Toymods » Tech & Conversions » removing shocks
chubbylover53
removing shocks Tue, 16 November 2004 02:53 Go to next message
i'm treying to remove the shocks from my corona struts to put them in my celica one's. can anyone tell me how to do this. The nut holding them in is really tight and to big for a spanner.
Corona RT142
Campbelltown
Re: removing shocks Tue, 16 November 2004 02:56 Go to previous messageGo to next message
Was really tight on mine when my uncle did it we sprayed it with heaps of wd40 let it rest for a while then came back. He also had a spanner big enough so that helped.
Corona RT142
Campbelltown
Re: removing shocks Tue, 16 November 2004 02:58 Go to previous messageGo to next message
Also had to get my dad and I to act as a vice as my uncle tried to loosen it
ra23celica
Re: removing shocks Tue, 16 November 2004 03:41 Go to previous messageGo to next message
Vice, socket, rachet/breaker bar or water pipe. Don't forget to put spring compressors on before you start turning the nut.
rob_RA40
c'town, NSW
Re: removing shocks Tue, 16 November 2004 03:56 Go to previous messageGo to next message
i think hes talking about the nut thing that holds the strut in the tube not the nut on the shock holding the spring hat.
get yourself 2 pairs of stilson wrenches, one to turn the nut one to put your foot on stopping the tube from turning.
or use a big vice and a HUGE set of multigrips.
or use a big vice and buy one of those strut tube undo-er tools.
HyDrA
Adelaide, SA
Re: removing shocks Tue, 16 November 2004 03:58 Go to previous messageGo to next message
Hmmm... is there a standard size for that top strut insert "bolt"?
I have a feeling i'll be buying a large spanner very soon to fit my tokico's Wink
ra23celica
Re: removing shocks Tue, 16 November 2004 03:59 Go to previous messageGo to next message
Apologies, my BAD, you are right. Hire/buy/borrow a pair of stilsons and use the vice, that's how I did mine.
rob_RA40
c'town, NSW
Re: removing shocks Tue, 16 November 2004 04:01 Go to previous messageGo to next message
u know thats got me thinking, ive never heard it being referred as anything before,
so what is the proper term for that strut tube nut thingy?
ra23celica
Re: removing shocks Tue, 16 November 2004 04:03 Go to previous messageGo to next message
HyDrA wrote on Tue, 16 November 2004 14:58
No, I don't think so. Some are circular and others hexagonal, and some are like on Koni's, usinge a special spanner with two lugs on the two arms to remove them.
I know in the Koni's I bought for my RT132 struts I had to buy the correct strut retaining plate/bolt as the 077 part number they supplied did not match the thread. I had to use a 076 or 078 version. Memory suffers at this point Smile
paddles
Re: removing shocks Tue, 16 November 2004 04:08 Go to previous messageGo to next message
it's called a gland nut. try clamping the edges of the nut in the vice and then put a bar through the holes that hold the strut leg to the hub carrier and use this bar to turn the strut tube. this method works for an ae82 anyway Cool
rob_RA40
c'town, NSW
Re: removing shocks Tue, 16 November 2004 04:11 Go to previous messageGo to next message
paddles wrote on Tue, 16 November 2004 15:08
teh th1nk1n 0uts1de 0v teh square == teh win
ra23celica
Re: removing shocks Tue, 16 November 2004 05:04 Go to previous messageGo to next message
I don't doubt that it works but it seems to me that you would be 'shaking the dog' to 'wag its tail' !!! Very Happy
I guess you don't have any tube twisting or cross threading doing it this way rather than any other.
chubbylover53
Re: removing shocks Tue, 16 November 2004 06:47 Go to previous messageGo to next message
yeah thancks i used paddles method. it seemed to work the best and i dodn't need to buy n e thing so it's all good.
gr8r-x
Vic, AU
Re: removing shocks Tue, 16 November 2004 21:10 Go to previous messageGo to next message
Pipe wrench, spare wheel, some wheel nuts.. Works great, very easy for one person as well. Smile
Also, when it comes to putting the nut back on (or taking it off if you are recycling), put a rag around the nut, that'll stop the pipe wrench from ripping it to shreds. They can be nasty tools and the nuts can be rather soft..
1gt48u
newcastle
Re: removing shocks Tue, 16 November 2004 21:30 Go to previous messageGo to next message
there is a tool for removing/replacing gland nuts but its
$50.00 Sad
makes the job a lot easier Smile
Sam_Q
S.E suberbs, Vic
Re: removing shocks Tue, 16 November 2004 21:57 Go to previous message
I just clamp the stut length ways in my vice in such a way that it cant twist and use my oversized multigrips to undo the gland nut (thanks paddles!). Also works great for oil filters too. Where are you chubby? I can do it for you if you are in Victoria.
Previous Topic:Diff oil cooler
Next Topic:4age timing problem
Current Time: Mon Nov 2 06:07:46 UTC 2026
Total time taken to generate the page: 0.005620002746582 seconds
