Toymods » Tech & Conversions » thermo fan conversion
jesseT18
Castle Hill, Sydney
thermo fan conversion Sun, 14 November 2004 05:33 Go to next message
im looking at taking off the belt driven fan on my t-18 and replacing it with a thermo fan, i had a look at a few thermo's at the wreckers but they all look like they wont mount on my radiator, has anyone done this before and know what car's thermo fan can be used
Re: thermo fan conversion Sun, 14 November 2004 05:36 Go to previous messageGo to next message
MAKE it fit.
Its a little something we call, BRACKETEERING Razz
Re: thermo fan conversion Sun, 14 November 2004 14:22 Go to previous messageGo to next message
THE WITZL wrote on Sun, 14 November 2004 13:36
MAKE it fit.
Which WST would you recommend?
Re: thermo fan conversion Sun, 14 November 2004 22:14 Go to previous messageGo to next message
Cable ties Rolling Eyes
Re: thermo fan conversion Sun, 14 November 2004 22:15 Go to previous messageGo to next message
My mate with a 4agze powered T18 just put a massive thermo fan on and fitted perfectly to the radiator. The fan was off some quite new Commodore and it was the A/C fan not the thermo fan.
Might help ya..
Joel
TheStitt
Membership Secretary
Re: thermo fan conversion Sun, 14 November 2004 22:46 Go to previous messageGo to next message
Hey man
I just bought the bigggest fan that would fit from repco and there tempreture control switch.
Mounted the fan by putting the bolts thru fins of radiator, and installed the thermo switch bulb in the top hose.
Only one complaint its a bit loud the fan
Skip
Re: thermo fan conversion Mon, 15 November 2004 01:39 Go to previous messageGo to next message
Not the greatest thermofan mounting method!!
TheStitt
Re: thermo fan conversion Mon, 15 November 2004 02:24 Go to previous messageGo to next message
yeah probably not the best method. Just have to be careful, the fan came with large washers to help spread the load.
Brakets are probably the best way to go that is how my other cars thermo is set up.
towe_001
Somewhere on a dirt bowl ...
Re: thermo fan conversion Mon, 15 November 2004 14:03 Go to previous messageGo to next message
No its not the best cause if thefan start moving around the washers will start wearing a hole into the radiator tubes and the bolts will have a good chance of taking out the fins and also start to wear a hole into the tubes.
Re: thermo fan conversion Mon, 15 November 2004 14:22 Go to previous messageGo to next message
towe_001 wrote on Mon, 15 November 2004 22:03
Mine was on there for over a year with this setup and it was fine
Skip
Re: thermo fan conversion Mon, 15 November 2004 23:29 Go to previous messageGo to next message
CrUZsida wrote on Mon, 15 November 2004 22:22
It was on there for over a year and it didnt wear a hole in the tubes? Well in that case it should be fine for 5 years Razz :end sarcasm:
Besides the point it looks bodgy mounted like that anyway.
flynn21atwork
Re: thermo fan conversion Tue, 16 November 2004 01:09 Go to previous messageGo to next message
Davies Craig thermo I bought had instructions that said mount it with bolts through the radiator, also said its very important to use fibre washers underneath the regular washers.
I wasn't too fond of the idea, so I just made a couple of brackets out of aluminium strip, its really easy stuff to work with. $2 a metre from bunnings whorehouse..... Very Happy
jesseT18
Castle Hill, Sydney
Re: thermo fan conversion Sat, 20 November 2004 10:59 Go to previous messageGo to next message
thanks for all the help Very Happy
i looked at every single commodore at pick and payless for the air con thermo joel mentioned and none had a decent thermo, i went to pick and pull all i could find was a radiator thermo fan from a VS, so i grabbed it, might take a little bit of ....fabricating... to get in nice
not sure about bolting it through the fins i might gave a wack at making some brackets up!
now i just have to decide if i mount it so it blows through radiator, or mount it on the inside to suck the air through...
i guess it just depends on which way it fits better right?
[Updated on: Sat, 20 November 2004 11:04]
Re: thermo fan conversion Sun, 21 November 2004 07:43 Go to previous messageGo to next message
jessetamsett wrote on Sat, 20 November 2004 18:59
Suck... suck... suck... suck...
jesseT18
Castle Hill, Sydney
Re: thermo fan conversion Sun, 21 November 2004 07:53 Go to previous messageGo to next message
....because?
Re: thermo fan conversion Sun, 21 November 2004 08:04 Go to previous message
A) It works better
B) You obviously missed my SpaceBalls quote Rolling Eyes
Previous Topic:TWNPOT SUPERSTRUT CALIPER KIT P/N
Next Topic:Turns of Wheel Nuts?
Current Time: Thu Oct 22 08:55:44 UTC 2026
Total time taken to generate the page: 0.0072400569915771 seconds
