLA
Adelaide, Australia
Re: ae71 inst panel on ke70 Sun, 07 August 2005 14:02 Go to previous messageGo to next message
any cluster will fit and wire up... we butcherd our ke70's dash to fit a t-18's... beautiful eight grand tacho, cable speedo, the lot... just cant have the AM radio at the same time! Razz
gearb0x
Re: ae71 inst panel on ke70 Sun, 07 August 2005 23:31 Go to previous messageGo to next message
Phrostbyte wrote on Sun, 07 August 2005 23:10
Kev.
not worried about the green colour of the lights, its the "yellowed tinge" im talken about. After using a T-18 with a clear dash for so long the yellow tinge looks stupid
Gleno28
Re: ae71 inst panel on ke70 Thu, 18 August 2005 11:45 Go to previous message
Have now tried an AE71 tacho dash and a KE70 tacho dash, neither of which have worked in the panel van... i wouldn't think both would have bad earths when the original still works??
KE70 one was worse even, made all the relays flutter??
Any ideas?? (besides trying to isolate individual wires)
Glen.
Previous Topic:18r alternator conversion
Next Topic:RWD 3Y to Silvertop 4A-GE
Current Time: Wed Nov 18 09:45:00 UTC 2026
Total time taken to generate the page: 0.0088860988616943 seconds
