Toymods » Tech & Conversions » 2TG Custom Intake Manifold
EMP-2TG
Carlingford, Sydney
2TG Custom Intake Manifold Tue, 08 October 2002 06:46 Go to next message
Im thinking about making a custom intake manifold for my 2tg when i convert it to efi
i was wondering if i should start from scratch or if i should use a normal 2tg efi manifold and modify it
(greater air volume, ported runner and large t/b)
starting with the standard manifold would be a heap easier
im just not sure that going with a total custom job would be worth it
any idea's ppl
and rod if you have any info you would share about yours it would be great
thanks Smile
Snyper
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 10:55 Go to previous messageGo to next message
I'd suggest using the actual manifold of the 2tg efi unit, and then get a custom plenum made up with a front to suit whatever TB you decide to use, bigger would be better for the TB.....wish I had have done this to my efi set-up now I think about it....
Brendon
EMP-2TG
Carlingford, Sydney
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 11:36 Go to previous messageGo to next message
yeah thats what i was planning on doing so far i think
has any1 got any pics of somthing like this?
wil8115
Seattle area, USA
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 11:47 Go to previous messageGo to next message
get an 2TGEU intake cut off the front TB flange flat as possible.
weld on a piece of Alum flat stock 1-1.25cm thick
then get an 18RGEU TB(60mm btw) center punch and drill/tap the
holes and port to match the TB opening into the plenum.
Shouldn't cost more then few hundred, less if you know friends
with air tools and TIG welder. Cool
EMP-2TG
Carlingford, Sydney
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 11:56 Go to previous messageGo to next message
Im thinking about more extreme than that
like hacking the whole top off above the runners and making a larger (3.2L) plenum to go onto it with a XF T/B (75mm)
wil8115
Seattle area, USA
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 12:37 Go to previous messageGo to next message
why stop there? i saw a 100mm TB on ebay a few weeks back. ;-P
Is this for an N/A motor or boosted?
EMP-2TG
Carlingford, Sydney
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 12:57 Go to previous messageGo to next message
It will be N/A for awhile
but only a month or 2 and then hopfully it will be turbo
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 13:09 Go to previous messageGo to next message
I'll letcha know how well mine works in the next few days...
Hey, why not stick some multi throttles on there while you're at it?
Grega
melbourne.victoria.austra...
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 20:27 Go to previous messageGo to next message
bah. use the existing 2TG runners that bolts to the side of the head - unbolt the inlet plenum chamber and throw that then make something up that will bolt to the existing runners.
EMP-2TG
Carlingford, Sydney
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 21:54 Go to previous messageGo to next message
Does the plenum just unbolt?
wow that just got easyer didnt it Smile
my mission is to now look for a 2TG inlet manifold
wil8115
Seattle area, USA
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 22:00 Go to previous messageGo to next message
the RG TB would be fine unless this is an all out drag/race motor. It flows 550-600cfm i've been told. Thats not even forced inducted...
wil8115
Seattle area, USA
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 22:04 Go to previous messageGo to next message
yes it unbolts right in the middle. If it didnt you'd have one hell'va time getting to the injectors/fuel rail. My 18RGEU manifold is the same way.
EMP-2TG
Carlingford, Sydney
Re: 2TG Custom Intake Manifold Tue, 08 October 2002 22:10 Go to previous message
WEll an XF T/B is cheap so it does bother me is would pobably be easyer to get ahold of id say
but we shall see Smile
Previous Topic:RA65 Celi vs MA61 Supra rear quarter
Next Topic:mr2 lsd??
Current Time: Tue Nov 24 01:03:01 UTC 2026
Total time taken to generate the page: 0.02366304397583 seconds
