Classifieds » Car/Engine Electronics & Audio » HKS PFC Fcon + GCC >> 1GGTE for sale
eakonee
Bkk thailand
HKS PFC Fcon + GCC >> 1GGTE for sale Fri, 12 November 2004 09:40 Go to next message
second hand
HKS PFC Fcon + HKS GCC for 1GGTE
for Yellow plug series.
Chip tune from kansai service japan.
http://www.kansaiss.co.jp/menu.htm
better to use with 1GGTE toyota ZV ECU box.
it never cut anything. Don't need FCD.
PFC Fcon + GGC+Harness + PFC F-CON Pressure Sensor
450 AUS$
(I'm in thailand.)
http://forums.toymods.org.au/index.php?t=getfile&id=7851
Attachment: DSC04081.jpg
(Size: 32.32KB, Downloaded 608 time(s))
[Updated on: Tue, 16 November 2004 03:49]
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC for 1GGTE for sale Sat, 13 November 2004 07:29 Go to previous messageGo to next message
Whats the pin layout.. Is it 26p 16p 22p.
Or is it 10p 18p 22p
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC for 1GGTE for sale Sun, 14 November 2004 05:52 Go to previous messageGo to next message
Anybody home??? Can you tell me this and the part number or not...
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC for 1GGTE for sale Mon, 15 November 2004 02:43 Go to previous messageGo to next message
Sorry I'm late.On holiday I can't online.
maybe Aus. call 1GGTE series 2...(not sure)
In thai we call "Grayplug" & "yellowplug"
Yellow older than Gray.it come from connect
ECU plug.
Grayplug = T5-A diagram 26p 16p 22p.
Yellow = T2-e diagram 10p 18p 22p
My Harness for yellowplug 10p 18p 22p.
(But you can direct connect to use with T5-A.
it can use cause got GCC for set Fuel)
If you type is 26p 16p 22p and need to Modify Ecu.
Here maybe i can fine "Mine ECU".
It can replace your ecu that so cool for T5-A.
it come with modify Air flow or can use with your air flow.
- Uncut Fuel
- Uncut speed
- new fuel program from Mine http://www.mines-wave.com
if you use with garret AR50 or same size with modify Air flow.
That ECU will show full power.
http://forums.toymods.org.au/index.php?t=getfile&id=7920
Attachment: yellow-plug.jpg
(Size: 16.84KB, Downloaded 549 time(s))
[Updated on: Mon, 15 November 2004 02:49]
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC for 1GGTE for sale Mon, 15 November 2004 05:52 Go to previous messageGo to next message
I have a 26 16 22 pin yelllow ECU. So what do i have to do to connect your unit to my ECU. Do i need a diffrent loom.
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC for 1GGTE for sale Mon, 15 November 2004 06:30 Go to previous messageGo to next message
I will look for "ECU electrician" to make diagram plan
to wire T5-A with Fcon.
another way...
Can i have information.What u did with you engine?
If you full modify "Mine ECU"'s good choice for you.
maybe tomorrow i can show pic of my Harness.
Very Happy http://forums.toymods.org.au/index.php?t=getfile&id=7922
Attachment: map2.jpg
(Size: 18.18KB, Downloaded 530 time(s))
[Updated on: Mon, 15 November 2004 06:53]
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC for 1GGTE for sale Mon, 15 November 2004 11:42 Go to previous messageGo to next message
Its just a standard engine, bigger exaust, intecooler, and the boost has been raised to one bar 14.5psi. If you can find a diagram or a way to wire up your HKS FCON unit to a 26p 16p 22p pin i will buy it of you. My is yellow plug but because its auto it has the later grey T5-A a plug arrangement. This would be very helpfull.
I allready have that wiring graph..from Apexi catalog
How much is the Mines ECU??
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC for 1GGTE for sale Mon, 15 November 2004 16:32 Go to previous messageGo to next message
What i need to know is what each wire is coming out of the PFC FCON. I can make my own loom as long as i know what each wire is for on the Fcon plug that plugs to the ECU??
Thats the information i need???
And also the part number so i know what ROM the Fcon has got. I need it to suit a stock yellow plug configuration engine with stock injectors and turbos...
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC for 1GGTE for sale Mon, 15 November 2004 16:36 Go to previous messageGo to next message
I allready know what each pin is for on the T5-e graph. I have a complete ECU Pin diagram which is from this forum. But i don't
know what the each wire on the Fcon plug is for. What wires tap into what ecu plugs. For example ox sensor, fuel and so on. What does the Fcon tap in to on the ECU...
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC for 1GGTE for sale Tue, 16 November 2004 03:43 Go to previous messageGo to next message
Oh sorry that pic I want to make sure for ECU type. Embarassed
Ok on this weekend I will go to see ECU electrician
draw diagram wire the Fcon plug to the ECU and engine.
Mine's ecu for M/T is around 170-300 AUS$.
thankyou...
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Tue, 16 November 2004 06:38 Go to previous messageGo to next message
Yeah my ECU is the T5-e.. If you could get that wiring graph for the Fcon to the ECU I would really appreciate it.
Does mines have a ECU for the Auto transmition. Whats the difference between the Mines ECU and Fcon. Which is better for my situation??
Thanks for your help..
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Tue, 16 November 2004 10:38 Go to previous messageGo to next message
"Mine's ECU" is replace you ECU.It take more fuel
& fire by smooth control in "Mine's" style.
and unlock anytype.Thailand first step to modify toyota ecu.
We always choose ECU modify from hot garage in japan.
Central20,Garage SPL,Top secrect,k-sport,etc.Mine's is hottest..
Mine'It so cool with full modify(don't adjust anything)
and don't use anyunlock unit for good signal of sensor.
if need more.we choose FCONV,SuperAFC,Motec
(Aus ECU programable it so cool for us)but so expensive to
set&tune it.
Fcon can set fuel(by GGC)or edit rom.
Mine's can set fuel&fire only on edit rom.
(so difficult it got 2 Chip over special
board and then connect to toyota board)
sorry I never see "Mine's ECU" for 1GGTE Auto.
Here for A/T it got only for JZGTE series.
You need anymore part for 1GGTE?
I have Used 1.6 HKS metal engine Gasket.
Maybe My friend had new 1.5 greddy metal Gasket.around 190 Aus$
Or Used....
turbo timer,
Apex auto time around 170 Aus$
http://www.apexi-usa.com/electronics_timer.asp
Apex RSM blue display not include STAND around 270 Aus$
...etc that light weight?
I will ask for you.
Today I call ECU electrician already.
He sad he can show which fcon wire to join ecu wire.
I can go to see him on this weekend.
[Updated on: Tue, 16 November 2004 11:19]
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Tue, 16 November 2004 10:55 Go to previous messageGo to next message
What's mine's style?
Download file midnight-04-2004.wmv from.
http://www.boost-up.com/media/
and see Nissan cefiro+2JZGTE.
They usually choose mine's ECU.
or tmr2 see white truck I saw his car
in garage he use 1JZGTE with Mine&e-manage.
P.S.thay not my friend.
[Updated on: Tue, 16 November 2004 11:16]
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 01:01 Go to previous messageGo to next message
I allready have a Apexi auto timer.. They are $150 AUD New here. I am interested in the Apexi RSM. Is this brand new??
I think i will go for the Fcon as i there is no Mines Ecu for Auto. All i need is to get the wiring graph and i will by it from you.
Would you be willing to seperate the GCC fromt he FCOn as i already have one??
indian
south east - melbourne
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 03:59 Go to previous messageGo to next message
boyan what the deal here matey will this stuff he selling suit our cars or what maybe i might be interested then
indian
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 04:03 Go to previous messageGo to next message
btw eakonee what have u done to the engine of ur 1g-gte looks like a lot of piping in there are u running a single turbo some pics of it would be good if u can get it
chers
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 04:32 Go to previous messageGo to next message
I am trying to figure what wires run from the Fcon to the ECu plug. If i can figure this out i can make my own loom to suit our 26p 16p 22p arrangment. The problem is ours is a gen2 but uses weird gen3 pin arrangment. So i am trying to figure how to make a loom for the Fcon. I have all the wiring diagram for each ECU pin from toymods site but not for the Fcon. Thats what i am trying to do..
By the way one of my injectors failed yesterday...damn cars.Now i have to repair that
indian
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 04:35 Go to previous messageGo to next message
WELL LEMME KNOW WHAT THE HELL HAPPENS i might be getting a aftermarket ecu / piggy back someime later hope u fix the injector soon mate
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 04:54 Go to previous messageGo to next message
Rsm is used(may be got Gsensor).
timer I not sure it new one?cause it
expensive for me too.(I got them price
from thai 2nd board)Bought in AUS better.
for indian
with Aus&thailand engine style.
thailand hardcore and dirty.like jap style. Very Happy
Aus&Usa look smart and clean.(it cool)
We love big turbo(strong G power)and
always swap engine to another brand.
Ex.2JZGTE to nissan cefiro.2JZGTE to RX7.
or my car 1GGTE to BMW.
hardcore like this...
http://forums.toymods.org.au/index.php?t=getfile&id=7987
Attachment: forums[4].jpg
(Size: 18.23KB, Downloaded 487 time(s))
[Updated on: Wed, 17 November 2004 05:03]
indian
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Wed, 17 November 2004 05:08 Go to previous messageGo to next message
man u guys are crazyyyyy as whats the beemer like now with the toyota engine in it
ive seen a pic of 2jz in a mazda rx7 series 5 or 6 body looked nice , imagine the power it will be making
nice set up u ave man some pics will be sweet if u have em
thats a charade or honday city farking hell that cooler is hugeee on it , looks like gtr cooler tooo
hmmm wouldnt mind a pockett rocket lolllll
mine is still a soarer with stock engine bay and all lollllllllll
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Fri, 19 November 2004 08:22 Go to previous messageGo to next message
BLK1GGTE yesterday i go to see ECU elet.. alreadey.
it finished today.He told me he wrote from 2 pic.
Pin of T5-e & T2-e.When you got it.You cut wire from
T2-e harness to join you T5-e.(cause my harness it join
all signal between Fcon&ECU&GCC already.)
I will show soon.
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Fri, 19 November 2004 12:13 Go to previous messageGo to next message
He told cut 5 wires on my harness.
Then connect it with diagram point.http://forums.toymods.org.au/index.php?t=getfile&id=8028
Attachment: wiring.gif
(Size: 7.74KB, Downloaded 433 time(s))
[Updated on: Fri, 19 November 2004 12:14]
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Sat, 20 November 2004 01:59 Go to previous messageGo to next message
Perfect// Do you know the model of your Fcon. I need the code to check to rom.. Also how much for the HKS head gasket and does it lower the copression or leave it same as stock..
Also are you willing to separate the GCC from the FCON as i allready have the GCC at home??
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Sun, 21 November 2004 06:05 Go to previous messageGo to next message
How much for the used HKS head gasket.. Ijust blew mein... Is it metal gasket or??
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Mon, 22 November 2004 08:49 Go to previous messageGo to next message
HKS metal head gasket 100 aus$ 1.6 mm.
I got it from my friend.with HKS ECU&header.
He used about 3 month than he change to JZ.
I never use it.it expensive cause it hard to
fine it here.(always JZ)
for fcon I can check it cause got paper sticker
on chip.it wrote Japan text code.(kensai)
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Mon, 22 November 2004 09:29 Go to previous messageGo to next message
Is it a metal head gasket or...
Also it would be great if you can get the model code cause i need to know what ROM it has?? Thanks
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Mon, 22 November 2004 12:16 Go to previous messageGo to next message
sorry in wrong word I can't check rom model.
(my boss call me... no time for check spell.)
Sticker paper over it.can't get it out.
this's my HKS metal head gasket...
http://forums.toymods.org.au/index.php?t=getfile&id=8122
Attachment: forums2.jpg
(Size: 18.17KB, Downloaded 380 time(s))
-==L=a=N=c=E==-
Brisbane, Queensland
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Sat, 27 November 2004 16:06 Go to previous messageGo to next message
you willing to split the GCC?
BLK1GGTE
South Eastern Subs
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Mon, 29 November 2004 05:16 Go to previous messageGo to next message
Hey eakone.. How about you sell me the PFC F-CON as i only need this unit and sell the GCC to L=a=N=c=E==.. If you are still around..
I like to get this unit ASAP..
SUPRA MAN
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Sat, 11 December 2004 15:54 Go to previous messageGo to next message
I'll give you $200 for the pressure sensor and Graphics Controller.
Anyone else want the F-CON and harness for $250, if so, we can do a deal, or I will buy the whole lot for $450 then split it up.
Please let me know ASAP, money here ready Smile
Kristian
Fattony
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Sun, 12 December 2004 00:52 Go to previous messageGo to next message
I do remember when i was in Thailand seeing a few Toyota hilux and Rodeos there with big front mount intercoolers, though the most tripped out thing i saw was a ta22-23 with a ra60 front on it, pitty i was in a car and could not get the phone out quick enough to take a photo.
eakonee
Bkk thailand
Re: HKS PFC Fcon + GCC >> 1GGTE for sale Sun, 12 December 2004 10:35 Go to previous message
Sorry guys. I prefer to sell as a whole unit.... Sad
If anyone still want my stuff plz contact me via eakonee@hotmail.com
Thx for interesting... Cool
Previous Topic:COMMERCIAL SALES ARE NOT PERMITTED.
Next Topic:F.S St185 instrument cluster
Current Time: Tue Oct 20 12:49:29 UTC 2026
Total time taken to generate the page: 0.14898419380188 seconds
