Classifieds » Parts Wanted » ma70 driveshaft
mkiii
ma70 driveshaft Wed, 09 October 2002 01:11 Go to next message
The centre bearing on my drive shaft is gone, i can find the bearing at auto1 for $20, but i also need the rubber housing and bracket for the centre bearing, does any1 know where i can get 1, as usual totyota wants an arm for it.
Thanx.
JZZ30MAN
Re: ma70 driveshaft Wed, 09 October 2002 06:22 Go to previous message
Many years ago I wnet on a search like you for the centre bearing.
I couldn't find the inner bearing intself, which you managed to find. Congrats.
But, the bearing is supposed to be cast into the rubber mounting as a single unit with the housing.
I ended up biting the bullet and buying one from Toyota for about $70 (11yrs ago).I recommend you do the same, or install a one piece tailshaft, which will cost you a lot more.
The only other alternative would be to use the original housing and find somebody who can rubber cast the bearing in the centre. A really big ask I suspect.
Michael
Previous Topic:ta22 parts
Next Topic:5M-GE Airflow meter
Current Time: Fri Oct 23 21:39:44 UTC 2026
Total time taken to generate the page: 0.0040798187255859 seconds
