Toymods » Tech & Conversions » ke11 lsd rear axle?
syncro
ireland
ke11 lsd rear axle? Mon, 22 November 2004 09:16 Go to next message
i want to put an lsd rear end on my ke11,
what kind of axle can i use that wont be too wide? i read somewhere before that an old skyline axle can be used if its narrowed on one side as its got unequal length shafts?
i have a few ae86 lsd axles at home in ireland, could one of these be narrowed to fit if the shafts can be resplined
or how about a hi-lux axle? can they be narrowed?
Re: ke11 lsd rear axle? Mon, 22 November 2004 10:25 Go to previous messageGo to next message
talk to a diff shop, as they will be the ones doing the shortening.
syncro
ireland
Re: ke11 lsd rear axle? Fri, 26 November 2004 06:44 Go to previous messageGo to next message
i can shorten the casing myself as i am a welder, i need to know what kind of half shafts have enough metal on them to be resplined after cutting the ends off.
Re: ke11 lsd rear axle? Fri, 26 November 2004 09:24 Go to previous messageGo to next message
Well if you're a richer man than I you can always get some axles MADE, but then if you've got that much cash, can I be your new best buddy??
syncro
ireland
Re: ke11 lsd rear axle? Sat, 27 November 2004 04:56 Go to previous messageGo to next message
would i be pissing about with a ke11 if i had money?
pro_ke
adelaide
Re: ke11 lsd rear axle? Sat, 27 November 2004 05:07 Go to previous messageGo to next message
you would want to be more concerned about the size of the ke11 axles rather than the actual diff centre!
what sort of power are you planning on making? if you are still using a k series motor you could get away with just locking the standard centre
it you plan on making 200kw then you would want a hilux
joeninety
Re: ke11 lsd rear axle? Sat, 27 November 2004 21:57 Go to previous messageGo to next message
If I had a few ae86 lsd's sitting around anywere ,i'd sell them and with the ridicolous amounts of cash these things seem to pull , I'd shorten an F or a G and throw in a gze for good measure. Times a few x $2000 and you have a healthy budget
nabs478
Re: ke11 lsd rear axle? Sun, 28 November 2004 06:29 Go to previous messageGo to next message
Do you have a photo of a KE11?? I've seen most of those early corolas and cant get enough of 'em.
It sounds like you'd be best of buying a whole drum-to-drum (or disc-to-disc) diff with LSD center then worrying about fitting to the car.....trying to shorten and re-spline axles will send anyone broke.
syncro
ireland
Re: ke11 lsd rear axle? Sun, 28 November 2004 07:15 Go to previous messageGo to next message
there is a link to photos of the car in the for sale section as i only bought it a week ago.
i have 3 ae86 axles, one from an 87 model complete with disks, one from an 84 model with the smaller size spline on the half shafts and no brakes and one with a quaife automatic torque biasing differential that i kept from my ke35 before i sold it...... but they are all in my garage at home in ireland, it would probably be cheaper to buy an axle in this country than to get one of mine sent out here, they are a crappy diff anyway(except the quaife)
i would eventually like to put a gze in it, i had an ae86 with a gze a few years ago.
indigoid
Canberra, ACT
Re: ke11 lsd rear axle? Thu, 02 December 2004 11:59 Go to previous messageGo to next message
there's photos of my ke11 in my fotki
really they're just a ke10 with slightly different trim, taillights that look like arse, and a 3k and front discs
syncro
ireland
Re: ke11 lsd rear axle? Fri, 03 December 2004 08:09 Go to previous messageGo to next message
i spoke to a diff shop yesterday and they tell me that the 28 spline nissan axles can be shortened and resplined if i get two long ones from one side i will have enough metal, they also tell me i just need a complete rear axle from a pintara and the lsd centre will fit from a post 92 commodore of falcon
syncro
ireland
Re: ke11 lsd rear axle? Sat, 04 December 2004 10:45 Go to previous messageGo to next message
got an lsd centre from a commodore today for 180 and i can get a pintara axle from disk to disk for 160 but im going to pull the shafts first to count the splines.
it will cost 165 per side to get the shafts shortened and resplined.
TheStitt
Membership Secretary
Re: ke11 lsd rear axle? Sat, 04 December 2004 23:53 Go to previous messageGo to next message
Chop down a Fseries and put a true trak in you'll never brack it
plus keeps it all toyota
syncro
ireland
Re: ke11 lsd rear axle? Sun, 05 December 2004 02:11 Go to previous messageGo to next message
but then i have to get the pcd changed to fit the 4 lug wheels, the pintara/skyline axle comes with disks and the 114 pattern so i just need to change my front hubs to ke30 or ke70 ones.
im told the hilux diff is too big and heavy for a ke11
TheStitt
Re: ke11 lsd rear axle? Mon, 06 December 2004 02:56 Go to previous message
Run a F series talk to some of the celica guys but you could pull a disc brake Corana Mark 2 F seruies rear end out and it will have the 4 stud pattern you need
Previous Topic:What cars come with front sump 1JZGTE's?
Next Topic:2tg dizzy to 18rg dizzy
Current Time: Sun Oct 25 01:29:27 UTC 2026
Total time taken to generate the page: 0.39748406410217 seconds
