Toymods » Tech & Conversions » What should I replace on an import engine + what's this sticker?
davedave
icon5.gif  What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 01:51 Go to next message
Hi guys/gals,
Firstly, can anyone read this and tell me what it means. An educated guess tells me it means my timing belt was replaced at 80,000 on the 13/10/1997. In which case the low km import engine I have is not really low km Sad , or it has been sitting around doing nothing for a very long time Sad
http://home.swiftdsl.com.au/~mk15/images/IMGP1058_320x85.jpg
Now, what should I replace on this little fella? I'd rather spend a bit more money now than worry about pulling it out once it is in, but that said, I don't want to go over the top.
http://home.swiftdsl.com.au/~mk15/images/IMGP1060_640.jpg
My current list is:
Timing belt
Welsh plugs
Rear main seal
Rocker cover gasket
Turbo manifold/dump/water-bypass gaskets
Water pump
Water pump gasket
Air con & alt belt
Water pump belt
Thermostat
Thermostat gasket
Oil and fuel filters
Timing belt cover gaskets
Intake/Exhaust manifold gaskets
All fuel and water hoses.
Newly added:
Cam seals
Front seals
Silver insulated hoses that go to and from the oil cooler
Clean and test injectors
Clean the ISCV and the TB
I was also thinking about replacing the idler pulley bearings, but they seem to spin pretty freely by hand.
Can anyone think of anything else, or a reason why I shouldn't replace something I have mentioned.
PS, I will drop pants for anyone telling me to search. I'm pretty sure a similar thread came around a couple of months ago, but the search offered no help finding this thread. I have also hand searched quite a few pages of the tech and coversions section.
Dave
[Updated on: Wed, 17 November 2004 02:55]
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 01:58 Go to previous messageGo to next message
Thats the timing belt replacement sticker.
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 01:59 Go to previous messageGo to next message
BTW, looking at the list I only see the rear main seal, what about all the front ones?
Dust
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:01 Go to previous messageGo to next message
Cam seals?
its amazing how much this will all cost you, I just did most of that stuff on my 1ggte and it quickly adds up even buyin at wholesale prices :/
But in saying that, I would rather spend the money now then have to pull it apart later Smile
Good luck with the conversion.
ps. yeah educated guess would say that is timing belt change, but change it anyway, you never know how long its been sitting.
davedave
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:11 Go to previous messageGo to next message
justcallmefrank wrote on Wed, 17 November 2004 12:59
I was tossing up whether to do the front ones or not, but they're a bit of a pain in the @rse so I was going to risk them Smiley =. I'll add them to the list if you think that they're worth doing.
Also with the sticker, I'm more interested in knowing if that's a date on it and what is the date. Just trying to gauge the age of the engine for curiousity sake.
Dave
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:13 Go to previous messageGo to next message
It's a little bit of a pain in the arse, but being methodical, even a complete dunce like me was able to do it on my 1GGTE.
Joshstix
Toymods Vice President
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:25 Go to previous messageGo to next message
Definately replace the silver insulated hoses that go to and from the oil cooler. They are a complete pain in the arse to get to unless the turbo is removed so do it while it's off.
The sticker, yeah it's a date the Japanese calerdar dates are written Year, Month, Day.
Corona RT142
Campbelltown
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:33 Go to previous messageGo to next message
That stciker is dated 1997 and unless the engine has been sitting round since then the timing belt should need replacing again. At an average of say 15000km a yr even if the engine was in use for the next 6 yrs and lying around for a yr it would suggest that it's over due for another belt
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:34 Go to previous messageGo to next message
you can work out the kanji yourself by using:
http://www.csse.monash.edu.au/cgi-bin/cgiwrap/jwb/ wwwjdic?1R
have fun Smile
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:35 Go to previous messageGo to next message
Corona RT142 wrote on Wed, 17 November 2004 10:33
Japanese don't tend to do that many km's a year, but yeah, I'd be changing it regardless. It's a lot easier when its out.
rob_RA40
c'town, NSW
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:37 Go to previous messageGo to next message
clean and test the injectors while your at it
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:51 Go to previous messageGo to next message
rob_RA40 wrote on Wed, 17 November 2004 10:37
Couldnt agree more.
Also clean the ISCV and the TB while you are at it
davedave
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 02:52 Go to previous messageGo to next message
Joshstix wrote on Wed, 17 November 2004 13:25
I can't remember seeing those hoses, where do they run to/from?
Off topic: Did you have to remove anything to get it up in to the engine bay, ie turbo, manifold etc. I'm hoping to do a trial fit this weekend and would like to keep as much on as possible to start getting the position right.
Dust
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 03:27 Go to previous messageGo to next message
another thing that helped me alot, take lots of photos, every time u remove something, take a pic, cant count the amount of times i have refered back to my pics, somoene here suggested it to me, was good advice Smile
Joshstix
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 03:40 Go to previous messageGo to next message
davedave wrote on Wed, 17 November 2004 13:52
The hoses are in under the turbo and dump pipe, they connect to the bottom of the oil filter housing. They only cost a few bucks each but they really should be replaced while you've got access to them.
I had to remove the turbo and manifold to get my engine into the bay. Actually it may have gone in with the manifold but I don't think ti would be possible with the Turbo on. Then you really need to put the turbo and manifold on with the engine half one into the bay because it is a real pain to get to once the negine is mounted.
davedave
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 06:41 Go to previous messageGo to next message
Thanks for your help peeps, I've talked to my contact at Toyota, and await the quotation (aka: reaming) to be faxed through tomorrow Very Happy
Flogbag
Sydney (Campbelltown...!)
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 08:05 Go to previous messageGo to next message
instead of buying all those seals individually i would recomend buying a complete gasket kit, rings and bearings and rebuild it not that hard and it will ensure the motor lasts for ages and be reliable
davedave
Re: What should I replace on an import engine + what's this sticker? Wed, 17 November 2004 10:33 Go to previous messageGo to next message
Yep, got the whole gasket kit, but not planning on pulling the head or sump off. I've got to draw the line somewhere Smile
jase
Re: What should I replace on an import engine + what's this sticker? Thu, 18 November 2004 06:19 Go to previous messageGo to next message
Joshstix wrote on Wed, 17 November 2004 14:40
Seconded - this hose is a nightmare to change in the car. It's also killed more 3sgte's than anything else I can think of.
davedave
Re: What should I replace on an import engine + what's this sticker? Fri, 19 November 2004 06:15 Go to previous message
I was really struggling to find the part you were talking about in the EPC to order it. But then I remembered this write up http://www.mrtwo.net/mr2modproject/service/hfh/hfh .htm.
Will definately adding one of those to the list.
Got the quote back from toyota today, and even being looked after, it came to $1001.17, anyone got any lube I can borrow?
I think I'll start investigating some aftermarket parts...
Previous Topic:4age 7 rib bigport injector upgrade
Next Topic:MA70 / JZA70 FRONT BRAKES
Current Time: Wed Oct 21 18:56:51 UTC 2026
Total time taken to generate the page: 0.0060570240020752 seconds
