Toymods » Tech & Conversions » Custom Intake Manifold
86tt
Custom Intake Manifold Tue, 16 November 2004 14:22 Go to next message
Does any one where I can get a good custom intake manifold made to flow some big numbers? I've been thinking of getting the stock RWD intake manifold for the 4AGE, but the rarity of these things, and the cost, I'm starting to wonder if I can actually fabricate a custom manifold that will actually flow better (around 20psi? I actually just stumbled across Bill's website)
gabe
Re: Custom Intake Manifold Tue, 16 November 2004 15:29 Go to previous messageGo to next message
Not sure what you mean when you say "Flow 20 Psi" but anyway....
When fabricating an intake manifold it may pay to build your manifold around the specs of the factory item. Specifically runner length and plenum volume and port sizing, unless of course you are planning to play heavily with cams and big turbochargers etc....
Reason being that Toyota have engineered the factory item and matched it to a specific engine with specific cam specs, and whether or not the engine is subject to forced induction and the like.
As far as pointers go, there is plenty here that a search will uncover, and I cant help you with a place to make one for you as I do all my fabrication work myself.
Gabe
86tt
Re: Custom Intake Manifold Tue, 16 November 2004 15:42 Go to previous messageGo to next message
Hi Gabe, thanks for the reply, but is the length of the runner really that important? As I've seen custom intake manifold with real short runners for the 4AGTE conversion, also I've seen people cut short the original 4AGE intake manifold so as to clear the bonnet, I've searched through yahoo and couldn't find much, so maybe I'll look in the phone book tomorrow..
Also, what do you think about the below?
http://www.hotengines.com.au/manifold_modfication. html
their intake manifold seem to look "square" and not rounded as in the factory 4AGE, do they flow less?
How much time and money would it cost you to fabricate a custom say 4AGE intake manifold?
blackjza70r
Re: Custom Intake Manifold Wed, 17 November 2004 03:39 Go to previous messageGo to next message
I'm no expert, but from what I have heard and read, you need to build the runners to the torque characteristics of the engine.
"US based engineering guru David Vizard suggests that a runner length of seven inches at 10,000rpm makes a good starting point. (Note that runner length is the distance from the plenum chamber right to the intake valve seat.)
Add to this another 1.7inches for each 1000rpm less than that which the system is being tuned for. Tuning for peak torque (not peak power) is the norm, so if the engine were being tuned for 4000rpm, a runner length of 17.1 inches (43.6cm) would be required."
-Julian Edgar, 2000 21st Century Performance
I ripped this from this thread which is worth a read....
http://forums.toymods.org.au/index.php?t=msg&t h=30397&rid=8258&S=75b68124fe687e3d107f17d 5fe7df261&pl_view=&start=0#msg_266989
It is not always practical to have huge long runners but if you look at the factory designs, they are not far from it.
As far as flowing well, its not always possible to "see" what flows well, though usually you can get a rough idea on if the manifold is restrictive or not.
I can make you a manifold, I have for a few others, not specifically a 4AG but the principals are the same. If you're not in a huge rush, PM me and we might be able to work something out
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 04:09 Go to previous messageGo to next message
Hi there, I'm not really in a rush at the moment, coz still using the cut and shut FWD manifold, but I was just interested to know when these FWD and RWD manifold starts restricting? And when a custom intake manifold is necessary? Since these RWD manifold are so rare!
TE72_Turbo
Re: Custom Intake Manifold Wed, 17 November 2004 04:13 Go to previous messageGo to next message
200rwkw doesn't seem to be a problem with the stock bigport manifold.
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 04:20 Go to previous messageGo to next message
TE72_Turbo: so I assume that's what you've got? But what's the chance of finding one for a reasonable price? Very Happy
TE72_Turbo
Re: Custom Intake Manifold Wed, 17 November 2004 04:26 Go to previous messageGo to next message
Yes, I have the RWD inlet manifold on mine, but it shouldn't be any better than a cut and shut FWD one, they have the same runners, just the throttle body is placed differently isn't it? Confused
gabe
Re: Custom Intake Manifold Wed, 17 November 2004 04:27 Go to previous messageGo to next message
blackjza70r wrote on Wed, 17 November 2004 11:39
Dunno what happened here. But I wrote that!!
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 04:36 Go to previous messageGo to next message
reason why I'm chasing the RWD is becoz my FWD seems to sit too high?! And have clearance problems with the bonnet, and from what I've seen, the RWD manifold seems to sit much lower?
ke382TG
Re: Custom Intake Manifold Wed, 17 November 2004 04:52 Go to previous messageGo to next message
I picked up my RWD manifold with a throttle body for $80 if I remember correctly. You see them go for about $150 more commonly. They don't appear to cause any sort of restriction up to 200rwkw as has been shown on a number of occassions now.
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 04:56 Go to previous messageGo to next message
ke382TG: so how long ago was it when you got yours for $80? Smile I'll pay straight away if I see one for $80 with TB... Very Happy
Re: Custom Intake Manifold Wed, 17 November 2004 07:14 Go to previous messageGo to next message
gabe wrote on Wed, 17 November 2004 12:27
Someone else at your work uses Toymods.
Terry I believe it is.
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 09:52 Go to previous messageGo to next message
if only I can find one for $80... Razz
4ageeza
Adelaide, drift capital
Re: Custom Intake Manifold Wed, 17 November 2004 10:06 Go to previous messageGo to next message
86tt wrote on Wed, 17 November 2004 15:06
I know a number of people who run cut and shut FWD intake manifolds in their ae86s. They dont seen to have any issues with bonnet clearance.
As suggested earlier, they are the same runner length ect. as the RWD?
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 10:15 Go to previous messageGo to next message
that's strange.. is there different FWD manifold? Because I've even seen in a japanese ae86 page using a FWD manifold and he had to cut part of the runners off which is right under the plenum to lower the intake manifold profile...
4ageeza
Re: Custom Intake Manifold Wed, 17 November 2004 10:22 Go to previous messageGo to next message
86tt wrote on Wed, 17 November 2004 20:45
Hmmm to my knowlegde they are the same length runner. However now that you meantion it, the people I know who have cut and shut intake manifolds all have smallport 4AGEs.
Can anyone confirm whether FWD bigports are identical in runner length and height as RWD bigports? I am not 100% on this.
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 10:44 Go to previous messageGo to next message
how does the small port & big port FWD manifold look like? They look different right?
4ageeza
Re: Custom Intake Manifold Wed, 17 November 2004 11:23 Go to previous messageGo to next message
The bigport 4AGE is a little similar in size and shape (from the outside) to the smallport 4AGE. The bigport has the TVIS.
In regards to this jap ae86 with a bigport cut and shut, could you please post a pic?
For one I dont see why a jap ae86 would have a FWD 4AGE and secondly I have many doubts that this manifold would cause any bonnet clearance issues.
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 15:12 Go to previous messageGo to next message
yeah, you've made a good point, why the hell they have to convert a fwd manifold to rwd when they should have so many manifold anyway? Razz here's one of the link, but I'm still trying to find the one where they had to cut the runners short...
http://www.mirai.ne.jp/~jnagai/inmani.html
http://members.dodo.com.au/~l88/small_port.jpg
I think this is the small port manifold that you've mentioned, found it on Bill's website, it looks pretty flush with the top of the engine (only slightly higher)
http://members.dodo.com.au/~l88/big_port.jpg
And this could be a big port manifold, which seems to sit much higher than the 4AGE engine?
86tt
Re: Custom Intake Manifold Wed, 17 November 2004 15:21 Go to previous messageGo to next message
this article written by Michael (which Michael??) also mentioned there may be a clearance problem with FWD manifold??
http://www.toymods.org.au/FWD_To_RWD_4A-GE/
Below is an extract from Phil Bradshaw's page mentioning the same problem... http://home.clear.net.nz/pages/phil.bradshaw/Engin e%20Installation.htm#Inlet%20Manifolds
so why does it happen only to certain people? Razz
Quote:
If you do not have access to a RWD manifold or you have a post 89.6 Red Top then there are two possible options (short of fabricating your own manifold or converting to carburettors); cut both ends off the manifold and swap the throttle body to the front of the manifold and blank the rear or else cut the intake runners and weld the entire top half of a RWD intake on (assuming the intake runners line up).
If bonnet clearance is a problem the 16 Valve manifolds can be shortened by cutting a section out of the vertical part of the intake runners and welding back together . My original engine was shortened 30 mm in this manner with no apparent loss in power. Be warned that this will place the cam cover breather almost horizontal and hence an oil catch tank is a wise idea. This all means that realistically the oil filler cap and plug leads are the limiting factors for bonnet clearance on 16 Valve motors.
[Updated on: Wed, 17 November 2004 15:25]
ae86slaver
Re: Custom Intake Manifold Wed, 17 November 2004 23:30 Go to previous messageGo to next message
I think that the only real clearance problem between the FWD and RWD manifolds is the slant at which the TB is. (this is shown on the first link)
as the bonnet slopes down, it runs parallel with the RWD manifold slant so you won't have as much issues where as the FWD one will have to be most probably shortened and adapted back to clear the bonnet.
86tt, so are you opting for more power? is this the reason you are after different manifold/cooler/turbo etc?
86tt
Re: Custom Intake Manifold Thu, 18 November 2004 01:34 Go to previous messageGo to next message
audioslaver: I'm fine with the turbo (should be good till 300hp+), just that I've only got a 1GGTE cooler, and a hole in my bonnet, so it's 2 things that I want to get rid of... Very Happy Because I'm putting the air condition back in soon, and I want to relocate the cooler a bit forward to fit the condensor, that will mean new pipings for cooler and so may as well replace the cooler if I can afford it.. Very Happy
Joshstix
Toymods Vice President
Re: Custom Intake Manifold Thu, 18 November 2004 01:44 Go to previous messageGo to next message
The TVIS manifold is the big port one, the ribbed manifold is a small port.
What kind of manifold are you running at the moment?
4ageeza
Re: Custom Intake Manifold Thu, 18 November 2004 02:02 Go to previous messageGo to next message
Please post some pics of your current intake manifold setup.
As meantioned, the first pic that you posted (TVIS manifold) is a bigport...with a weird looking adapter mounting the TB. The one below is a smallport.
86tt
Re: Custom Intake Manifold Thu, 18 November 2004 14:06 Go to previous messageGo to next message
Joshstix/4ageeza: you two seems to be saying the opposite thing??
I have the one below with 4 big runners...
4ageeza
Re: Custom Intake Manifold Thu, 18 November 2004 14:31 Go to previous messageGo to next message
By 'ribbed manifold' Joshstix is referring to the bottom 'Smallport' 4AGE. The ribs he means are the parallel ribs that run along the top of the plenum. The top pic is the 'blue-top' or 'bigport' as it is known.
For more info check out http://www.club4ag.com
86tt
Re: Custom Intake Manifold Fri, 19 November 2004 03:02 Go to previous message
so that means I have the bottom manifold, small port manifold with a small port head...
so why does some people have clearance problem with the manifold while other's don't? They must use the same mount right?
Previous Topic:water temp too hot
Next Topic:mixture hypothesis
Current Time: Sat Oct 17 21:16:00 UTC 2026
Total time taken to generate the page: 0.0067410469055176 seconds
