Toymods » Tech & Conversions » 4age 16v FWD gearboxes and ratios
incert
Trinidad
4age 16v FWD gearboxes and ratios Thu, 18 November 2004 21:30 Go to next message
I have a corolla ae-111 and i want to put in a 4age smallport 16v. I want to use my 4afe gearbox and clutch, will that be ok and will there be alot of wiring work to do in that kinda conversion or will it be easy. One more thing does anyone know the ratios on a 4afe box compared to the 4age box. Sorry to be a pest, had these questions unanswered for a while Embarassed
Hunty
Re: 4age 16v FWD gearboxes and ratios Fri, 19 November 2004 09:44 Go to previous messageGo to next message
incert wrote on Fri, 19 November 2004 08:00
someone has to ask...... WHY? but also im pretty sure it wont fit...easily. save more cash think about what u want....think harder....then come back
ummm pretty sure the ae111 didnt come out with a 4afc champ more like a 7afe or something even newer
as for ratios the gearboxes u can get for 4a series motors go something like this correct me if i miss anything guys
c50 same gb as in cs-x 5 speed models
c52 std twin cam gb slightly better ratios than c50 ie 1st is taller
c56 6 speed from jap levin
e5x (not sure what number x is supposed to be) LSD box from GZE, tuffer than c series but needs a bit of work to get into a ae82 or ae92 not sure bout n e thin else
Rod83
Re: 4age 16v FWD gearboxes and ratios Fri, 19 November 2004 10:48 Go to previous message
If it did come fitted with a 4afe, which is a possibility since he is in Trinidad, then fitting the engine shouldn't be too much of an issue. The biggest problem will be wiring, unless you plan to run an aftermarket ecu.
c56 is not a 6 speed. It was fitted to the 20v's and has better ratios for them, but it is still a 5speed.
c160 is the 6 speed.
Previous Topic:3tgte starts, but floods
Next Topic:AE82 car wiring diagram (twincam)
Current Time: Sun Oct 25 02:36:31 UTC 2026
Total time taken to generate the page: 0.069926977157593 seconds
