Toymods » Tech & Conversions » 3t-gte injection system issues - wont quite start
craufurd
Auckland
icon5.gif  3t-gte injection system issues - wont quite start Wed, 17 November 2004 05:22 Go to next message
Firstly my 3t-gte wont start.
The scenario
-If i leave it for a day when i come back to it it will nearly go. then after some cranking it sounds less and less like starting.
-inspection of the sparkplugs reveals they have become all wet and fuely. a quick whiff of the exhaust pipe confirms it seems to be flooding.
-It has spark on all 4. the timing has been set with a gun
My understanding
-The injection is non-sequential (what ever this might be called) and the injectors pulse 4 times in total prior to their respective intake strokes
-there are two inj plugs on the ecu. these are wired together in the loom to create this single pulse across all injectors
-fuel pressure at the rail needs to be at least 255 kPa or 36+psi i think as a conversion
My questions
is my understanding of the wiring correct?
what should the pulse length be in milliseconds at idle?
is there anything else i need to consider?
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 05:48 Go to previous messageGo to next message
Yeah thats correct about the wiring of the injectors. There actually is 2 seperate wires for the 4 injectors but internally in the ECU its all connected.
Sure the dizzy isn't 180 degree out?
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 05:49 Go to previous messageGo to next message
umm, cold start injector?
can you hear the main injectors clicking at all? or do they just fully open and flood the motor?
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 05:51 Go to previous messageGo to next message
An injector test light might help here.
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 05:54 Go to previous messageGo to next message
ahh, good idea Smile you mean LEDs with an appropriate resistor? Very Happy
craufurd
Auckland
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 05:58 Go to previous messageGo to next message
im pretty sure the dizzy is in the right place.
actually it cranked up after about 1 second after i rebuilt the eng but then it died a few mins later and hasnt started again.
auto elec measured injector pulse at a couple of milli seconds i think, so it is pulsing, not just staying open
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 06:26 Go to previous messageGo to next message
Quote:
ahh, good idea you mean LEDs with an appropriate resistor?
If its as easy as that, then yes Smile I am probably the twit who paid full price for one!
The injectors should only be pulsing, thats good. I could tell you the exact millisecond of mine if it wasn't in 101 pieces at the moment. But i think only 10ms pulses at idle or somewhere around that.
Have you taken a spark plug out and put hi tension lead on it to make sure its sparking? Just because timing light is picking up a pulse might not mean spark plugs firing.
craufurd
Auckland
Re: 3t-gte injection system issues - wont quite start Wed, 17 November 2004 23:12 Go to previous message
its possible the afm is giving bogus readings to the ecu as im not sure it is off a 3t - i know i have one off a 1g-ge the other im not so sure about. and there is a smaller one from a 2t-g.
what would be the consequences of using the 1gge afm on this engine wrt it not starting?
Previous Topic:AE86 FUEL GAUGE
Next Topic:Brakes - Slotted, Drilled or both?
Current Time: Thu Nov 19 19:08:54 UTC 2026
Total time taken to generate the page: 0.028356075286865 seconds
