Toymods » Tech & Conversions » 4age 7 rib bigport injector upgrade
b1gb3n
south Melbourne/KL
4age 7 rib bigport injector upgrade Thu, 18 November 2004 11:54 Go to next message
i have a jap spec 4age with tvis and i plan to upgrade my injectors.
based on http://www.club4ag.com/faq%20and%20tech_pages/4A-G E_technical_specifications.htm my impedence is 2 ohm, same as the ones on smallports. however, this is an american website.
can i plug and play smallport injectors onto my car? running standard ecu atm. if not, what is the easiest inj. upgrade to do?
engine has writing in black and 16valve in red
rxjohn
Melb VIC
Re: 4age 7 rib bigport injector upgrade Fri, 19 November 2004 04:11 Go to previous messageGo to next message
you will find that most 100kw are high impedence, if you got pink 86kw injectors 200cc they will be fine for 100kw engine power up.
http://www.toysport.com/webpages/Techinfo/Referenc es/injectors.htm
b1gb3n
south Melbourne/KL
Re: 4age 7 rib bigport injector upgrade Fri, 19 November 2004 06:16 Go to previous message
rxjohn wrote on Fri, 19 November 2004 15:11
exactly what i was looking for!!
Previous Topic:engineering a ta23 1G
Next Topic:What should I replace on an import engine + what's this sticker?
Current Time: Fri Oct 23 12:45:23 UTC 2026
Total time taken to generate the page: 0.0054290294647217 seconds
