Toymods » Tech & Conversions » TA23 + F312/292 + W55 = what tailshaft?
RWDboy
TA23 + F312/292 + W55 = what tailshaft? Fri, 12 November 2004 09:48 Go to next message
Question is as per title. Will I need the tailshaft out of the SA63 that I'm grabbing the gearbox from, or will my current tailshaft suffice (out of TA23 with T50/T292).
Re: TA23 + F312/292 + W55 = what tailshaft? Sat, 13 November 2004 11:27 Go to previous messageGo to next message
You'll probably need a custom tailshaft for that combination. An SA63 tailshaft won't fit.
ra23celica
Re: TA23 + F312/292 + W55 = what tailshaft? Sat, 13 November 2004 12:08 Go to previous messageGo to next message
Its possible that a RA65 tailshaft may fit, I don't know its length, but with a W58 gearbox and a F series diff as standard on this model, the spline and flange should fit your W55 and F series diff. The length is the question. Contact CLG on this forum as he has one of these for sale if you are interested.
RWDboy
Re: TA23 + F312/292 + W55 = what tailshaft? Sat, 13 November 2004 13:26 Go to previous messageGo to next message
Yeah - the SA63 is definitely not right (seeing as it supposedly hooks into a T292).
I will bug Mr CLG and do some more measurements now that I have some of the parts on hand.
TE72_Turbo
Re: TA23 + F312/292 + W55 = what tailshaft? Sun, 14 November 2004 06:54 Go to previous messageGo to next message
The 4 bolt flange for the F & T series diffs is the same. At least, it was between my T18 diff & Corona F series when I did the conversion.
RWDboy
Re: TA23 + F312/292 + W55 = what tailshaft? Sun, 14 November 2004 07:25 Go to previous messageGo to next message
Hmmm - depends on the gearbox spline I guess.
Re: TA23 + F312/292 + W55 = what tailshaft? Sun, 14 November 2004 07:48 Go to previous messageGo to next message
I have a RA28 Celica with a W55 and F292 diff.
I use the standard Celica tailshaft that came with the car when it had a 18RC, W50, T series diff.
All fits well except had i had to make the holes around the centre bearing a bit offset as the rear half of the tailshaft was a bit long.
Joel
TE72_Turbo
Re: TA23 + F312/292 + W55 = what tailshaft? Sun, 14 November 2004 08:48 Go to previous messageGo to next message
My F292 diff is now in an AE71 corolla, with W55 box. An RT104 corona one piece tailshaft was a good starting point for the conversion, having the correct yokes/unis, and a constant diameter of 3" (no tapers), so it was simple to shorten the required 35mm. Smile
RWDboy
Re: TA23 + F312/292 + W55 = what tailshaft? Sun, 14 November 2004 10:17 Go to previous messageGo to next message
So I just have to find something with a W5x gearbox and an F or T series rear end and shorten it to suit?
TE72_Turbo
Re: TA23 + F312/292 + W55 = what tailshaft? Sun, 14 November 2004 10:32 Go to previous message
Pretty much. There will be automatic toyota gearboxes that share the same spline too, which will open up the list a bit more.
Remember that if the diff tube tapers up to a larger diameter just after each uni (as many toyota 1 piece tailshafts do), then it will be difficult to shorten. Check this out with your local engineer/diff shop before you make a purchase & take it in.
Previous Topic:PCD for celica 86
Next Topic:Weight Reduction
Current Time: Sun Oct 18 15:44:11 UTC 2026
Total time taken to generate the page: 0.074073076248169 seconds
