Toymods » Tech & Conversions » Acrylic lacquer whats a good mix ratio !?
KiwiKe70wagon
New Zealand
Acrylic lacquer whats a good mix ratio !? Mon, 15 November 2004 08:30 Go to next message
Hey guys!
I've just started painting my ke70 wagon in Acrylic lacquer Ford Wild Plum! (solid colour) anywho the tin says mix ration of 1:1 but i heard thats too thin Confused its a Du Pont paint lucite 400 with ad345 thinners if that helps i'm using a HVLP gun whats a good psi for running that manual says between 43 and 60 !? anywho any help would be great! cheers
Grega
melbourne.victoria.austra...
Re: Acrylic lacquer whats a good mix ratio !? Mon, 15 November 2004 09:07 Go to previous messageGo to next message
hiya
i used acrylic to do my celica, i mixed my clear at 400ml thinner 200ml clear.
can i suggest you test somewhere (a piece of wood) to see if you get any sort of frosting when you mix it?
i run 45psi and had no issues.
again - mine was all acrylic - i won't spray 2 pack
ChuckLandwehr
Re: Acrylic lacquer whats a good mix ratio !? Mon, 15 November 2004 09:24 Go to previous message
Yeah 1:1 sounds about right from the manufacturer. If weather is hot add more thinners, and vice versa. Do a test patch somewhere, to set up your gun, and check application. Good luck man, I know it can be very rewarding, when it all works out.
regards Chuck.
Previous Topic:EMS DualSport tuning ?
Next Topic:ATTN: 18rg and rgeu experts...please tell me what i have???
Current Time: Sat Nov 21 01:59:06 UTC 2026
Total time taken to generate the page: 0.014257907867432 seconds
