Toymods » Tech & Conversions » Quick question: 4AGZE with standard GTi/SX instrument cluster
Phoenix01
Brisbane, Australia
Quick question: 4AGZE with standard GTi/SX instrument cluster Sun, 14 November 2004 23:25 Go to next message
The halfcut I bought has serious dashboard damage, so I cant use that. And I recently discovered the GZE has an electronic speedo, whereas the GE uses a mechanical speedo.
Whats the cheapest and easiest way to get around this problem, without sourcing another dash? Is there some form of electonic to mechanical workaround I can setup?
I've searched an not found anything, and im in a bit of a hurry. Any advice is appreciated.
ae86slaver
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Sun, 14 November 2004 23:37 Go to previous messageGo to next message
www.sixworks.com.au
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Mon, 15 November 2004 00:05 Go to previous messageGo to next message
you need to get a mechanical speedo drive from an AE92 E58 g/box. It would be safe to assume you have an AE101 f/cut? Most AE92 4agze's had mechanical speedo drive, so try and find one from that.
ORRRRR - i have thoughts that perhaps a mechanical speedo drive from another type of E series box will work eg, MR2, GT-4 etc.
I think AE86slaver is thinking more along the lines of the tacho booster that sixworks sells, you will need something to modify the tacho signal as well.
Phoenix01
Brisbane, Australia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Mon, 15 November 2004 00:30 Go to previous messageGo to next message
Thanks for the quick replies.
Basically, the biggest problem is. The speedo drive from my AE92 GE gearbox is too short to fit in the AE101 GZE box. And the AE101 drive is electronic. And the location of the drive is on the other side of the gearbox on the AE101 so I'd need a 90* bend in the cable.
What is the AE92 GZE LSD box like? Would the drive be located in the same spot as the AE101 GZE?
Sorry if this info sounds vague or doesnt make sense, I'm relaying it from someone who actually knows what they are talking about. Confused
Rod83
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Mon, 15 November 2004 02:32 Go to previous messageGo to next message
As the witzl said, you'll need the drive from an ae92 e58 box. The boxes fitted to the ge's are c5x boxes and their speedo drives are unsuitable.
Phoenix01
Brisbane, Australia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Mon, 15 November 2004 03:18 Go to previous messageGo to next message
Thanks for all your help guys. I need my daily back badly.... Now I just need to find a place that has one. Very Happy
Probably not something toyota australia would stock. Oh well.
Phoenix01
Brisbane, Australia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Thu, 18 November 2004 07:18 Go to previous messageGo to next message
Hmmm, not having any luck. New plan.
I'm going to try and track down a new dash.
1st question: The AE101 supercharged model's dash fits into an AE92?
if not
2nd question: Is there an AE92 supercharged model that comes with a n electronic speedo?
3rd question: Is someone willing to sell me one? I will pay $$$ for one in good condition. Because I doubt I'll be able to get one from a wrecker without buying a whole front cut. Sad
inertia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Thu, 18 November 2004 08:38 Go to previous messageGo to next message
Try revhead on twincam.org he can probably source the part
sideshow
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Thu, 18 November 2004 10:12 Go to previous messageGo to next message
the ae101 dashes are totally different
those mechanical drives for the gze boxes are impossible to find
just ask around for awhile and see if u have any luck
u could try remove just the speedo from yr dash cluster and fit the ae101 not to sure how hard
there is a device that has an electronic puls einput then this input then spins a cable to turn the speedo
so its electronic to mechanical
http://www.abbott-tach.com/cablex.htm
dont know if it can do toyota speedos
inertia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Thu, 18 November 2004 10:45 Go to previous messageGo to next message
Mr Anthony Kellam may be able to sell you an E series sender too...
Phoenix01
Brisbane, Australia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Thu, 18 November 2004 11:09 Go to previous messageGo to next message
Thanks for the responses guys.
My mechanic tells me the electronic drive is still needed for something in the ecu (injector related i believe). So what we are doing for now, is just doing a dodgy (at my request, just to get the damn thing back on the road after 2 months), and cutting out my instrument cluster, and cramming the AE101 instrument cluster in.
This is a temporary fix until I can find a better solution.
My mechanic also mentioned a device like that too. But when my current dash is full of cracks, i might as well cut it up and stuff the cluster in and replace the whole lot later with something a little newer/nicer.
Phoenix01
Brisbane, Australia
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Thu, 18 November 2004 12:43 Go to previous messageGo to next message
Also... it just hit me... using the electronic speedo drive, the car will be speed limited @ 180km/h wont it?
jasonp1977
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Sat, 20 November 2004 11:56 Go to previous messageGo to next message
your mechanic doesn't know what he's talking about with relation to the speed sensor.
Get an E series mechanical sender, use your original dash, do the 30c mod to the factory tacho drive so it runs off the GZE ignitor, connect the GZE ECU's speed sensor input to the 4 pulse per revolution on the back of your AE93 dash cluster.
Mr Revhead from twincam.org can source you a mechanical sender, an MR2 E51 sender will also work.
Or you could just slap in an Apexi RSM for a temporary fix to give you a speedo display from the original elec sender while you source a mechanical sender. Dont hack up your SX dash.
The RSM will get rid of the 180km speed cut, but it doesn't really matter because the GZE will not get up to 180 down the main straight of QR or Darlington Park, or down the track at Willowbank.
[Updated on: Sat, 20 November 2004 12:07]
Anthony Kellam
Re: Quick question: 4AGZE with standard GTi/SX instrument cluster Sat, 20 November 2004 12:25 Go to previous message
The ECU gets its SPD signal from the dash cluster. The ECU doesnt care if that signal originated from a mechanical cable or from an electronic sender, it's a switched ground at 4 pulses per revolution of sender either way (from a reed switch/four magnets or from a switched transistor respectively).
I can sell you a complete mechanical E58 sender but these cost $80. I have only one left and will probably kick myself next AE92 conversion I do but you seem to be in trouble Wink
I would suggest this would be the easiest path. Also, if you aren't able to perform the modifcations to your tacho assembly I can do this mod for $20 if you can get the cluter to me for half an hour.
email me at akellam@optusnet.com.au if you're interested.
Previous Topic:Head Torque Specs???
Next Topic:Oil on spark plug tip
Current Time: Thu Oct 29 15:23:22 UTC 2026
Total time taken to generate the page: 0.026134967803955 seconds
