Classifieds » Parts Wanted » Wanted: MA61 Electronic Dash
Les
Wanted: MA61 Electronic Dash Mon, 22 November 2004 10:05 Go to next message
I want to fit this to my RA65 ... does anyone have one lying around ?
Please post pics and price if you have !
Re: Wanted: MA61 Electronic Dash Mon, 22 November 2004 23:41 Go to previous messageGo to next message
Do you have a electronic 4 cyl one?
I'm guessing you need it for the 6 cyl tacho?
You know the wiring is COMPLETELY different between the two, and even how it interfaces with certain parts of the car is different.
Les
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 00:34 Go to previous messageGo to next message
enlighten me please - what is difference ? the actual connections ? or as u said the actual way it interfaces ?
EVERYTHING
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 00:35 Go to previous messageGo to next message
CrUZsida wrote on Tue, 23 November 2004 07:41
And you didnt answer this
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 00:37 Go to previous messageGo to next message
RE: converting
PM bbaacchhyy - he is/will be in the process of converting from Digital to Analogue.
Tis not an easy process.
Les
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 01:31 Go to previous messageGo to next message
sorry dude, it has a 6cyl 1g in it, hence the tacho is off already .. but if it is a hassle, better if i just fix the speedo cable and get a shop to convert the tacho to the right reading
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 01:37 Go to previous messageGo to next message
Oh, its a hassle to convert analogue dash to digital. (And vice versa)
Electronic dash uses a speedo cable anyway
ZZT231
melbourne.vic.au
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 02:08 Go to previous messageGo to next message
This might help you Les...
http://www.celicasupra.com/phpBB2/viewtopic.php?t= 12143&highlight=digital+dash
Cheers.
bbaacchhyy
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 06:12 Go to previous messageGo to next message
CrUZsida wrote on Tue, 23 November 2004 11:37
Freak Freak Freak Freak Freak Freak
I started wiring it up yesterday doing my best to decipher things, and have gotten easy things like blinkers, door ajar, hi beam, and handbrake to work, but dash lighting is not working (may be dodgy wiring on my car), but some other connectors are not easily traceable, and the cluster that I have is different to the wiring shown in the Mk2 TSRM.
So I'm gonna get the digi dash working properly and try and decipher the analogue one better.
At least I got the tacho working !!!!
Les
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 11:26 Go to previous messageGo to next message
ok .. sounds like TOO MUCH HASSLES !!!
thanks anyway guys Smiley =
bbaacchhyy
Re: Wanted: MA61 Electronic Dash Tue, 23 November 2004 20:05 Go to previous messageGo to next message
Les wrote on Tue, 23 November 2004 22:26
I'll get it done, but it will require more time and it will be worth it.
I hopefully resurrected my digi one last night by swapping over the various bits. For those that haven't pulled them atpart, they are in 3 separate modules : Tacho, Speedo and Fuel/Water temp.
Re: Wanted: MA61 Electronic Dash Wed, 24 November 2004 01:26 Go to previous messageGo to next message
bbaacchhyy wrote on Tue, 23 November 2004 14:12
Is this on the anal? or digi?
with? or without a tacho convertor?
IG- from the ignitor? or tach output from the ecu?
DETAILS BOY
bbaacchhyy
Re: Wanted: MA61 Electronic Dash Wed, 24 November 2004 01:38 Go to previous messageGo to next message
CrUZsida wrote on Wed, 24 November 2004 12:26
DETAILS BOY
Digi
Sixworks Tacho Booster
I belive from the ignitor, but I'll double check tonight.
Re: Wanted: MA61 Electronic Dash Wed, 24 November 2004 01:42 Go to previous messageGo to next message
bbaacchhyy wrote on Wed, 24 November 2004 09:38
Digi
Cool, thought thats how.
I'm trying to do it without the booster.
But I don't even know if the tacho works at all.
Gotta try with a normal motor.
bbaacchhyy
Re: Wanted: MA61 Electronic Dash Wed, 24 November 2004 20:49 Go to previous messageGo to next message
Here is a pic. It is connected to the yellow wire on the six pin connector on the ignitor, and goes to Pin 9 on the plug (black wire) on the back of the cluster. (Plug disconnected to clarify)
The grey wire is the one that is connected diirectly to the plug on the back of the cluster.
http://img79.exs.cx/img79/7958/2004-11-24007.jpg
Re: Wanted: MA61 Electronic Dash Thu, 25 November 2004 00:28 Go to previous messageGo to next message
bbaacchhyy wrote on Thu, 25 November 2004 04:49
So no booster?
Straight from yellow wire on ignitor, splice in grey wire, and connect grey wire to pin 9 (black)?
I currently have pin 6 on the ignitor connected to pin 9 on the dash.
Pin 6 was supposed to be IG-
The yellow wire is one of the -ve coil wires.
So you will have 1/3 the revs yes?
bbaacchhyy
Re: Wanted: MA61 Electronic Dash Thu, 25 November 2004 00:31 Go to previous messageGo to next message
CrUZsida wrote on Thu, 25 November 2004 11:28
So no booster?
The booster is hiding behind the stereo. (sse latest pics in Members ride section)
Yes. (except now it goes to and from tacho booster)
NFI, that is how it was wired when I got the car.
With the booster connected, I have the revs as per the test function (2k and 5k), but before, yes the revs were low, but don't know by how much.
[Updated on: Thu, 25 November 2004 00:32]
Re: Wanted: MA61 Electronic Dash Thu, 25 November 2004 00:34 Go to previous messageGo to next message
Cool, will check your thread.
So the booster is just 4 wires?
Ignition, Earth, old signal in, new signal out?
bbaacchhyy
Re: Wanted: MA61 Electronic Dash Thu, 25 November 2004 00:39 Go to previous messageGo to next message
CrUZsida wrote on Thu, 25 November 2004 11:34
It didn't work at fiorst, but when I got the right wire it was just as advertised.
Yes to the 4 wires and their connection !!! Only downside is the size of the unit.
Re: Wanted: MA61 Electronic Dash Thu, 25 November 2004 00:41 Go to previous message
bbaacchhyy wrote on Thu, 25 November 2004 08:39
Cool banana's
Sounds like the way to go
/thread hijacking
Previous Topic:WTB:V160 tranny
Next Topic:WTB: Sprinter roof lining in melbourne
Current Time: Sat Oct 17 10:52:16 UTC 2026
Total time taken to generate the page: 0.14496183395386 seconds
