Toymods » Tech & Conversions » RA28 wheel size qestions.
jeffro RA28
Tamworth
RA28 wheel size qestions. Sat, 13 November 2004 10:59 Go to next message
hey guys
I am currently restoring a 77 RA28 and am looking at the different wheel size options.
I am mainly after good all round handling, keeping in mind that it has to look smick aswell. The car wont be driving on dirt roads often.standard tyre size is 175/70/15. Currently looking at tyre size of 195/50/16.
i do not want to go to low in the profile beacause of the expense of the tyres. Is this an appropiate size for a RA28 that will give good handling etc?
Any 1 that knows about the handling characteristics of tyre widths and diametre, opinions suggestions and tips would be very helpfull.
[Updated on: Sat, 13 November 2004 11:39]
ra23celica
Re: RA28 wheel size qestions. Sat, 13 November 2004 12:20 Go to previous messageGo to next message
Original std tyre size on an RA28 is 165 R 14. They have an overall diameter of about 522mmm. To keep your gearing and speedo close to original you should try to get near the same diameter, so on a 16 inch wheel you want a 205/55 16 or a 205 /50 16 or 225/50 16. Above 225mm you run the risk of your tyres rubbing / fouling the guards or suspension. I sometimes run 225 50 15's on my RA23 and have no rubbing problems.
Tyres alone won't give good handling by themselves, they should be considered as part of your total suspension upgrade. Given that, lower profile is better and some tyres do handle/grip/perform better than others.
Case in point, Goodyear Eagle GA's are a poor tyre, Yoko A539's are much better, by xomparison.
In 1977 Toyota never considered low profile tyres on its cars so its suspension design would only reflect the best tyres available on the day.
CLG
Perth, Western Australia
Re: RA28 wheel size qestions. Sat, 13 November 2004 18:09 Go to previous messageGo to next message
By the calculation, the correct original tyre diamter is 626.2mm, so you'll be looking for 205/55/16's, 225/50/16's, or 245/45/16's.
For handling, I'd definataely look at 16" wheels, going higher results in a sidewall ratio that can cause problems with grip and turn in, due to it's reduced ratio.
jeffro RA28
Tamworth
Re: RA28 wheel size qestions. Sat, 13 November 2004 23:29 Go to previous messageGo to next message
thanx alot.
i am only 15 and dont know all that much about this kinda stuff, so ur help is very apreciated.
i just thought that if i went to fat in the tyre it would decrease the weight per sq inch resulting in poor traction.I checked the size of the tyres on the car just then and it says p185/75HR14. For a streetcar i thought that 225 would probly be to much? at the moment im looking at 205/50/16.
I have been reading as much as i can on suspension setups etc but due to my lack of knowledge i hardly understand any of it.
If any 1 could supply a website that is easy to understand or explain to me wat suspension upgrades should i do on my RA28 if running tyres 205/50/16
CLG
Re: RA28 wheel size qestions. Sun, 14 November 2004 00:51 Go to previous messageGo to next message
205/50/16 is too small in diameter for an RA28 - it will work but it will throw your speedo out. Use either of the tyre sizes I have mentioned above.
joecoolmk2
Re: RA28 wheel size qestions. Sun, 14 November 2004 01:05 Go to previous messageGo to next message
225/50r16 are a common size on performace cars, and are cheaper and easier to get a wide variety in. it is almost exactly the same circumference as a 185/75r14, depending on the brand you get. trust me, it's the best option pricewise and performance-wise. what style of wheels are you looking at? superlites look awesome on any older car in my opinion.
jeffro RA28
Tamworth
Re: RA28 wheel size qestions. Sun, 14 November 2004 02:31 Go to previous messageGo to next message
gee thanx for the help:)
i havent seen any superlites pics yet so i dont know about them. got a website 4 em?
but otherwise looking at dragways or somthing to give it that muscle car look. nothing to shiny either
joecoolmk2
Re: RA28 wheel size qestions. Sun, 14 November 2004 02:35 Go to previous messageGo to next message
go to www.performancewheels.com.au, and look in the third 'street' page. there the wheels that you'd see all the time on mini's, also known as minilites or watanabes.
EvilJack
Sutho/Hills NSW
Re: RA28 wheel size qestions. Wed, 05 January 2005 10:11 Go to previous message
What would people suggest for a 15x6.5 " rim +35 offset ?
i think i will have to go atleast 2-4mm spacer on the front
Previous Topic:!HELP! crossed snaped bolt in block
Next Topic:Electric Windows, need to retain power after ignition turn off
Current Time: Mon Nov 2 00:57:36 UTC 2026
Total time taken to generate the page: 0.0050292015075684 seconds
