Toymods » Tech & Conversions » Are RA40 and RA60 undersides and engine mounts the same?
cloud9crown
Are RA40 and RA60 undersides and engine mounts the same? Thu, 18 November 2004 09:35 Go to next message
could you swap engine and gearbox etc. between these 2 models?
cloud9crown
Re: Are RA40 and RA60 undersides and engine mounts the same? Thu, 18 November 2004 11:44 Go to previous messageGo to next message
and what about the susspention
cloud9crown
Re: Are RA40 and RA60 undersides and engine mounts the same? Fri, 19 November 2004 10:14 Go to previous messageGo to next message
*BUMP*!!!
Re: Are RA40 and RA60 undersides and engine mounts the same? Fri, 19 November 2004 10:29 Go to previous message
before bumping the message a third time, i'd suggest you do some research:
do RA40/60 share the same engine family (RA40 used 18R engines)?
do RA40/60 share the same front suspension ?
do RA40/60 use the same gearbox (W50 for RA40)
do RA40/60 share the same diff (RA40 has a hard axle - which later model had IRS?)
research... and some creative use of the search tool should answer most of this - search on a model name then add search terms like the engine and gearbox.
and don;t forget to use google!
and don't forget to go here:
<http://www.geocities.com/MotorCity/Pit/9975/tm_ind ex.html>
and spend some seriosu time going thru the links to:
models
engine
drivetrain
...or go to the wreckers and scout out both models. and take you tape measure and digital camera just in case.
Previous Topic:AE82 car wiring diagram (twincam)
Next Topic:Amplifier Problem, crackling sound through speakers...
Current Time: Sat Oct 24 16:20:56 UTC 2026
Total time taken to generate the page: 0.064572095870972 seconds
