Toymods » Tech & Conversions » uneven camber, whats acceptable?
slydar
uneven camber, whats acceptable? Fri, 19 November 2004 02:28 Go to next message
Hey guys im am about to have my struts converted to coilover. ive had a suspension alignment check done, and my camber is slightly uneven, about .1*- on one side and .6*- on the other, so about a half a degree differance. i am thinking this is possibly due to a slight differance in stub axle angle.
Is this within tolerance, or should i maybe pick up another pair of struts before i go to the trouble of having them converted?
the man at fulcrum was of the oppinion that thats ok, anyone else? the car is also in need of some new lower control arm bushes, so i guess some of the problem (if it is one) may be there.
ill also have camber ajustable strut tops eventually.
any oppinions appreciated
IRA11Y
Club Member
Re: uneven camber, whats acceptable? Fri, 19 November 2004 05:15 Go to previous messageGo to next message
most road cars will run about a half degree extra on the left (passenger side) so as to counter road camber
slydar
Re: uneven camber, whats acceptable? Fri, 19 November 2004 10:22 Go to previous messageGo to next message
0.65- on th left, 0.1- right.
Re: uneven camber, whats acceptable? Fri, 19 November 2004 12:42 Go to previous messageGo to next message
If you're adding adjustment (which I'd hope you are if you're spending that much!) then I doubt it's likely to be too much of an issue...
slydar
Re: uneven camber, whats acceptable? Fri, 19 November 2004 13:42 Go to previous message
spending how much? i think i "might" maybe top 300 bux for my whole coilover setup.
but yes i will be adding ajustable strut tops once money permits.
Previous Topic:1990 Corolla - 20v Conversion
Next Topic:AE86 Dash Tacho colour of the input wiring loom
Current Time: Mon Oct 26 23:09:45 UTC 2026
Total time taken to generate the page: 0.0055460929870605 seconds
