Toymods » Tech & Conversions » 3t-gte speed limiter
steve-O
wollongong
3t-gte speed limiter Wed, 17 November 2004 10:37 Go to next message
hey guys i have a ta22 with a 3t-gte and i found out it has a speed limiter in 5th wondering if anyone knows how to get around this?
i thought i saw something on these forums about it but i couldn't find anything
Purple_Beasty
New Zealand
Re: 3t-gte speed limiter Wed, 17 November 2004 21:17 Go to previous messageGo to next message
I very much doubt the limiter is connected, especially with an engine swap. Go to Matti's Mainly Toyota page (link is on the Toymods link page), it shows which wire should be cut to disable it.
Callum
steve-O
wollongong
Re: 3t-gte speed limiter Thu, 18 November 2004 08:23 Go to previous messageGo to next message
ok i went to that site and checked it all out and it seems that the limiter has been disconnected. but that still doesn't change the fact that i cant go over 180km Confused i'm stumped. anybody ???
Toycrash
Finland
Re: 3t-gte speed limiter Thu, 18 November 2004 09:18 Go to previous messageGo to next message
Try add more boost Cool
steve-O
wollongong
Re: 3t-gte speed limiter Thu, 18 November 2004 09:52 Go to previous messageGo to next message
that doesn't help me Very Happy
Re: 3t-gte speed limiter Thu, 18 November 2004 10:11 Go to previous messageGo to next message
Maybe its the boost cut that is holding you back? The 3tgte factory ECU cuts fuel when boost gets over 6.5 or 7psi. Maybe its just some boost creep when you fanging along in 5th gear.
There is almost no way the factory speed limiter would be in place. For this to work you'd need an electronic speedo drive.
boris
On probation
Brisbane, Queensland
Re: 3t-gte speed limiter Thu, 18 November 2004 11:18 Go to previous messageGo to next message
I've had no problems getting to 200 with my 3tgte so i don't know whats happening with your car? Oh, i achieved this speed under controlled conditions Up To Something
Toycrash
Finland
Re: 3t-gte speed limiter Thu, 18 November 2004 14:07 Go to previous messageGo to next message
steve-O wrote on Thu, 18 November 2004 20:52
I was serious about that Confused
There is no way that speed limiter is able to cut your speed..
Have you tried what happens if you run 4th gear?
Some limiter it may be.. If it was boost limit, i think it would have been noticed on other gears too?
How about rev limiter? You can tell this by running 4th gear and try top speed Twisted Evil
steve-O
wollongong
Re: 3t-gte speed limiter Sat, 20 November 2004 04:34 Go to previous messageGo to next message
ok it has a rev limiter, i know cause i've bounced off it once before. in 5th it does this at about 5000rpm but it doesn't do it in any other gears, plus it backs itself off at exactly 180 everytime. i really dont know what could be making it do this Confused
[Updated on: Sat, 20 November 2004 04:36]
Pure_In_Sanity
Melbourne, Vic
Re: 3t-gte speed limiter Sat, 20 November 2004 04:49 Go to previous messageGo to next message
Is there a switch on the transmission to let the ecu know when it's in 5th?? - Just a thought but maybe rev limiter is lower in 5th just as some cars have a low rev limit when in neutral.
Otherwise it would have to be the boost cut.
Sounds really strange... Confused
Good Luck!
-Phil
Toycrash
Finland
Re: 3t-gte speed limiter Sat, 20 November 2004 15:12 Go to previous messageGo to next message
What about faulty fuelpump?
Pressure drops at full boost and max fuel consumption..?
scrote
Re: 3t-gte speed limiter Sat, 20 November 2004 17:22 Go to previous message
dude dont kill yourself huh. never actually took the car to 180 so cant help ya.
maybe check fuel pressure and intake temp gauge.
Previous Topic:TRD
Next Topic:where to mount SAFC??
Current Time: Tue Oct 27 11:42:25 UTC 2026
Total time taken to generate the page: 0.012156009674072 seconds
