Toymods » Tech & Conversions » How to adapt 4AGZE CAS to 20v head...
irishtwincam
Ireland
How to adapt 4AGZE CAS to 20v head... Mon, 22 November 2004 12:56 Go to next message
Hi everyone.
Does anyone have pictures or information regarding adapting an
AE101 4agze DLI CAS/pickup to a 20v head.
I am looking into what it would take to mount the pickup successfully on the back of the 20v head.
This is for the intention of running the 20v-GZE with the standard 16v MAP 101 GZE w/DLI ECU.
20v gze = standard 20v block/head/internals, w 4agze ancilleries (SC/ECU/Injectors/customer plenum)
Hers some reference pics:
My own site is down so Im apologise for robbing pics/bandwidth from another site.
4agze PICKUP (@ distributor location)
http://www.toy-ota.de/P1010076.jpg
20v distributor location
http://img.photobucket.com/albums/v342/hachi.roku/ mycar/wat01.jpg
http://img.photobucket.com/albums/v342/hachi.roku/ mycar/wat02.jpg
Thank you in advance,
Irishtwincam
gearb0x
Re: How to adapt 4AGZE CAS to 20v head... Mon, 22 November 2004 13:40 Go to previous messageGo to next message
Does the 20v dizzy have the same number of tooth pickups then the CAS? if so could you just make up a flat cap and remove the rotor?
irishtwincam
Ireland
Re: How to adapt 4AGZE CAS to 20v head... Mon, 22 November 2004 14:54 Go to previous messageGo to next message
Ive to look into this yet.
Pickin up a blacktop with a spun bearing in a week or two as part payment for a job Wink
Even if the toothed wheel has the same num of teeth
the actual magnets that pickup/generate a signal may not output the same signal as a 20v for the ECU to interpret?
The (dis)similarity of the signals would be known to Aftermarket ECU owners Im sure. Someone on Club4AG designed a Digital signal converter to allow the 20v pickup signal to work with a GZE DLI igniter negating the need to cut the bulkhead. so I think the signals are different Sad
Heres the links
http://forums.club4ag.com/topic.asp?TOPIC_ID=74944
http://home.insightbb.com/~jmengel4/dliconverter_w iringdiagram2.gif
Any input here from aftermarket ECU owners?
irishtwincam
Ireland
Re: How to adapt 4AGZE CAS to 20v head... Fri, 26 November 2004 15:50 Go to previous message
bump
Previous Topic:1zj AFM limit
Next Topic:st184 box onto 3sge on st162
Current Time: Thu Oct 15 11:06:16 UTC 2026
Total time taken to generate the page: 0.074733018875122 seconds
