Toymods » Tech & Conversions » Why do people get roll cages?
andrewa
Why do people get roll cages? Mon, 15 November 2004 20:15 Go to next message
This isnt a attack on anyone for starters.
But i just want to know why people get roll cages if their not gonna do any track work at all?
1. how much do they cost
4. how much wieght do they add?
2. is it for looks
3. safety
4. If a car were to remove back seat and do other weight reduction would there be a need for a roll cage?
muaythaiman
Re: Why do people get roll cages? Mon, 15 November 2004 21:01 Go to previous messageGo to next message
maybe safety? Rolling Eyes
Purple_Beasty
New Zealand
Re: Why do people get roll cages? Mon, 15 November 2004 21:18 Go to previous messageGo to next message
muaythaiman wrote on Tue, 16 November 2004 10:01
Actually, without all the matching gear (harness, race seats, helmet etc) a cage can be MORE dangerous.
Callum
Chris Davey
sunny coast, qld
Re: Why do people get roll cages? Mon, 15 November 2004 21:29 Go to previous messageGo to next message
yeah, I agree with purple beasty.
Also, sometimes you have to eg. run a 10 second pass and you have to before you will be allowed to race again.
Re: Why do people get roll cages? Mon, 15 November 2004 21:31 Go to previous messageGo to next message
I had my doubts before but it must be the school holidays.
takai
Re: Why do people get roll cages? Mon, 15 November 2004 21:34 Go to previous messageGo to next message
I get my 4 pointer put in next week, and thats going in simply for safety. True my car isnt a daily driver, and for that matter my daily driver doesnt have a cage. But on the 86 i think its a reasonable requirement, especially as i will be doing track work on it.
As for daily drivers, i wouldnt install one, mainly for the reasons that PurpleBeasty has already iterated. Without everything else you have too much room to move, and the cage becomes a really hard object which you hit. Normally there woudl be padding or at least plastic there, but with a cage it is now metal.
As for your questions:
1. My 4point crossbraced is costing me $600
2. I estimate itll add about 15-20kg
3. No i race this thing.
4. I have completely stripped the interior, and the cage is a logical extension.
._T_.
Re: Why do people get roll cages? Mon, 15 November 2004 21:50 Go to previous messageGo to next message
a proper roll cage not only increases the saftey of the car in an accident, but it also can dramatically increase the stiffness of the chasis (not the cusco etc bolt in type cages - they are mostly cosmetic items)
yes an unshelded 6 point style of cage can be a very dangerous thing in a road car - people have died in quite minor accidents from head injuries. common sence should prevail here when it comes to padding tubes near one's head.
as to costs - a good 4 point built into your car tig welded racetech350 tube would be around $1k. basic 6 point about double that
T
Purple_Beasty
New Zealand
Re: Why do people get roll cages? Mon, 15 November 2004 23:11 Go to previous messageGo to next message
._T_. wrote on Tue, 16 November 2004 10:50
ayes an unshelded 6 point style of cage can be a very dangerous thing in a road car - people have died in quite minor accidents from head injuries. common sence should prevail here when it comes to padding tubes near one's head.
T
The main issue I see with a using a cage in a road isn't lack of padding (as you point out common sense says you put in padding), but used with retractable belts they prevent the car crumpling to absorb an impact as well as reducing the space that the retractable belts have to reduce the momentum of your body.
Its a bit like using harnesses with out a cage, retractables are much safer as they slow your body gradually. Harnesses are only really designed to prevent most of your body movement (they will stretch in a crash) so you don't hit the cage.
Callum
._T_.
Re: Why do people get roll cages? Tue, 16 November 2004 00:09 Go to previous messageGo to next message
i don't agree - a harness will hold an occupant much better in an accident than a sash belt ever will - sash belt is a compramise piece of safety equipment if there ever was one.
99% of roll cages do not protude beyond the firewall so they will not affect the cars cruple (crumble?) zones (unless side impact - then cage intrusion bars far more benifit!!)
a decent seat will also hold you better - allowing the harness to work better as well.
only thing left unrestrained (fairly important part) ends up being you head - unless encased in a helmet & with a neck brace (or even better a haans device) neck injuries will occur. not much you can do about that other than not have any accidents!
lets be honest - safety equipment is better off not being used - ideal situation is that you never have an accident & have to test everything out - that's the ideal situation.
Purple_Beasty
New Zealand
Re: Why do people get roll cages? Tue, 16 November 2004 01:04 Go to previous messageGo to next message
As individual pieces harness, seat, cage and helmet are not the best option. It is only together and at higher speeds that you get the real benefit.
Helmet - makes your head heavier increasing risk of neck injuries when in most crashes you won't hit your head.
Harness - will cause sudden deceleration of your body in an accident rather than the controlled deceleration of retractable belts increasing the risk of internal injuries. Also interferes with airbags if fitted.
Seat - proper race seats can interfere with the correct operation of seat belts in some cars.
Cage - reduces interior room thereby increasing the risk of head injuries, and most decent race spec cages should be tied into your front strut towers which will interfere with crumple zones.
Put them all together and increase the speeds though and you will be far better off. However for normal road use any single component is likely to do more harm than good in most accident situations. The exception is seats, IF they don't interfere with the correct operation of your seatbelts they can help by reducing sideways movement in an accident.
Callum
AE86slut
Baulko Hillo
Re: Why do people get roll cages? Tue, 16 November 2004 01:51 Go to previous messageGo to next message
I put my cage in purely for the chassis stiffening effect. Then again, my car is not a daily driver.
Re: Why do people get roll cages? Tue, 16 November 2004 07:01 Go to previous messageGo to next message
gianttomato wrote on Tue, 16 November 2004 07:31
Special schools apparently have their holidays in different times to others Confused
bbaacchhyy
Re: Why do people get roll cages? Tue, 16 November 2004 07:08 Go to previous messageGo to next message
._T_. wrote on Tue, 16 November 2004 11:09
So wrong it is not funny. An example is the crappy factory strut tower brace fitted to V8 and AWD Commodores (and some W cars) affected the crumple zones to the extent, that they delayed the introduction to ensure that it posed no risk !!!
[Updated on: Tue, 16 November 2004 07:08]
DRFTAE86
Melbourne: South east
Re: Why do people get roll cages? Tue, 16 November 2004 12:18 Go to previous messageGo to next message
If any1 is looking for a 4-point cage.... Toyospares (rip-off-spares) is/was seliin 1 for $200. But i believe it is now on e-bay...already fetching more than $200. MMuuhahahaha, foolz!
Rex_Kelway
Re: Why do people get roll cages? Tue, 16 November 2004 12:22 Go to previous messageGo to next message
Ahhh, a thread close to Rex's heart...
Standard seatbelts do not provide controlled deceleartion of body mass.
They are one the most compromised piece of safety equipment in the modern automobile. They are designed to: (a) retract out of the way, when entering or exiting a car, (2) Cater and work the same across all body shapes and sizes, (3) LOCK on sudden extension to tie the body to the vehicles mass and (4) be easy enough for any bonehead to use
When the occupants body lurches forwards, the reel LOCKS solid. No control of deceleration whatsoever. The usage of pre-tensioners further highlights this. Pre-tensioners are often used as part of the SRS system. an explosive charge in the reel causes the belt to pull tight the instant the SRS system is triggered.
Controlled deceleration is only built into crumple zones, airbags and padding.
Harnesses are surely a gift from god to restraining systems. The massive increase in surface contact to the torso has a huge affect on how forces are applied to the human body.
As good as they are, they are not used explicitely for the following reasons.
- ADRS assume occupant laziness/stupidity, in that not every person is going to adjust the harness for a proper fit each time they use the vehicle. Retractor belts do this automatically.
- Harnesses are more complicated (emergency crew stupidity) than reciever type buckle seatbelts to release an occupant from in the event of an emergency.
Neck injuries are impossible to prevent without making the head part of the cars mass as a seatbelt/harness does or a neck brace which is in no way a match. For example head rest and wings for rearward and sideways movement and a strap across the forehead for forwards movement. In this respect helmets are bad because they increase the mass of an occupants head. But it is better to have a sore neck than pieces of your brain in the passenger footwell and smeared across the roll cage
Rollcages perform 2 functions. Increase vehicle stiffness so the suspension performs its best and protect occupants in event of roll over and side impact. Front and rear impacts are still absorbed mostly by the vehicles body.
The cage must tie rigid all four suspension corners and prevent the body from flexing or twisting and transfer/distribute forces throughout the structure with minimal deformation.
This is why competatiion rollcages are very complex and very heavy.
Less serious roll cages filter on down through the levels to where simple half cages and 4/6 point bolt-in cages acceptable.
Then there are wank cages, which although them may perform very well are over-kill and simply add a mass of weight to a car which may only require a simpler cage. These types of cages usually kill people because they are rarely used with helmets (unless on track).
Jesus, here Rex is wanking on about shite when he has study to perform.
Live long and prosper, you lot...
Rex
[Updated on: Tue, 16 November 2004 12:25]
takai
Re: Why do people get roll cages? Tue, 16 November 2004 12:53 Go to previous messageGo to next message
Rex, and others, i would be interested in hearing what you think of the Hans device.
I have been curious about this for a while, looks like a good idea.
Rex_Kelway
Re: Why do people get roll cages? Tue, 16 November 2004 13:27 Go to previous messageGo to next message
Rex would definately get one without hesitation.
For those who havent seen the testing video:
http://www.hansdevice.com/sled_01_quick_150.wmv
The scary thing is to watch a fierce impact from an in car view.
Rex remembrs seeing Harri Rovanpera slide into a tree during a round of the WRC. Watching it frame by frame, his head moves from the head rest to within an inch of the steering wheel in a single frame (which Rex is assuming was 24fps?). The forces are huge!, given that its his neck taking a fair portion of the loads make it even more scary.
Mabye oldcorollas could give us an idea of the speeds/accelaration involved, Rex cant be arsed...
Motorsport is very dangerous, deaths (or worse) happen all the time. The best you can do is minimise the risk as best as possible.
Rex is reminded of Tyler's line in Fight-Club...
"An exit door procedure at 30,000ft, Ahhh, the illusion of safety"
Rex
[Updated on: Tue, 16 November 2004 13:32]
M.W.P.
Rocky Mountains, Canada
Re: Why do people get roll cages? Tue, 16 November 2004 15:51 Go to previous messageGo to next message
Rex_Kelway wrote on Tue, 16 November 2004 23:57
Wow.... makes a big difference.
But whats with the harness in the movie, when the car hits, the dummy's body moves forward a lot before the belts stop it.
Looks like they were too loose?
muaythaiman
Re: Why do people get roll cages? Fri, 19 November 2004 08:31 Go to previous messageGo to next message
I never checked back to this thread since i origanally posted. If I was in a car that rolled on an outback road, regardless of whether I was wearing a harness, or standard (but decent condition) belts, I would be happier with a rollcage.
ae86drift
sydney.au
Re: Why do people get roll cages? Fri, 19 November 2004 11:13 Go to previous messageGo to next message
thing i love about that device is the dumb american nascar driver that shunned the device died from a neck related accident
i too saw that rovanpera wrc clip, fucking scary shit
Kyosho
Wollongong
Re: Why do people get roll cages? Fri, 19 November 2004 11:31 Go to previous messageGo to next message
Rex_Kelway wrote on Tue, 16 November 2004 23:22
I have to completely disagree there...
The self locking seatbelt actually removes momentum safer...
When in an accident, with no seat belt, your body moves with the same momentum, until it smacks the wheel/dash...
An old school seat belt just snaps instantly once a certain point is reached...
The newer self locking seatbelts actually start up a tensioner before locking (You may not notice it until in an accident)
But when in an accident, they can "slip" which allows decelleration although fairly quick still, over a greater distance...
As for the explosive charges...
They are actually set up, such that when an airbag system deploys, the charges go off, and actually "snap" the self locking system (releasing it) such that, instead of stopping you in the "short" distance the seat belt tensioner can use, it allows you to slow over approx 6 - 12 inches...
Therefore you don't slow as quickly, therefore you recieve less problems from sudden stops etc...
ae86drift
sydney.au
Re: Why do people get roll cages? Fri, 19 November 2004 11:58 Go to previous messageGo to next message
still id prefer a willans 3 inch wide 4 point harness and my bride full bucket over a std seat and a sash belt
MS-75
Re: Why do people get roll cages? Fri, 19 November 2004 18:40 Go to previous messageGo to next message
interesting thread here fellas. Soooooo-I too have a question to pose.
Currently the crown is on the brink of running the magical 10.99 or faster for the 1/4. Now-although you may all tink 'gosh theres a billion rules to adhere to once you've done that', due to the fact that Adelaide International Raceway is a Bob Jane operated venue-the ANDRA rules to not apply as it is a track which is no longer ANDRA afilliated (believe it or not.....!!!!!). Consequently, if you turn up in a clean and roadworthy car, you are free to race. More specifically, if I turn up in my Crown, which is less than technically legal, although completely roadworthy and well maintained,and run a 10.99 or better, there is nothing extra to do (ie-no cage, no harness and possibly no parachute-but only above 140 mph with rear discs (135 with rear drums)).
Although I can get away without one, for my own safety I am considering fitting a cage, race seat(s) and harnesses. Has anyone here actually fitted a custom one/or had one fitted, and also gone the full race seat and harness set-up? If so, is it possible to design one up my self and have it fabricated, or is it more of a specialised field to ensure safety during an accident?
Cheers guys-sean
greenta22
Dandenong Ranges, VIC
Re: Why do people get roll cages? Sat, 20 November 2004 07:58 Go to previous messageGo to next message
Jim agrees with Rex here, the explosive charges pull the belt tight over the occupant, restricting forwards motion (hence the name, seatbelt pretensioners) pretty sure this is to minimise the risk of airbag related injuries, otherwise it would be desirable for the belt to "give" slightly to reduce the forces acting on the occupants.
[Updated on: Sat, 20 November 2004 08:01]
Alchemist
Re: Why do people get roll cages? Sat, 20 November 2004 08:41 Go to previous messageGo to next message
The HANS device looks the goods, if I was ever in a position to do some serious track work I'd invest in on of those!
Purple_Beasty
New Zealand
Re: Why do people get roll cages? Sat, 20 November 2004 19:26 Go to previous messageGo to next message
MS-75
First off you car is damn impressive.
When it comes to building a cage my personal opinion is leave it to the experts, they may not deal with Crowns that regularly but they will have the experience to design an appropriate cage. When picking someone to build your cage, talk to lots of people with cages in different areas of motorsport until you find a cage builder you are happy with. Usual story, check over their workmanship and attention to detail. Find an engineer who agrees with what you want to do and why you want to do it. Putting a cage in a road car is quite a bit trickier than slapping one in a race car, you don't need to worry about interiors, passengers etc.
Personally, you need to decide what you want out of the car, balancing between road and race use is pretty tricky stuff. By the time you put in a rollcage you pretty much have to say goodbye to the back seat. I don't know what the rules are like in Oz but in NZ you can get bolt in cages custom made and approved, they give you the extra peace of mind without the added hassles when using your car everyday. So then you put in race seats, use regular seat belts most of the time and swap in the cage and harnesses for racing. Not sure how you would go about this on your side of the ditch though.
Callum
ODR-666
Outer space
Re: Why do people get roll cages? Sat, 20 November 2004 23:10 Go to previous message
Hi guys,
I have a 4 point half cage in my mazda mx5 originally it cost me 550 from brown davis who manufactured it in sydney/melborne where ever it was
Such is the demand it was an off the shelf item that can be installed in less than an hour I also have sparco jnr seats and looking at harnesses in the near future original reason for getting the roll cage was for doing weekend track work out at QR for saturday arvo sprints etc
When i did it the insurance company etc or DOT etc didn'thave a problem with it as the car is a convertible chassis from the factory and the part is regarded as a saftey feature
now though with alot more money invested in the car it rarely sees the track and just draws attention from the boys in blue
My cage was fitted with harness mounting points etc so they are easy to engineer so on so forth when i do it!
What phases me is when you see a commodore or falcon with a 6 point roll cage ie bars going down to the back parcel shelf and side intrusion that people will still get in the back of these cars
The main problem with roll cages on the street is from a after accident point of view commonly cut to remove the turret are the a'b and c pillars to gain access to victims in such a case, when these are is substanially stregnthened it is no longer as easily accesable as originally was intended from the manufacturer
Then there is the fitting of harnesses in road cars! most people have them running either strait dowm to the floor or to the gap between the bottom and top part of the rear seat! which are both dangerous and illegal the minimum lower angle is 30deg below horizontal any more than the 30 deg and you risk breaking your back in a roll over as the seat cannot compress where as if you did have the right angle your seat can actually compress backwards into the rear of the car area .
in the case of my mazda the harness points are directly horizontal to the point where they go through the chair
there are also other things to consider a lap sash seat belt offers the occupant to be able to 'duck' ie move in board important in a convertable Cool but also in a sedan coupe etc
if you fit harnesses to a car without a cage you run the risk of not being able to be pushed down effectively having your haed pushed into the roof
so it becomes as some one said before a wepon rather than a saftey device if not used with the other right parts equipment etc
Just to add it also as said increases strucutural stregnth in a side impact if my car was T boned at 60 km's an hour by a landcruiser or small 4wd for that matter it is usually most certain death as your head is right in the bumper bar line with the roll cage the bumper bar hits it first and not your head
you dont realise how dangerous the road is till you get into a small car and look up at the world! especially when we are only allowed to lower our cars a tiny bit but 4wdrivers can go up a great deal (but thats a totally different debate!)
I for one am happy with my roll cage and will take it with me to my next mx5
Previous Topic:78 cressida ?
Next Topic:TRD
Current Time: Mon Oct 26 19:00:16 UTC 2026
Total time taken to generate the page: 0.25016403198242 seconds
