Toymods » Tech & Conversions » RA/SA/MA 6x Diff Centers - How hard to remove?
ZZT231
melbourne.vic.au
icon5.gif  RA/SA/MA 6x Diff Centers - How hard to remove? Sun, 14 November 2004 03:17 Go to next message
Hey All,
How had is it to pull a diff center out of a the Celica/Celica-Supra with IRS.
What needs to be done?
Cheers.
Re: RA/SA/MA 6x Diff Centers - How hard to remove? Sun, 14 November 2004 05:50 Go to previous messageGo to next message
It's piss easy. It only gets difficult if you come across a stuck bolt, which is not uncommon on a 20yo car which has probably never had the diff removed.
1. Disconnect tailshaft from diff. 4x12mm bolts.
2. Disconnect driveshafts from diff. 4x14mm bolts each side.
3. Support diff with trolley jack.
4. Remove 17mm bolts holding diff to cradle. From memory there are 4 on each side and 4 on top.
5. Diff is now hanging from 2x19mm bolts through the crossmember. Remove these and you can lower the diff out of the car (some wiggling may be necessary).
Should take you no more than an hour if you don't hit any snags.
ZZT231
melbourne.vic.au
Re: RA/SA/MA 6x Diff Centers - How hard to remove? Sun, 14 November 2004 07:44 Go to previous messageGo to next message
Thanks Norbie, I hit a snag.
I was at Nick-A-Part (aka Pick-A-Part) and was under the car for 30 minutes trying to remove the CV bolts also since the car was proped up by rims, I wasn't game enough to put a little more weight incase the car came on top of me. The bolts on the housing were un-do-able without doing stupid things. The Trip wasn't wasted as I got other small nick-nacks for the 5M-E.
I think it's safer for me to wait till someone wants to sell their F Series open diff center (with a lower diff ratio) housing that I'll put a bid on it and see if it is within budget.
Cheers.
CLG
Perth, Western Australia
Re: RA/SA/MA 6x Diff Centers - How hard to remove? Sun, 14 November 2004 09:39 Go to previous messageGo to next message
What ratio do you want?
ZZT231
melbourne.vic.au
Re: RA/SA/MA 6x Diff Centers - How hard to remove? Sun, 14 November 2004 10:27 Go to previous messageGo to next message
Thanks Clint,
I just want a spare diff housing with all the gears so I can reco the worn LSD center and have it placed in the housing so I can keep it spare.
Cheers.
RA65 Sleeka
Re: RA/SA/MA 6x Diff Centers - How hard to remove? Mon, 15 November 2004 00:18 Go to previous message
it took me and a mate about two hours to get two diffs out of two ra65 the first one took about just over an hour cos we sat there trying to get the diff out still with one bolt attached Razz and the second one took about 30 mins cos we new what to do. then we ended up paying $150 for two diffs and two black ra65 seats in very very good con and some bits and pieces.
Previous Topic:Ageing W58 Gearbox
Next Topic:Leaky exhaust/turbo manifold?
Current Time: Tue Nov 3 06:39:20 UTC 2026
Total time taken to generate the page: 0.15846395492554 seconds
