Toymods » Tech & Conversions » rear sprinter height adjustment
Sam_Q
S.E suberbs, Vic
rear sprinter height adjustment Tue, 23 November 2004 08:33 Go to next message
has anyone setup a rear height adjustment on a sprinter or a simular setup without converting to coil-overs? I am thinking about doing this thats all.
ae95
Re: rear sprinter height adjustment Tue, 23 November 2004 08:40 Go to previous messageGo to next message
how would you do this without coilovers?
spring compressors?
Re: rear sprinter height adjustment Tue, 23 November 2004 08:53 Go to previous messageGo to next message
With your Fat Cousin Lenny in the back - too high = more custard tarts, too low = starve him. Simple, ey?
takai
Re: rear sprinter height adjustment Tue, 23 November 2004 08:56 Go to previous messageGo to next message
Adjustable perch height.
Sam_Q
S.E suberbs, Vic
Re: rear sprinter height adjustment Tue, 23 November 2004 09:30 Go to previous messageGo to next message
I was thinking of a setup where the original seat is removed off the diff and a tube is welded to the housing that is the same I.D as the spring, from there it either winds up and down via a threader collar like a coil-over or by spacers.
Takai: ever seen or heard of this perch height adjuster?
takai
Re: rear sprinter height adjustment Tue, 23 November 2004 09:35 Go to previous messageGo to next message
Yeah, seen a similar design on a 300ZX. They used a 65mm coilover setup and welded it to the base and an upper hat on. It was kept captive by a chain. Slightly dodgy if you ask me.
Simon-AE86
Banned user
ADELAIDE - The Drift City
Re: rear sprinter height adjustment Tue, 23 November 2004 09:38 Go to previous messageGo to next message
pick a height and stick with it!
honestly, even with adjustable coilovers are you going to be changing the height all the time?
doubt it
IRA11Y
Club Member
Re: rear sprinter height adjustment Tue, 23 November 2004 10:10 Go to previous messageGo to next message
This might be what your referring to..
http://ira11y.qnix.com.au/Coil%20overs%20008.jpg
found here... http://forums.toymods.org.au/index.php?t=msg&t h=2463&start=0&rid=2&S=6af29221cfcf0f6 b2b0db7b7ef243eb6
takai
Re: rear sprinter height adjustment Tue, 23 November 2004 10:29 Go to previous messageGo to next message
Not quite Michael, this was ona 300ZX. But yours looks quite interesting too. How reliable would you peg it? I note that you specifically said IP. Thats now one of the things i have to comply to. Interesting....
Sam_Q
S.E suberbs, Vic
Re: rear sprinter height adjustment Tue, 23 November 2004 13:08 Go to previous messageGo to next message
Simon-AE86: find a height a stick to it? sounds good except how do I find the right height when I cant change it to test it out? I plan to tweak all 4 corners of my car a few times untill I get it right, then keeping it there.
IRA11Y and takai: I was thinkig of something a bit less dodgy!
Perhaps if I can I should just make something up
Re: rear sprinter height adjustment Tue, 23 November 2004 22:37 Go to previous messageGo to next message
Whats dodgy about IRA11Y's setup?
Sam_Q
S.E suberbs, Vic
Re: rear sprinter height adjustment Wed, 24 November 2004 01:33 Go to previous messageGo to next message
well it isnt the best pic but I think the spring would rub against that collar under the right circimstances, also I wonder how captive that spring is. This is one of those times I want to keep an original design part. As a bous I would have less chance of getting defected.
EVOSTi
cambo
      no
Re: rear sprinter height adjustment Wed, 24 November 2004 10:09 Go to previous messageGo to next message
man there is no way that spring would come off. you dont want dodgy but you want to weld a tube to your diff? why dont you find a tried and tested suspension combination that works rather than something thats gonna be dodgy just for the sake of the wank factor.
Sam_Q
S.E suberbs, Vic
Re: rear sprinter height adjustment Wed, 24 November 2004 21:13 Go to previous messageGo to next message
there is nothing dodgy with my idea, I would do it in such a way that I would try and make it look factory and would be used to fine-tune my suspension. No wank factor here I want to adjust the balance of my car. It would even work out in conjection with one of these tried and true packages as you call it to make fine adjustments to my personal prefrance.
EVOSTi
cambo
      no
Re: rear sprinter height adjustment Thu, 25 November 2004 05:47 Go to previous messageGo to next message
for the money you would spend im sure you could get a high quality coil-over setup for the same or cheaper. less hassle and im sure better anyway.
IRA11Y
Club Member
Re: rear sprinter height adjustment Thu, 25 November 2004 06:36 Go to previous messageGo to next message
well to be honest i still dont have it in the car yet, that pic was a mock up. Ive been very busy trying to get the front end just right first and been waiting to buy a rear swaybar before i put the coil overs in ( which I have now bought so will be in the car very soon )
but reliability wise i decided on this setup because this is exactly how noltec set up the IP AE86's and was suggested to me by Dave at Noltec so that it would still pass engineering for street seeing as its not in effect a true coil over setup on the rear and also it can be easily set up as captive by choosing the correct shock configurations
see above nothing dodgy about this setup at all... a few more things to note about that specific picture of my coils though....
in that shot there are a few things ive left off.. it was a test fit after all Smile
firstly the top spring perch is not there, this helps to keep the spring a bit more captive and by drilling a wire tying ( like what you do to meet scriutineering in rally ) the spring to the top plate helps to secure it further, although this is not really neccesary if you choose a correct length max shock stroke that keeps the spring captive at all times ( referring to live axle set up here )
secondly theres no bumpstop, ill be cutting down a factory one so its a bit shorter which bolts in and holds the top plate as well
thirdly, similar to what has been discussed the threaded sleeve is welded to a section of pipe which in turn is welded directly on to the original spring perch, so if you ever need to you can still throw the original springs back in and you also dont upset the axle tube by heating it up with welding, the std perch is more than strong enough to cope with the job, you may need to do a bit of intracate grinding on the pipe to get it to sit nicely but a bit of patience and carefull planning makes it all easy.
hmm what have i missed......
oh yeah,
nope it doesent, with the correct spring and shock combination the movement is limited and the only reason it would ever rub is if you havent set the angle correctly to cater for foward tilt movement on full lift. at the end of the day that is down to how well you set it up in the begining.
I havent heard of any problems with this from the IP guys either.
Sam_Q
S.E suberbs, Vic
Re: rear sprinter height adjustment Thu, 25 November 2004 12:07 Go to previous messageGo to next message
IRA11Y: mosty opf the things I was looking at and thinking was dodgy were things that u pointed out as being unfinished. Although looking crude it has the capability of working well. I thought that the spring would rub because the angle of the collar seemed wrong, but now that u say it was only a temporary dummy fit thats a different story. I would like to see it when it is done.
EVOSTi: I would prefer not to machine a circlip grove in my shockers for a colar and also it would be very close to my tire and would severly limit tire choice I would think. bracing the shocker mount would be pretty insignificant for me though, i am welder happy. Depending on how things work out down the road I will consider it.
Anyway for now I have pretty much decided I will either get to chose the right height because I need to get some custom made or I will carefully measure up what height I want and drop the spring seat height appropriatly.
IRA11Y
Club Member
Re: rear sprinter height adjustment Sat, 27 November 2004 06:33 Go to previous messageGo to next message
well to keep you all happy I got out in the searing heat of sydney to do a proper test fit today and took a pic so you can see exactly how it should seat up...
http://ira11y.qnix.com.au/rearcoil.JPG
you can see that now the top seat is in position its fairly captive and thats with the diff floating freely at its lowest point on the shock.. therefore it is captive all the time without having to lock down with ties.
The two spacers on the top perch was what I was testing to get the correct alignment, an alloy wedge will be cut to the correct measurements, then fitted to give a perfect angle down to the lower perch and therefore avoiding any possible binding. You can see as I mentioned previously that the factory bump stop will need to be cut down, this is no real issue as they are easily cut with a stanley knife to size.
Sam_Q
S.E suberbs, Vic
Re: rear sprinter height adjustment Sat, 27 November 2004 12:24 Go to previous messageGo to next message
thats starting to look pretty good IRA11Y, where did u get the collar and spring from?
SLYSEVENONE
Re: rear sprinter height adjustment Sat, 27 November 2004 22:04 Go to previous messageGo to next message
the collar is noltecs coilover kit and the spring is from Eibach
takai
Re: rear sprinter height adjustment Sat, 11 December 2004 23:50 Go to previous messageGo to next message
On friday i had a look at the rear end on my sprinter and came to the conclusion that there just isnt enough room there without removing that protrusion which normally sits in the spring at the top and holds the bump stop. With the short stroke shocks, at 110mm travel i have less than 15cm between where the hat would sit and the top of the seat. Certainly not enough to fit a coilover kit and collar into.
Any other suggestions.
IRA11Y
Club Member
Re: rear sprinter height adjustment Sun, 12 December 2004 00:38 Go to previous messageGo to next message
thats interesting... a KE70 rear end is the same as an AE86 and mine fits in the KE70
EDIT: Oh and Noltec do it exactly as i have done for the AE86 IP cars and they have no issues either.
[Updated on: Sun, 12 December 2004 00:39]
IRA11Y
Club Member
Re: rear sprinter height adjustment Sun, 12 December 2004 00:47 Go to previous messageGo to next message
do you mean that you cant get the spring in there or that it makes the car sit too high??
have you tried using a spring compresser to get them in?
takai
Re: rear sprinter height adjustment Sun, 12 December 2004 01:13 Go to previous messageGo to next message
There is no way i could physically fit the height adjustment collar in there. There ended up being about 20mm between the upper chassis mount and the collar when it was placed in there. The Noltec one that is. Thats without the coilover upper hat too. i.e. i would have 20mm or less of travel all up.
I think it has to do with the fact that my shocks are 110mm stroke at max i.e. very short stroke, and so compared to your "full" or long stroke shocks there isnt the room in there. Ill try and take a pic soon of the rear of the car jacked off the ground, its quite interesting. Drops about 20mm all up, need to get some softer springs in there.
IRA11Y
Club Member
Re: rear sprinter height adjustment Sun, 12 December 2004 02:30 Go to previous messageGo to next message
why do you need such short stroke??? even my two way adjustable Konis arent that short? currently im actually running some Hilux shocks which have about 2cm longer than std lenght stroke but they are equal resistance in rebound and bound to some smaller Dia race shocks
takai
Re: rear sprinter height adjustment Sun, 12 December 2004 03:39 Go to previous message
To be honest, i dont really. I have them mainly because they perform better than the konis and only a slight bit worse than the Bilsteins. That and they are about half the price.
Previous Topic:aftermarket comp question for a noobie
Next Topic:MA61 Steering Rack
Current Time: Fri Nov 20 10:24:50 UTC 2026
Total time taken to generate the page: 0.014240980148315 seconds
