Toymods » Tech & Conversions » water injection.
MR. 2
Parramatta
water injection. Fri, 12 November 2004 03:45 Go to next message
i have been thinking about this one a bit and i would like to know what others think.
let me paint the picture, i have an mr2 turbo, so as people know there is not much space or good positioning to put an air to air cooler. (i know i could have done water to air - kicking myself now but im not prepared to spend the money again)
so as some of you may know i had top mouneted the cooler with a tilt on the cooler (above the motor) now it works to a point but now im running more boost with a much bigger turbo so things arnt good when its a hot day. so im thinking water injection.
But here is the question should i plump the sqwirter in to the turbo side of the cooler (the hot side) this way the water has to go through the core of the cooler there fore the cooler will work the way it is suppose to.
Or pump the water jet directly into the inlet so its missing the IC all together. what to do???!!?!?
Also does anyone know any good water injection systems I know the earl one but im not spending that much, i have EMS so i need some things basic with all the relays and the modulators etc.
[Updated on: Fri, 12 November 2004 03:48]
84supra
myrrhee
Re: water injection. Fri, 12 November 2004 04:29 Go to previous messageGo to next message
It dosn't really matter were you inject the water.
I would plumb it in before the turbo as it is easier than pushing against your boost pressure.
If you do this you could use a pressurized bottle system where the engine boost pushes on top of the water making the water only come on during boost.
I would use a nitrous oxide 'dry' injector for the water and an LPG fuel solenoid to allow the system to work only above say 25 degrees inlet temp.
The nitrous injectors are jetted so you could tune it easily.
I hope this helps mate.
M.W.P.
Rocky Mountains, Canada
Re: water injection. Fri, 12 November 2004 04:34 Go to previous messageGo to next message
84supra wrote on Fri, 12 November 2004 14:59
Bad idea.
Ive heard of it causing corrosion of the compressor wheel.
If your running a proper water injection system, the pressure wouldnt be a problem anyway as the water pressure is much higher.
Joshstix
Toymods Vice President
Re: water injection. Fri, 12 November 2004 04:48 Go to previous messageGo to next message
Yeah.
I'd never plumb anything in to inject before the compressor. The erosion of the compressor wheel is not what I'd be wanting, especially on a lovely new GT35R.
I'd also avoid plumbing it before the intercooler. My reasoning for this is that the speed of the gas drops hugely when it enters the IC and the water will tend to fall out of suspension in the cooler. This condensed water in the cooler has too much potential for hydraulicing the engine and bending a rod.
Using a solenoid to close the line is definately a good idea, this stops the line from syphoning out on the small amount of vacuum generated by sucking through the IC.
There are a couple of guys on http://www.mr2oc.com who sell water injection kits. I guess you could take a look at what they have done and reproduce it locally.
84supra
myrrhee
Re: water injection. Fri, 12 November 2004 05:16 Go to previous messageGo to next message
I haven't heard of corroding the compressor wheel before.
Better to be safe though.
Running water through an intercooler works fine, but you do make a valid point Josh.
All this considered, and the fact that you have an after market ECU to control the system I would probably use a nitrous injector straight after the cooler, LPG solenoid and maybe a headlight washer pump (may not push well enough against the pressure?) or something, all up costing under $100.
Note: Water/Alcohol mixes work better than just water.
Have you thought about using nitrous oxide as a cooling agent?
buccy
Re: water injection. Fri, 12 November 2004 05:46 Go to previous messageGo to next message
Here
http://www.autospeed.com/cms/article.html?&A=0 115
and with a bit of work you could modify this to work for water injection.
http://www.autospeed.com/cms/A_0527/article.html?p opularArticle
MR. 2
Parramatta
Re: water injection. Fri, 12 November 2004 05:48 Go to previous messageGo to next message
84supra - not really... i just want a cooler temp i know alcohol and even nitrous will keep it much colder but the running costs would be too great, i think i will stick with water (unless im am at the track)
thanks for all the helps guys i think i will be tapping into the pipe after the IC after all the remarks. Yeah the kit im looking at, at the moment is a Single stage water injection at http://www.coolingmist.com tell me what ppl think?
it also does include the 'Pressure Switches' and 'Solenoids' as people said i dont want it leaking or spraying too much it could cause all sorts of issues.
thanks buccy i will take a look.
[Updated on: Fri, 12 November 2004 05:49]
feral4mr2
Bundaberg, Qld.
Re: water injection. Fri, 12 November 2004 08:46 Go to previous messageGo to next message
http://www.aquamist.co.uk/
http://users.frii.com/maphill/wi.html
i to have been wanting to do a water injection set-up, already bought aluminium container for it (got 4 of them from a scrap yard).
i already have the w2a i/c set-up but i'll be building a 4agte with 83mm ca18det pistons (when i receive the them and acumalate the other bits i need). so i think because of the thinner bore walls i'll need some extra cooling.
cplux
Re: water injection. Fri, 12 November 2004 10:04 Go to previous messageGo to next message
I tried some of the water injection parts from auto speed and seemed to work well. Though in my instance i was going through water quickly as i dont have an intercooler yet. On my wolf 3d controller you could visually watch the temp go down very quickly once the water injection kicked in. put the injector after the ic and you can add some metho to the water for added power aswell. (acts a bit like staged injection).
NVD05X
parra
Re: water injection. Fri, 12 November 2004 10:16 Go to previous messageGo to next message
i've heard that if you plumb the water in before the turbo it can eventually wear the compressor away... like how a river gets made...
Anthony55
Re: water injection. Fri, 12 November 2004 11:02 Go to previous messageGo to next message
hi guys under some peeople heres advice i am considering this option and I have a couple of questions you guys might be able to answer, as it relates to this thread. (don't mean to hijack the thread)
1) how much is a simple kit worth one that runs on pressure? and where can you get one?
2) how much water does it consume/ how often do you have to top up the water and how big does the tank have to be?
3) Do you think the steam cleaning effect on the bores of your cylinders cause extra wear. For example a 2-stroke motorbike gets water in it, it will seize up straight away as it washes the lub of the walls. (although you can ussually start it again when it drys) Razz
Re: water injection. Fri, 12 November 2004 12:42 Go to previous messageGo to next message
my old water injection setup was to spray ahead of the turbo - i'd say it slowed down the turbines - tho am unsure of the erosion affect on the turbines as i;ve since gotten rid of the turbo (long story).
pre_turbo is certainly simpler - but you'll hav a delay between trigger and affect - and even more pronounced if there is an intercooler in the way.
dont forget that any high pressure water injection requires methanol/water suitable injectors - stock EFI injectors will rust or corrode internally - methanol injectors are suitable as they are stainless steel internally.
anthony: regarding query #3, no corrosive affects observed - the water is in vapour form by the time it gets into the chamber and will not condense on the cylinder walls. The only risk is too much water that results in hydraulicising (attempt to compress water).
M.W.P.
Re: water injection. Sat, 13 November 2004 06:22 Go to previous messageGo to next message
Max amount of water you ever want to run is 10% of fuel volume.
Its quite easy to work it out from that.
If you have a 65L fuel tank, youll need 6.5L of water to last a fuel refill (handy this way, refill with water when you fill with fuel).
You can use more than 10% if you run a water/methanol mix tho.
[Updated on: Sat, 13 November 2004 06:24]
Classique71
Colac, Victoria
Re: water injection. Sun, 14 November 2004 00:09 Go to previous messageGo to next message
haha - wrong window post :
Anyway on proper topic - im looking to use an ERL system on my gt4 when i get the frontmount piping finished .. ive heard these have very very good results ..
talk to justen (justengt4) as hes got good experience of water inj. on 3sgte's
[Updated on: Sun, 14 November 2004 00:12]
MR. 2
Parramatta
Re: water injection. Sun, 14 November 2004 00:54 Go to previous messageGo to next message
cheers but dont those ERL systems cost an arm and a leg, being that they use there own computer to contorl the injection?
Classique71
Colac, Victoria
Re: water injection. Sun, 14 November 2004 08:24 Go to previous messageGo to next message
they are not a cheap solution , but they have been tried tested + proven to work well Smile
SevPP
Benalla
Re: water injection. Mon, 20 June 2005 07:22 Go to previous messageGo to next message
The water will only corrode or pit the compressor blades if it isn't vaporised enough. A good nozzle will keep that problem at bay.
Here's a link to Ausrotary that may interest some of you.
http://ausrotary.dntinternet.com/forums/viewtopic. php?t=38929
badboybubby
On Probation
Re: water injection. Tue, 21 June 2005 07:33 Go to previous message
There was an article in the last street machine that used a hobbs switch Smile
Previous Topic:4age (4 to 1) Vs (4 to 2 to 1) extractors
Next Topic:1g-gte rebuild bits
Current Time: Mon Oct 12 08:50:55 UTC 2026
Total time taken to generate the page: 0.09691596031189 seconds
