Toymods » Tech & Conversions » Water temps??
nik3t
perth
Water temps?? Mon, 22 November 2004 00:47 Go to next message
hi i hav a 3tgteu just got it back on the road after a long time... added cooler..
over here in west its been a bit hot last few days..wondering wat normal water temps motor should be running..yesturday it was 35 deg and my temp went up to 95degrees and then at night it sat around 90..
is this normal guys??
ta
rob_RA40
c'town, NSW
Re: Water temps?? Mon, 22 November 2004 01:02 Go to previous messageGo to next message
where are u taking these temp readings from?
what range thermostat is in there?
most toyota engines should run at 82deg
Re: Water temps?? Mon, 22 November 2004 01:12 Go to previous messageGo to next message
My 1uz has an 82 deg thermostat.
Gets up to 94 at idle when stationary, this is when the thermo's kick in.
not sure what it sits at when driving, but its less than 88.
Dash Temp guage starts to move at about 98 deg C
RAV-GT4
Toymods member
Rydalmere, NSW
Re: Water temps?? Mon, 22 November 2004 22:34 Go to previous messageGo to next message
I got a 71° TRD thermostat in mine (~165°F) and mine sits around that mark most of the time, sometimes warmer, sometimes cooler depending on (what seems to be) outside air temp and traffic conditions. My thermo fans are on all the time so no probs with cooling it down. What kind of coolant is it running with? Is it running with the right mixture? These issues contributed to me having overheating problems before I switched over the thermostat and coolant for Toyota red. Wink
nik3t
perth
Re: Water temps?? Tue, 23 November 2004 07:58 Go to previous message
not sure what thermostat i have...hasnt been changed ever since ive had the car.
if i was to change the thermostat wat would i be asking for and from where for the 3t???
as far as coolant ive just got the premix anti-boil stuff from repco.. do i need a better quality??
Previous Topic:Squeaky Belt Aircon Compressor??? HELP :)
Next Topic:3sge gearbox??
Current Time: Mon Oct 26 09:21:58 UTC 2026
Total time taken to generate the page: 0.036508083343506 seconds
