Toymods » Tech & Conversions » removing AE86 rear windows
45aken
NSW.south coast.Drifting
removing AE86 rear windows Mon, 15 November 2004 13:27 Go to next message
how do i remove and re-install the rear and hatch window glass on my AE86. needing to do some rust repairs Rolling Eyes
tanman
Re: removing AE86 rear windows Mon, 15 November 2004 19:08 Go to previous messageGo to next message
cut it out with wire and sikaflex it back in.
Jon B
Re: removing AE86 rear windows Tue, 16 November 2004 01:21 Go to previous messageGo to next message
with the hatch glass you can get it out without cutting the rubber, i did it took 2 people to do it tho. have a look at the ae86 manual on the site tech docs.
FKN16V
NSW, East Coast
Re: removing AE86 rear windows Tue, 16 November 2004 03:34 Go to previous messageGo to next message
i did mine the other day, its not easy, i got no muscles,
lift up hatch, pry (with something soft, i used a toothbrush) the rubber back on the inside and push in that corner with a flat palm, work your way along the top then down one side, it'll take a little bit of effort but you"ll get there.
The corner must come out before the rest does,so pick a top corner and work at it till it out,then the rest will follow easily.
Hope it helps.
Steve
Jon B
Re: removing AE86 rear windows Tue, 16 November 2004 03:39 Go to previous messageGo to next message
also i took the hatch off the car and turned it upside down on an old mattress. makes it easy if u can use gravity to help it out Smile
45aken
Re: removing AE86 rear windows Tue, 16 November 2004 04:01 Go to previous messageGo to next message
what about the rear '1/4' windows?
i understand what you mean about the hatch, but how do i remove the plastic/metal surrounds from around the rear quarter windows?
FKN16V
NSW, East Coast
Re: removing AE86 rear windows Tue, 16 November 2004 04:23 Go to previous messageGo to next message
Thats a different story, you need a wide paint scraper, stick it btween the glass and the trim, pry forwardoutwards slowly till you hear it pop out,
The bottom clip is harder, it needs to be pushed down (from behind) and out/forward at the same time.
Be firm but gentle otherwise stuff will break. Once the trim is off its just a mater of using a long bladed stanley or similar too cut the mastic ( i think thats what its called) and the glass will come of, make sure you cut all the mastic dont use the glass as leverage, it will break.
Hope it helps
Steve
[Updated on: Tue, 16 November 2004 04:25]
takai
Re: removing AE86 rear windows Tue, 16 November 2004 05:14 Go to previous message
On a similar note, how do you get them back in? I popped mine off no problems, just cant get it to sit right anymore. This is 1/4 window.
Previous Topic:4age 20v in a AE92
Next Topic:Which radiator for 1ggte Hilux
Current Time: Sat Nov 21 02:26:37 UTC 2026
Total time taken to generate the page: 0.0051209926605225 seconds
