Toymods » Tech & Conversions » Nevo Timing Marker
chrizer
Nevo Timing Marker Sun, 21 November 2004 00:45 Go to next message
Just installed the pulley, but dont know where to put the timing marker??? Can anyone with a Nevo kit help me out?
chrizer
Re: Nevo Timing Marker Sun, 21 November 2004 11:28 Go to previous messageGo to next message
Anyone??? Sad
Bill Sherwood
Brisbane / Gold Coast
Re: Nevo Timing Marker Sun, 21 November 2004 11:57 Go to previous messageGo to next message
I found TDC #1 using the dial guage amd marking the pulley with the piston a little way down the bore, either side of TDC - Then the point halfway between those two it the exact TDC.
I used a small chisel to mark the pulley then, and filed it smooth so the belt wouldn't get chewed up.
old_mr2
Re: Nevo Timing Marker Sun, 21 November 2004 12:15 Go to previous message
http://pic5.picturetrail.com/VOL86/504386/1188909/13821976.jpg
Here you can see the new Nevo tensioner and my new TRD sway bar too! Here is a clear view of the 175mm crank pulley and the new tensioner to the left. Also you can see the new timing pointer mounted on the oil pan - it is held in place by two 10mm oil pan bolts. I removed the original timing pointer by grinding it off.
Previous Topic:No oil pressure...on the gauge
Next Topic:Any body with a 4A-GTE?
Current Time: Sat Nov 21 13:46:30 UTC 2026
Total time taken to generate the page: 0.005202054977417 seconds
