Toymods » Tech & Conversions » EMS Stinger On 4AGZE Wiring Problems ?
MR2MK1SC
EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 04:42 Go to next message
I just purchased a EMS Stinger for my 4AGZE Aw11 and im having problems getting it started with the supplied base map. The base map supplied i believe was for the MAP sensored DLI 4agze as igniter's was set to two. I have since set it to 1. But would like to check my wiring with any 1 that has hooked one up to the stock distributor and igniter. Diz on the IRC channel gave me a hand but it seems that the plugs aren't firing correctly. as it fires as if its gonna start the stops and cranks for a while and fires again. But wont actually start. Any help would be great.
ae86trueno
Re: EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 05:39 Go to previous messageGo to next message
you have a PM
Ben.
4agte
Toronto, Downtown
Re: EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 08:43 Go to previous messageGo to next message
sounds like the timing is out.
MR2MK1SC
Re: EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 08:59 Go to previous messageGo to next message
this might sound newb then but how can i set the timing if the engine isnt running ? can i turn crank to the 10 degrees b4 tdc notch and turn the dissy till the rotor button lines up wif no 1. ???
ae95
Re: EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 09:01 Go to previous messageGo to next message
set it to zero dude
look in oil filler cap to see the indent on the camshaft
so you know its at the right stroke
if u dont see it
turn it over 180degrees
then set dizzy to fire on cyl 1
MR2MK1SC
Re: EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 09:05 Go to previous messageGo to next message
Ive got HKS 264 Degree cams will they have the notch in them. if not trial and error be ok ?
ae95
Re: EMS Stinger On 4AGZE Wiring Problems ? Tue, 16 November 2004 09:13 Go to previous message
look in tech docs for 4age manual
and follow that
Previous Topic:how low can compression be before engine wont run..
Next Topic:hilux full spool
Current Time: Sat Nov 21 04:21:59 UTC 2026
Total time taken to generate the page: 0.010166168212891 seconds
