Toymods » Tech & Conversions » 4age 7 rib bigport (jap) ecu diagram
b1gb3n
south Melbourne/KL
4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 00:48 Go to next message
i was searchin around the net and i found a few 4age diagrams that are different. Im not sure which one is for my car. I have a jap spec 4age as stated above with MAP, words on engine is written in black and "16 valve" in red.
anybody have a ecu diagram that is for this engine? Or any link?
Need it for installing SAFC
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 00:52 Go to previous messageGo to next message
http://sprinter.qnix.com.au/docs/wiring/4AGE-100kw /
http://www.club4ag.com/faq%20and%20tech_pages/ECU% 20Japan%20AE92%2090-91.htm
b1gb3n
south Melbourne/KL
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 01:05 Go to previous messageGo to next message
mine has TVIS. its not the 100kw version.
i have the one frm club 4ag. Im just not sure if its the right one. or which is the right one.
i have an ae92 levin gt apex btw.
edit : my car is 1988. club 4ag there is 1990-92
[Updated on: Tue, 23 November 2004 01:07]
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 01:57 Go to previous messageGo to next message
All the TVIS looms i've seen are pretty much the same, only differences would be AFM or MAP. You can open the ECU and printed on the circuit board is the pins usually.
What I normally do is get a few wiring diagrams, then check the pin outs and wires and work out what one is going to be most suitable. Sometimes one diagram matches perfectly, other times have to mix n match a few.
b1gb3n
south Melbourne/KL
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 03:37 Go to previous messageGo to next message
thats what i was thinkin. based on options available, mine should be similar to 100kw ecu. just gonna have tvis n 100kw ecu diagram to compare. I suck at wiring though
thanks alot anyway ra28turbo
takai
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 04:03 Go to previous messageGo to next message
Look on the apexi usa site, you can download the english wiring diagrams from there. Easy as pee.
b1gb3n
south Melbourne/KL
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 06:43 Go to previous messageGo to next message
i have the blue screen version. they only tell u to connect to batt, throttle etc... dont show u which is which
takai
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 06:46 Go to previous messageGo to next message
Yes it does.
Or do we have to hold your hand the entire way?
SAFC http://www.apexi-usa.com/productdocumentation/elec tronics_safc_wire.pdf
SAFC2 http://www.apexi-usa.com/productdocumentation/AFC2 Wiring.pdf
Do you want someone to solder it too?
b1gb3n
south Melbourne/KL
Re: 4age 7 rib bigport (jap) ecu diagram Tue, 23 November 2004 14:05 Go to previous message
thanks takai
missed out on that link when searching
u da man!!
Previous Topic:Burgundy GT4 Paint Code
Next Topic:Volvo 690 trans for 1JZ
Current Time: Sat Oct 24 11:01:03 UTC 2026
Total time taken to generate the page: 0.0052750110626221 seconds
