Toymods » Tech & Conversions » which turbo for 7mgte? PLZ HELP
RAWS
Adelaide Street Racing ca...
which turbo for 7mgte? PLZ HELP Mon, 22 November 2004 10:29 Go to next message
I am about to replace the turbo and manifold on my 7mgte powered supra mk 3.
It is going to be part of the following engine build:
engine out
block decked and o-ringed, all gasket faces machined, inlet and exhaust manifolds match ported. HKS 2mm MHG stopper type and ARP head bolts torqued at 75nm. It will also have aftermarket ecu, intercooler, BOV and exhaust. Prob injectors too.
Im currently trying to source all these parts (I live in Adelaide). I also need a turbo/manifold/wastegate setup. I am aiming for 250-300kw. I'd like to spend under 3k on turbo/man/gate, so it seems it'll all be second hand. Which set up would cater to my needs? I was thinking hks to4e.
Also, can anyone think of anything else i'll need for this build? (Im also getting race pads & a big clutch)
Thanks guys.
negative boost
Hobart, TAS
Re: which turbo for 7mgte? PLZ HELP Mon, 22 November 2004 10:51 Go to previous messageGo to next message
Yeh, i'd back the TO4E. Thats just from what i've read out of an article Reg Reimer produced:
Over the past few months I have Dyno tested three different Turbos on the Supra GTE. See the Dynojet printouts in this article. The best turbo tested to date has been the HKS Sport Turbo Upgrade turbo kit for the 7M-GTE. This Turbo spools very fast and has a very wide power band, about 3300 rpm to well past red line if required. The Dyno runs show this turbo still pulling hard at 6500 rpm {see printout below}. This HKS turbo produced 339 HP and 398 ft/lbs of torque at the rear wheels. This turbo required an upgraded clutch to hold the power. The clutch I installed when I put the 7M-GTE engine in would not hold any more than 300 HP and 340 ft/lbs of torque at the wheels
http://www.supras.com/~riemer/gtestory/
celicaboy_2000
Lismore, NSW
Re: which turbo for 7mgte? PLZ HELP Tue, 23 November 2004 09:32 Go to previous messageGo to next message
Good luck doing all this for under 3 grand!
Computer $1000+
Dyno and installation $500+
Intercooler & Piping $1000+
HKS MHG $500+
Bigger turbo, Manifold, Wastegate $1500+
Motor rebiuld $1000+
+ other little bits and pieces
If you do get all this done for under 3K im sure there a people here wanting to know how Very Happy
Ive spent about 4 grand, look at my specs underneath.
[Updated on: Tue, 23 November 2004 09:45]
RAWS
Re: which turbo for 7mgte? PLZ HELP Tue, 23 November 2004 11:14 Go to previous messageGo to next message
celica boy, under 3 grand is what i wanted to spend on just the turbo/manifold and wastegate. I have 10k for the build.
twincam_ke20
Castlemaine Vic
Re: which turbo for 7mgte? PLZ HELP Tue, 23 November 2004 20:08 Go to previous messageGo to next message
http://www.importbitz.com.au/turbo.htm
theres two kits on there for a 7mgte.
bbaacchhyy
Re: which turbo for 7mgte? PLZ HELP Tue, 23 November 2004 22:25 Go to previous message
twincam_ke20 wrote on Wed, 24 November 2004 07:08
Second a vote for John at ImportBitz.
Talk to Bill Keen at ATS on Marion Road, as he has done heaps of work on Danny's car (HKS_TRD on these forums - and he is in the process of changing from a highflowed CT26 to a GT35 or so on a HKS manifold), and he is also rebuilding my modified CT26 which has a T04B Super V Trim Compressor and P Trim turbine in teh CT26 housings.
Danny's should make about 300 rwkW, and I'm aiming for about 260kW at the flywheel.
Michael B
Previous Topic:Internal vinyl reapplication/replacement
Next Topic:Burgundy GT4 Paint Code
Current Time: Sat Oct 24 03:25:47 UTC 2026
Total time taken to generate the page: 0.03410792350769 seconds
