Toymods » Tech & Conversions » water temp too hot
cr336
water temp too hot Thu, 18 November 2004 14:28 Go to next message
hello, my 4ag 1.6 FWD normal driving and the temp meter up to halfway and stay no change. I try take out the thermostat and let the fan running at the time but the needle also going to halfway. I thinks it will too hot for my car cause very hot weather here. Is there any way to do to make it down?? And also the water outlet blocked and have 2 wire plug there. Does it block the water out cause these?
ae95
Re: water temp too hot Thu, 18 November 2004 16:36 Go to previous messageGo to next message
halfway is ok
as long as it doesnt go to red
hemi twofifteen turbo
Re: water temp too hot Fri, 19 November 2004 03:13 Go to previous messageGo to next message
does it use water?
Have you tried flushing the radiator?
removing the thermostat isn't a good idea, put a new one back in, they run them standard and don't get hot, so your problem
lied elsewhere.
What do your radiator fins look like?
is the ignition timing retarded?
etc..
alliance_22
Re: water temp too hot Fri, 19 November 2004 04:03 Go to previous messageGo to next message
Sounds liek EXCATLY the reason for my old Skyline
I replaced:
Radiator
Thermal Stat (which i later removed fullY)
hosing
Water pump
and the last thing which was the CLUTCH fan .... that was the problem that caused it... So i'm not too familar with 4AG/AC engines.... but if a clutchfan is involved, then i'll be looking at buying a new clutch for the fan.
Thats my 2 cents
~Chopin
wagonist
Toymods Club Treasurer
Re: water temp too hot Fri, 19 November 2004 04:08 Go to previous message
Ummm.... he said its FWD.
unless the radiators mounted like a mini it'll only have electric fans.
Previous Topic:MA61 RA60 Crossmember
Next Topic:Custom Intake Manifold
Current Time: Mon Oct 19 17:57:49 UTC 2026
Total time taken to generate the page: 0.0044929981231689 seconds
