Toymods » Tech & Conversions » Any body with a 4A-GTE?
86tt
Any body with a 4A-GTE? Tue, 16 November 2004 14:12 Go to next message
Could someone with a 4AGTE tell me what boost they are getting at 2600-3000rpm on full load? (also include what is your maximum boost, and if possible what turbo you're using? If you are using a boost controller?) thanks a lot... Very Happy
[Updated on: Tue, 16 November 2004 14:20]
ke382TG
Re: Any body with a 4A-GTE? Tue, 16 November 2004 21:46 Go to previous messageGo to next message
Before 3000rpm I get 20psi on full load and it will hold 20psi all the way to the rpm limiter Very Happy I can run more boost but it does not gain me any more peak power.
Turbo = T28 (from a pair on a GTR skyline)
Boost controller = one I made Very Happy
TE72_Turbo
Re: Any body with a 4A-GTE? Tue, 16 November 2004 22:36 Go to previous messageGo to next message
Mines not that responsive Confused
5psi at 2600 rpm
10psi at 3000 rpm
then builds very quickly from there to 19psi.
Turbo is from an S14 200SX (non ball bearing)
3" dump pipe etc.
Boost controller: Solenoid controlled by the haltech ECU. This is not gated and so does not bring the boost on any quicker than standard really, just allows adjustment of boost level.
86tt
Re: Any body with a 4A-GTE? Wed, 17 November 2004 02:50 Go to previous messageGo to next message
reason I asked coz I'm only getting 2-3 psi around 2600-3000, using a T28 .6/.64 and a turbo smart "gated" boost tee, so I'm trying to work out is the boost tee stuffed? I've got it brand new couple of days ago... Any other suggestions what could be wrong? Smile
ke382TG, how can you get 20psi at 3000rpm? That's incredible? Shocked
ke382TG
Re: Any body with a 4A-GTE? Wed, 17 November 2004 03:53 Go to previous messageGo to next message
That is a bit odd, because TE72_Turbo is using the same turbo as you, without a gate and his coming on boost much sooner.
Usually the turbo smart gated boost controllers bring on boost pretty quick with a big boost spike to begin with (as the gate is essentially not adjustable). Something mustn't be right somewhere on yours, can't put my finger on it though, especially considering you just replced the boost controller.
The exhaust housing on my T28 is a 0.48 A/R, my intercooler piping is short and only 2" in diameter, my intercooler is quite thin (ie post turbo my setup has very little volume to pressurise compared to most other setups) the cooler and piping is a legacy from the previous supercharged setup. No doubt a slightly thicker cooler core and some 2.5" piping may gain a little more top-end but I have no doubt I would lose the rapid boost response I currently have too.
I have played around with my boost controller a bit too to get the gate to work just the way I want it to. My low boost setting is not gated and the boost comes on much more gradually.
TE72_Turbo
[EDIT] looks like KE38 was typing a response at the same time!
[Updated on: Wed, 17 November 2004 04:18]
86tt
Re: Any body with a 4A-GTE? Wed, 17 November 2004 04:11 Go to previous messageGo to next message
hmm.. full boost around 5500-5800rpm @ 15psi... Razz (without boost controller boost only goes up to 6-7psi)
I'm suspecting the "gated" thingy in the Turbosmart boost controller is stuffed, becoz on dyno when it had a cheap "Powerup thingy" it had around 6psi @ 3000rpm, now I can't decide if the dyno graph was true or not?.
turbo is T28 normal non-ball bearing, still trying to confirm if it's a steel wheel...
ke382TG: my pipings are 2 inch too... but is not getting much boost... Razz
TE72_Turbo
Re: Any body with a 4A-GTE? Wed, 17 November 2004 04:16 Go to previous messageGo to next message
Do you have an exhaust leak by any chance? Or restriction in your exhaust perhaps (like a collapsed catalytic converter)??
What car did your turbo come from? If its from a 200SX (SR20), then its definately steel turbine.
86tt
Re: Any body with a 4A-GTE? Wed, 17 November 2004 04:25 Go to previous messageGo to next message
there was a small hole in the cat converter where a oxygen sensor supposed to sit, but that's been filled, and there doesn't seem to be any other leaks, no ticking noise around the turbo/exhaust manifold, although sometimes there's a bit of exhaust smell when accelerating hard...
When the car was being tuned, the guy told me the exhaust isn't restricting when I asked him was the 2.5" mandrel bent exhaust big enough, so I assume the cat is not collapsed?
I wouldn't really know where the turbo came from, but Garrett said it's definately a T28 (0.6/0.64) but when he was supposed to look up the ID tag for me in the end he forgotten, so I'm still getting that confirmed later..
NVD05X
parra
Re: Any body with a 4A-GTE? Wed, 17 November 2004 08:17 Go to previous messageGo to next message
from what i hear the gtr turbo's have a smaller exhaust housing so that could be why it spools quicker...
86tt
Re: Any body with a 4A-GTE? Wed, 17 November 2004 09:51 Go to previous messageGo to next message
but 20psi at 3000rpm is still incredible... Smile forget about twin turbo setup, and forget about super charger, @3000rpm there's virtually no lag.... Smile
so have anyone worked out if my turbosmart boost tee is a dud yet? Razz
NVD05X
parra
Re: Any body with a 4A-GTE? Wed, 17 November 2004 22:41 Go to previous messageGo to next message
i find 20 psi from a standard gtr t28 a bit hard to believe...
it must have been rebuilt/highflowed or something...
it also might relate to what kind of gze you started with...
i've heard the higher compression gze's spool up a bit quicker...
i know mine doesnt reach 15psi untill 3500rpm.. thats a s14 silvia non ball bearing turbo... and i have a low comp gze...
ke382TG
Re: Any body with a 4A-GTE? Wed, 17 November 2004 22:54 Go to previous messageGo to next message
It has been high flowed (these details are in the members ride section on my car on this forum, I had mentioned this in other threads but didn't bother with this one as it seems to be the same people asking questions in all the threads), it runs a larger compressor wheel, the exhaust wheel and exhaust housing are the standard size.
My ZE is the low compression one.
Quite happy to take any doubters for a drive Very Happy
86tt
Re: Any body with a 4A-GTE? Thu, 18 November 2004 01:22 Go to previous messageGo to next message
mine's high flowed too... Sad so is it obvious it's the boost tee now? Or will something else cause the same problem?
TE72_Turbo
Re: Any body with a 4A-GTE? Thu, 18 November 2004 02:41 Go to previous messageGo to next message
What has been changed with the high flow on your turbo 86tt? Have you got any pics?
Can you borrow another boost controller to try on your car to isolate the Turbosmart one as the problem?
86tt
Re: Any body with a 4A-GTE? Thu, 18 November 2004 14:12 Go to previous messageGo to next message
I think the turbo just been grinded a bit, steel wheel put in...
I'll see if I have time tomorrow to go to the shop where I bought the Turbosmart and asked them to replace another to try... Or should I just get one of those Powerups from the ebay?
Re: Any body with a 4A-GTE? Thu, 18 November 2004 23:04 Go to previous messageGo to next message
I'm not sure that I'd blame the turbosmart thingy just yet, because even with the hose connected straight onto the wastegate, you'd likely be building more boost than that, and the turbosmart thingy can't exactly make the problem any worse. Try running the car up to, say, 4000rpm with the wastegate hose disconnected altogether, keeping a close eye on the gauge to make sure boost doesn't go up to anything unreasonable. I'd be suspecting an exhaust leak, probably around the wastegate (otherwise you'd have to be stone deaf not to hear it!)
86tt
Re: Any body with a 4A-GTE? Fri, 19 November 2004 03:07 Go to previous messageGo to next message
becoz from memory, when the hose is pulled off, the boost builts up pretty quickly, I'll try again in a minute, to floor it at 2500-3000rpm and see what boost it builds, let u know when I'm back.. thx
86tt
Re: Any body with a 4A-GTE? Sun, 21 November 2004 06:57 Go to previous messageGo to next message
yeah it was bad news, because with the hose off it's still only boosting 2-3psi at 3000rpm, then I've found a little hole, about 2mm x 2mm on the intercooler, is that enough to make the difference?
ae86slaver
Re: Any body with a 4A-GTE? Sun, 21 November 2004 07:41 Go to previous messageGo to next message
i say it would be, a small hole can release a fair amount of vaccuum under pressure, so i won't be suprised if it was suffering boost loss
TE72_Turbo
Re: Any body with a 4A-GTE? Sun, 21 November 2004 09:12 Go to previous messageGo to next message
Not sure if that could contribute so much as to make much less boost, i've had a 6mm vacuum hose blow off the inlet manifold, but only noticed from the higher idle speed, it still made boost just the same. 2mm is not a very big hole, but you'd wanna fix it either way.
Or its a good excuse for an intercooler upgrade to happen now! Very Happy
MRKE20
wollongong
Re: Any body with a 4A-GTE? Sun, 21 November 2004 10:16 Go to previous messageGo to next message
how much boost are you guys running in you 4agte's. are the y stockers or been rebuilt. i was looking to run bout 17psi max with my new turbo, as i see it as long as you have the fuel there and the tunings good there should be no probs, but whats safe you guys recon for a stock, un opened gze block? not sure what version it is?, how do i check?
EVOSTi
cambo
      no
Re: Any body with a 4A-GTE? Sun, 21 November 2004 10:19 Go to previous messageGo to next message
my bottom end is stock, i run at around 15psi for daily driving, maybe about 18psi in winter.
86tt
Re: Any body with a 4A-GTE? Sun, 21 November 2004 12:09 Go to previous message
TE72_Turbo wrote on Sun, 21 November 2004 20:12
haha... yeah, that's a very good excuse to upgrade my 3 yo pipings and intercooler, but somehow can't find any spare change... Very Happy
at the moment I've put some body filler in the hole, if the filler gets blown out, I'll get someone to splash some welds onto it... Very Happy
Will test it out tomorrow after changing the oil & filter, hope that's where my missing boost was from... Very Happy I've tighten all the clamps at the same time and changed a few into silicon hoses, so finger's crossed
Previous Topic:Nevo Timing Marker
Next Topic:4age datto ute dizzy saga
Current Time: Sat Nov 21 13:38:36 UTC 2026
Total time taken to generate the page: 0.035403966903687 seconds
