Toymods » Tech & Conversions » Electronics wizards, please read this!!!
jkvsnn
icon4.gif  Electronics wizards, please read this!!! Sun, 14 November 2004 15:12 Go to next message
I have just found this malaysian guys website and he has tried to make an AFM to MAP conversion for the 20V silvertop
http://www.my-acoustic.com/Car/AFM/Replace_AFM_by_ MAP.htm
http://www.my-acoustic.com/Car/AFM/afm_to_map_2.ht m
The engine idles and will rev up and down but not hold partial throttle (closed loop?)
He seems as though he is very close to getting it to work. Anyone have any ideas? I would love for there to be a way to do this!!!!
Julian.
Brisbane.
Henn
Rosanna, Melb
Re: Electronics wizards, please read this!!! Mon, 15 November 2004 02:56 Go to previous messageGo to next message
I had a look at this a while ago, and it seems like an interesting idea, but I think it will never work quite properly.
Firstly you also need to know engine speed, not just manifold pressure (8000rpm and 10psi of vacuum will need more fuel than 1000rpm and 10psi of vacuum). And also, I'd see it as only being a cheap bandaid fix. Given that AFR should be very tightly controlled you you can make good power, good emissions and avoid pinging I think this whole approach is just too dodgy.
You could possibly take RPM and MAP and use a lookup table to give an equivalent airflow meter output. That would be a lot of stuffing around and then why not just go with an aftermarket ECU?
Hen
Soarer
Wollongong
Re: Electronics wizards, please read this!!! Mon, 15 November 2004 03:23 Go to previous messageGo to next message
A lot of $ required, but HKS had a product called the VPC from memory (Vane Pressure Convertor) which allowed AFM cars to be converted to running a MAP sensor instead. Might be worth looking into if you really need one that works.
b1gb3n
south Melbourne/KL
Re: Electronics wizards, please read this!!! Mon, 15 November 2004 03:42 Go to previous messageGo to next message
Im from malaysia and i can honestly tell u that malaysians are always successful in perfecting dodgy work!! dont ask how but it works!!
for example, most common mod in country, remove cat converter!! Laughing Laughing Laughing Laughing
talk about dodgy
Toobs
Re: Electronics wizards, please read this!!! Mon, 15 November 2004 04:31 Go to previous message
Why don't you borrow a known good AFM from someone before you messing with fuel mixtures etc.?
Previous Topic:A wiring issue or 10 on 4agte
Next Topic:1GGTE turbo upgrade
Current Time: Mon Nov 2 10:53:20 UTC 2026
Total time taken to generate the page: 0.085832118988037 seconds
