Classifieds » Engines, Accessories and other Mechanicals » Magnetic Sump Plug (suit Toyota/Nissan) $25
garage13
Magnetic Sump Plug (suit Toyota/Nissan) $25 Fri, 12 November 2004 07:18 Go to next message
Magnetic Sump Plug (suit Nissan/Toyota)
Suits most nissans and I'm pretty sure toyotas.
"Made of hardened steel, the magnet is hydraulically pressed into the end of the plug.
Hot zinc coated to prevent rust and corrosion.
These plugs greatly reduce engine wear and tear as ALL small metal particles are attracted to the magnet that the oil filter doesn't catch. This also helps reduce the engines risk to premature failure as the collection of larger metal particles on the magnet will show when something is wrong.
A must for keeping your engine running smoothly for as long as possible."
$25
http://www.garage-13.com/plugs.jpg
SXY184
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Fri, 19 November 2004 07:23 Go to previous messageGo to next message
what a great idea.... Shocked ,i know you say it should but willit fit a 3SGTE sump, cause if it did , you would make a million sellin them., what engine would it fit ...
EVOSTi
cambo
      no
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Fri, 19 November 2004 08:23 Go to previous messageGo to next message
or you could just put a small magnet on the end of your sump plug yourself. im sure if they "greatly reduce engine wear" then manufacturers would put them in factory.
definately wouldnt hurt tho.
STR8 2.8
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Fri, 19 November 2004 08:26 Go to previous messageGo to next message
garage13 wrote on Fri, 12 November 2004 18:18
Laughing
lovely worded!
[Updated on: Fri, 19 November 2004 08:26]
Sam_Q
S.E suberbs, Vic
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Fri, 19 November 2004 14:00 Go to previous messageGo to next message
EVOSTi wrote on Fri, 19 November 2004 19:23
They do put them factory, take the drain plug off a T50 to see one.
What suberb are u in garage man?
garage13
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Fri, 19 November 2004 14:02 Go to previous messageGo to next message
yeah should fit most toyota's, you can return it and get a refund if it doesn't.
manufacturers put magnetic plugs on gearboxes to reduce wear Razz
(located in south east suburbs - you have PM)
[Updated on: Fri, 19 November 2004 14:02]
STR8 2.8
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Sat, 20 November 2004 01:38 Go to previous messageGo to next message
Sam_Q wrote on Sat, 20 November 2004 01:00
...to avoid particles slipping between gears.
but not in the sump.
[Updated on: Sat, 20 November 2004 01:38]
JAZE
cronulla
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Sat, 20 November 2004 10:14 Go to previous messageGo to next message
um,.... arent commercial posts banned on these forums?
my appologies if you are an official toymods sponsor.
garage13
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Sat, 20 November 2004 10:16 Go to previous messageGo to next message
1 item available, 1 off, private sale mate.
EVOSTi
cambo
      no
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Sun, 21 November 2004 10:57 Go to previous messageGo to next message
it was my understanding this plug was for an engine, not gearbox. i understand gearboxes have magnets on the plugs, likewise with the diff plugs.
JAZE
cronulla
Re: Magnetic Sump Plug (suit Toyota/Nissan) $25 Sun, 21 November 2004 12:34 Go to previous message
my appologies i saw the pic and thought u were selling them.
bump
Previous Topic:very low kay 4age for sale.
Next Topic:SS autochrome manifold suit SR20
Current Time: Tue Oct 20 22:37:09 UTC 2026
Total time taken to generate the page: 0.058446884155273 seconds
