Toymods » Tech & Conversions » Rules on what (year) engine can go into your car ..
Les
icon5.gif  Rules on what (year) engine can go into your car .. Tue, 16 November 2004 07:14 Go to next message
Ummm does the engine that you propose to put into your car have to be newer than the actual car itself ?
This never crossed my mind before as I have never modified or owned a modified car that is newer than 1985 !
i.e. 1998 car must be modified with an engine that is from a newer than 1998 model vehicle?
EDIT
OR whatever year the new engine is, it must meet the emissions standards of the original engine ...
[Updated on: Tue, 16 November 2004 07:18]
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 07:23 Go to previous messageGo to next message
yup, you got it..
the engine that goes in must be to the same emission standards as the engine that was in the car... if you can show that an older engine was still manufactured to the saem emissions, you should be able to put it in...
as a general indicator, engineers say same or newer, as then they have to determine if the older engine meets specs...
the other option is to have a pre-ADR car Wink
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 07:37 Go to previous messageGo to next message
I always used to think that you couldn't put an older engine into a newer car. However this it not correct! It all depends on the emission gear fitted.
BradW
Bottom of the hill, Sydney
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 08:13 Go to previous messageGo to next message
If fitting a late model engine to an old car, does the engine have to meet the emmission standards of the car it came out of or the car it is going into?
Hope that makes sense.
Brad
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 08:19 Go to previous messageGo to next message
BradW wrote on Tue, 16 November 2004 16:13
The motor you are putting in, has to have the same or better emissions as the motor that came out.
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 08:40 Go to previous messageGo to next message
CrUZsida wrote on Tue, 16 November 2004 19:19
for NSW, the new motor must maintain it's better emissions.. you can't make a new motor more smoggy because it's going into an old car...
that said... if you take an old block, stuff new bits into and onto it, then it still only has to meet the higher standard of car or motor...
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 08:43 Go to previous messageGo to next message
So NSW has, on paper, the emission results of every motor released in Australia in the last 30 years?
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 08:58 Go to previous messageGo to next message
CrUZsida wrote on Tue, 16 November 2004 19:43
in a way yes Wink
if the motor was released, unaltered, between sayy... 1992 and 1996, then the motor was still ADR compliant in 1996. thus the engineer can look up the emissions ADR for that year, and if those ADR's were unchanged until sayyy... 1998, then the engine is fine to install in a 1998 car, since the motor is compliact to that ADR..
same goes for all motos that have been released to comply to a given emissions standard... you may be able to better the emissions of a certain engine by fitting emissions gear from a later version, and that may satisfy an engineer...
Danish
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 09:06 Go to previous messageGo to next message
What about power restrictions?
I have a 1JZ-GTE in my GZ20 Soarer. Soarer's came with 1G-GTE's and 7M-GTE's so with the larger 7M-GTE at 3 litre single turbo, does that mean the 1JZ at 2.5L Twin turbo is still ok?
RWDboy
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 09:27 Go to previous messageGo to next message
So I'm sticking a pretty heftily modified 3S-GE into my 1976 TA-23, The 3S-GE is composed of a 5S block from a 1992 celica and 3S head etc. According to all these laws (in NSW at least), the 5/3S-GE would have to comply with the emissions requirements for the 1992 period from whence the block came, not the 1986 period that the head came from...
right?
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 09:33 Go to previous messageGo to next message
does it look and sound stock for that motor?
if it has been modified, then the emissions will be affected, and that changes things, but techincally... (and not being an engineer) yes..
you have altered a 5S motor, and that is the emissions you will need to comply with..
technically, without a full emissions test, it shouldn't be engineered, and technically, aftermarket ECU's are not to be used (except when locked after being tuned and passing a full emissions test)
but this is all how it 'should' be done.. not necesarily how it is..
you could argue that the better breathing etc will result in a more efficient motor and that it should pass emissions Wink .... a cat will always help your case....
Les
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 13:50 Go to previous messageGo to next message
so now to find out whether the ae101 4agze / ae101 4age 20 valve which come out 92-95 in japan meets the emmissions (or betters) a 1998 ae101 4afe corolla seca ....
As for you Danish ... http://www.rta.nsw.gov.au/registration/downloads/v si/vsi06.pdf
read page 3 brudda ... there is a table that tells you exactly what u can / cant do
[Updated on: Tue, 16 November 2004 13:51]
davedave
Re: Rules on what (year) engine can go into your car .. Tue, 16 November 2004 20:04 Go to previous messageGo to next message
Page 5 scares me a little.
http://home.swiftdsl.com.au/~wtf/other/chassis_weld.gif
Now I'm planning on moving one of my mounts a few centimetres as shown here:
http://home.swiftdsl.com.au/~wtf/other/mount_before.jpghttp://home.swiftdsl.com.au/~wtf/other/mount_after.jpg
Am I affected by this rule?
Les
Re: Rules on what (year) engine can go into your car .. Wed, 17 November 2004 00:28 Go to previous messageGo to next message
that would be up to the engineer i guess .. if he says ok, then you will be fine as the RTA seldom says no to an engineered car Smiley =
CHECK with the engineer first dude as he will need to see your mounts before engineering them !
davedave
Re: Rules on what (year) engine can go into your car .. Wed, 17 November 2004 01:11 Go to previous messageGo to next message
wow, so that IS a chassis rail flange that the mount comes stock welded on to. I wonder how the aw11 ever got past compliance!?!
Re: Rules on what (year) engine can go into your car .. Wed, 17 November 2004 01:27 Go to previous messageGo to next message
in the first pic, you can seen the flange bits welded to the corner of the chassis rail... second pic only has welds across the top of the rail
i would take the first pic over the second pic any day, but i would definitely speak to the enginner that was going to approve my car first...
ps, take both those pics to engineer and get them to point out whats wrong with both.. and ask what they would suggest... advice should be free, approval costs Wink
davedave
Re: Rules on what (year) engine can go into your car .. Wed, 17 November 2004 02:06 Go to previous messageGo to next message
Thanks Stewart,
The first picture is actually a stock mount, and as you can see when grinding it off, it was actually attached to both the top and the side of the rail.
http://home.swiftdsl.com.au/~wtf/other/mount_removal.jpg
I think you're right though, I'm best to take these photos to the engineer I'm going to use and ask him.
Thanks all for your help!
wagonist
Toymods Club Treasurer
Re: Rules on what (year) engine can go into your car .. Wed, 17 November 2004 02:07 Go to previous messageGo to next message
The rules being talked about here apply to NSW ONLY.
EACH state has its own different rules.
Re: Rules on what (year) engine can go into your car .. Wed, 17 November 2004 02:17 Go to previous messageGo to next message
wagonist wrote on Wed, 17 November 2004 13:07
they certainly do Wink most states are more generous than NSW tho, so following NSW rules should be fine for each state.. although SA seems to have some weird ones...
davedave
Re: Rules on what (year) engine can go into your car .. Fri, 19 November 2004 05:45 Go to previous messageGo to next message
Spoke to another engineer today (because I couldn't find the phone number of the first one I'd talked to). Anyways, I quizzed him on the welds and he said he'd be happy with a weld accross the flange as long as the weld was done right. That rule is apparently for older vehicles and trucks, modern cars used pressed steel frames.
But on the downside, I was going to quiz him about using my mr2 disks with the gt4 calipers. But was cut short in saying I'd have to use mr2 brakes as the bias is set up properly for a mid engine vehicle. I think I'm going to have to find the phone number of the first engineer, he was fine with the celica brakes.
Les
Re: Rules on what (year) engine can go into your car .. Fri, 19 November 2004 06:24 Go to previous messageGo to next message
davedave wrote on Fri, 19 November 2004 16:45
regarding the brakes, maybe you should consider why he told you to keep the MR2 brakes - he may have a point and it may be safer overall for the car as opposed to you 'upgrading' to gt4 calipers?
davedave
Re: Rules on what (year) engine can go into your car .. Fri, 19 November 2004 06:53 Go to previous message
It is something to think about....
But after just buying brakes, 16" 4 stud simmons, intrax springs & tokico adjustable shocks. I'd hate to have to use different hubs & struts. Not to mention starting all over again trying to find out which combination of axle and CV would be the right length and fit the new hubs I'd have to use.
My guess is using the planned twin piston celica brakes will just give that little extra braking in the front, but being the same size front disks and using the whole old back brakes, I reckon there'll be two shakes of f*ck all difference.
The 3sgte will only add about 10-20 kgs to my current weight, and with the post 87 aw11 being already 'over braked', I think I'll keep a few extra grand in my pocket.
[Updated on: Fri, 19 November 2004 06:54]
Previous Topic:how much house power for 4ag?
Next Topic:engineering a ta23 1G
Current Time: Fri Oct 23 16:33:20 UTC 2026
Total time taken to generate the page: 0.019385099411011 seconds
