Toymods » Tech & Conversions » 18RGU
rockguru
Central Coast
18RGU Tue, 23 November 2004 09:43 Go to next message
This may be a stupid question, but what is the porthole in the top of the 18gru for?? I have seen some with filters and some with rubber tubes. Can anybody help??/
people100
Rocklea qld
Re: 18RGU Tue, 23 November 2004 10:48 Go to previous messageGo to next message
its suppose to go to your carbs. I think its for ventilation etc...Some people just stick a filter on there for the same affect and some looks but i think its actually illegal to that..
Re: 18RGU Tue, 23 November 2004 23:29 Go to previous messageGo to next message
It's crankcase ventilation. Either plumb it into the inlet (as per the factory setup) or hook it up to a catch can.
buderimboy
Sunshine Coast(Buderim)
Re: 18RGU Wed, 24 November 2004 10:57 Go to previous messageGo to next message
It use to go to an elbow in the middle of the original metal plenum plate that bolted to the front of the carbies.
F.Y.I The two 6mm bolt holes where for a solenoid(which dumped in fresh air) that was piped to the 10mm nipple on the balance pipe between carbies to stop running on when the engine stopped.(anti-dieseling valve)
Nort.
brett_celicacoupe
townsville NQLD
Re: 18RGU Wed, 24 November 2004 11:00 Go to previous messageGo to next message
where do all of these actually go?? there is like 5 comin outta the carby balancer. also, where does the one comin out the auxilary camshaft (that runs the fuel pump, oil pump) place go??
thanx
buderimboy
Re: 18RGU Wed, 24 November 2004 11:25 Go to previous message
From memory that pipe on the left hand side goes to the inlet manifold on the 18R-C.
As for the others,unless you have the emission control,the VSV`s(Vacuum Switching Valves)don`t worry,just connect the dissy advance diaphram outer nipple to port J on the 3 port TVSV in the thermostat housing(line 2) out of port K(diagonally across)to hex vacumm port on top of balance pipe(line 0)Front port of TVSV(J)line 5 goes to vertical nipple on No.1 cylinder carbie inlet housing. The inner nipple on the dissy goes to a valve that was originally behind the thermostat housing(port Z on the VCV valve)line marked 1,out of port Y line 0 to 3 port hex valve.
Hope that`s not to confusing,
Regards,
Nort.
Previous Topic:Headlight repairs
Next Topic:Stock 20V auto ecu with manual box
Current Time: Sat Oct 24 09:52:53 UTC 2026
Total time taken to generate the page: 0.0056040287017822 seconds
