Toymods » Tech & Conversions » 4agte, using standard ecu? is it possible
juzzo84
Hornsby, N.S.W
4agte, using standard ecu? is it possible Sun, 21 November 2004 06:14 Go to next message
heya guys my friend want to turbo his bluetop 4age and was just wondering what he has to do to retain the standard computer while running a turbo setup?? it will be running 7psi boost!!
justin
[Updated on: Sun, 21 November 2004 06:15]
ae86drift
sydney.au
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 06:24 Go to previous messageGo to next message
i could imagine the fuel supply of a turbo and a gze supercharger would be the same...
logic says it should work
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 06:27 Go to previous messageGo to next message
'Cept he said it was a bluetop 4AGE Very Happy
Seriously, don't. If he isn't going to do it right in the first place, he's always going to be plagued with problems.
juzzo84
Hornsby, N.S.W
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 06:34 Go to previous messageGo to next message
yeah, i understand there are issues, but is there a piggy back or something that you can get???
Smile
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 06:41 Go to previous messageGo to next message
Maybe. But it'll never work as well as one with a ECU made to handle boost. Could you adapt a 4AGZE computer?
ae86drift
sydney.au
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 06:42 Go to previous messageGo to next message
oh
4age ecu? no chance man, in hell, ever.
feral4mr2
Bundaberg, Qld.
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 10:48 Go to previous messageGo to next message
it's been done a before, as far as i know the people that have done it used a rising rate fuel reg (malpassi?) and put a diode in line with the cold start sensor or something. a bit of google and you would probably find info on it.
but as justcallmefrank said best to use a set-up thats made for boost.
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 10:59 Go to previous messageGo to next message
thats gotta be the DODGIEST way of using an N/A ecu to control a boosted motor EVER!!!
i am gonig to try something similarly dodgy, but will be taking it to a DYNO to be sure im not completely raping the motor in doing so..... and will be using a Jaycar Digital Fuel Adjuster kit to adjust mixtures if they need it.
# adding GZE injectors
# adding 2 bar MAP sensor (very important)
# making sure engine is physically plumbed and set up to take PRESSSURE in the manifold rather than vacuum.
juzzo84
Hornsby, N.S.W
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 11:05 Go to previous messageGo to next message
OK, thanks guys, looks like i will be telling him to go aftermarket ecu!! anyone selling one to suit bluetop 4age???
justin
feral4mr2
Bundaberg, Qld.
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 11:13 Go to previous messageGo to next message
yes it may be dodgy Karl, i dont even know exactly whats done other than the rising rate fuel reg.
i mainly wanted to state to ae86drift that it has been done.
ae86drift
sydney.au
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 11:18 Go to previous messageGo to next message
yeah it CAN be done, anythign CAN be done if you REALLY need it to work...
but i wouldnt classify that as being a legitimate way to run a performance engine... dodgy plus!
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 12:12 Go to previous messageGo to next message
i dont really consider 4a's a performance engine Razz
well not for my purposes anyway....
yep its dodgy plus Very Happy then again so is what im doing.
b1gb3n
south Melbourne/KL
Re: 4agte, using standard ecu? is it possible Sun, 21 November 2004 18:02 Go to previous messageGo to next message
juzzo84 wrote on Sun, 21 November 2004 17:34
Smile
i have a friend with a mitsubishi 1.5 twincam (4g9x). he turbo charged it and running on apexi SAFC. No problem so far. been half a year.
ofcoz he also has bigger ing, fuel pump etc....
probably able to do it to 4age as well
juzzo84
Hornsby, N.S.W
Re: 4agte, using standard ecu? is it possible Mon, 22 November 2004 02:07 Go to previous messageGo to next message
Ah, ok. where can you get an item like that, putting bigger injectors and pump in is not prob, but just have to sort the ecu out!!!
b1gb3n
south Melbourne/KL
Re: 4agte, using standard ecu? is it possible Mon, 22 November 2004 02:31 Go to previous message
apexi safc can be found easily. ebay definately.
not sure how it was wired up with turbo though.
Previous Topic:WHat is this kit and where can i get one from??
Next Topic:tell me about 13t-u's
Current Time: Sun Oct 25 18:00:35 UTC 2026
Total time taken to generate the page: 0.096456050872803 seconds
