Toymods » Tech & Conversions » Right Rear tyre loss of traction
Mookie
Tassie
Right Rear tyre loss of traction Thu, 18 November 2004 03:36 Go to next message
My
Right rear wheel spins really easy for some reason i don't know why the tyres are good but it just spins for stupid reason.
I cant reverse on even the slightest uphill angle on anything other than bone dry ashphalt.
Is this a sign that my diff is on the way out ?
and before you say anything when this happens i'm not dumping the clutch, I slip it as softly as i can.
It's wearing my tyre down is there anything i can do or do i just have to live with it ?
Mooks
[Updated on: Thu, 18 November 2004 03:37]
Re: Right Rear tyre loss of traction Thu, 18 November 2004 04:06 Go to previous messageGo to next message
Get an LSD
negative boost
Hobart, TAS
Re: Right Rear tyre loss of traction Thu, 18 November 2004 04:11 Go to previous messageGo to next message
What car do you drive?
My right rear wheel is also the main 'drive' wheel. In other words most of the power goes to this wheel, its called an open diff and thats why it spins so easily, happens to me too! LSD will fix this and improve handling.
As for tyres im going to regret saying this but if your chewing threw them so fast it might pay off getting some re-treads for the rear-bags. but watch it re-treads dont handle like 'real' tyres.
Mookie
Tassie
Re: Right Rear tyre loss of traction Thu, 18 November 2004 04:38 Go to previous messageGo to next message
Yeah i know an LSD will fix it and i was planning on getting one but does this mean my current diff is on the way out?
I have 2 retread tyres on wheels at home but i don't like the idea of having a blowout.
i don't care how much the tyres cost it's justi don't wanna be stuck down the rd with a blow diff
gearb0x
Re: Right Rear tyre loss of traction Thu, 18 November 2004 05:00 Go to previous messageGo to next message
Mookie wrote on Thu, 18 November 2004 15:38
The diff isnt on its way out if spinning one wheel is the only problem
I suggest taking it easy on the go pedal
3t-RA40
Re: Right Rear tyre loss of traction Thu, 18 November 2004 07:45 Go to previous messageGo to next message
Have you broken an axle?
Snap the left axle in mine once and the right rear would break traction without even trying, almost any gear. Broken axle would be pretty obvious though. It would feel real funny.
gold28
Madrid - Spain
Re: Right Rear tyre loss of traction Thu, 18 November 2004 07:57 Go to previous messageGo to next message
You obviously have to much power, Try a 4AG for an easy fix Laughing
Anyhoo I would be looking at your rear shocks and suspension bushes, It may be that you are getting too much torque transfer through the diff housing.
Mookie
Tassie
Re: Right Rear tyre loss of traction Thu, 18 November 2004 11:02 Go to previous messageGo to next message
Lol
it's a SA63 with a 2sc so i doubt too much power is a problem.
one of the rubber boots on the rear axle shafts has come apart and spread grease all over the bottom of my car could this have something to do with it ?
it's on the left hand side.
I can replace the axle shaft no problems as i have 2 spares.
i think my diff might be loose i'm not sure yet tho i've got it booked in to be looked at.
ZZT231
melbourne.vic.au
Re: Right Rear tyre loss of traction Thu, 18 November 2004 21:57 Go to previous messageGo to next message
Yes you should do something with the split rear CV boots, I did as I don't want to spend $250 for reconditioned CVs (I have spent more then enough on my MA61).
You sure that your SA63 have the right tyre size? I got 195s on mine and it hardly wheel spins in the dry when I boot it. How is the rear suspension?
Um... the SA63 has done 600,000kms and I don't have any driveline problem (besides a leaking yoke).
Cheers.
Mookie
Tassie
Re: Right Rear tyre loss of traction Fri, 19 November 2004 02:39 Go to previous messageGo to next message
600,000kms !!!!!
shit the bed that's a whole lotta kays.
MY suspension is fine and the tyres are 195s aswell.
I'll replace the axle shaft then,
The rear suspension seems fine nice and firm the way it has always been.
I got stuck on a flat piece of grass today how shit is that ?
gold28
Madrid - Spain
Re: Right Rear tyre loss of traction Fri, 19 November 2004 03:36 Go to previous messageGo to next message
Just a thought, It could be a really stuffed wheel bearing or something that is preventing the other wheel from rotating freely. This will put all the engine torque onto the free wheel.
Jack it up and have a good look at everything. Spin the wheels and make sure that everything is running freely.
ChuckLandwehr
Re: Right Rear tyre loss of traction Fri, 19 November 2004 04:34 Go to previous messageGo to next message
From what you have described, you are not getting ANY drive to your LH wheel.
This is being caused by something on the LH side being significantly tighter than RH side.
Sit down and think about how an open wheeler diff operates.
You have either 1 or more of the following:
1. brake binding on LH side,
2. a stuffed LH wheel bearing, or
3. a stuffed LH diff bearing.
regards Chuck.
Mookie
Tassie
Re: Right Rear tyre loss of traction Fri, 19 November 2004 07:04 Go to previous messageGo to next message
Thanks i'll jackit up and have a close look at everything.
oh and i can get the LH rear wheel if i push it.
The car had been sitting for a while before i drove it.
So i'll have a look at the wheel bearings.
the same thing happened to a mate barina the rear brakes just locked on and wouldnt disengage.
I've got a spare diff i could always try that in there and see how i go.
gr8r-x
Vic, AU
Re: Right Rear tyre loss of traction Sat, 20 November 2004 09:56 Go to previous messageGo to next message
Just jack the rear end up and spin the tyres.. They should both move freely, if both are off the ground.
Diagnose before you go replacing things like mad.
Mookie
Tassie
Re: Right Rear tyre loss of traction Sun, 21 November 2004 14:17 Go to previous message
they found a bolt loose on the top of the diff i haven't had a chance to test it as i am over 3 hours away i'm hoping this is the problem.
Previous Topic:engine shaking when fan n lamp on ...
Next Topic:1jz cam timing
Current Time: Mon Oct 26 20:20:05 UTC 2026
Total time taken to generate the page: 0.01448917388916 seconds
