Toymods » Tech & Conversions » 4AGZE GEARBOX SHIFTING PROBS
GUN METAL 87 SC
SYDNEY
4AGZE GEARBOX SHIFTING PROBS Wed, 24 November 2004 03:27 Go to next message
Doods,
Need some ideas on oil and fixes for a 4 AGZE gear box.
Its in an OZ spec AW-11, i believe the engine and gear box are out of a 94 Levin AE-101.
The shift is crap when cold better when its warmed up and good when raced. The main problem is 1 st and 2nd gear (i have heard the syncros are a problem in these boxes ??) Toyota have reccommended a 75W-90 oil so will see how that goes but has anyone got any other suggestions ?
I have also read somewhere about a different set of syncros to fix this prob does anyone know where to get them from ?
Thanks,
Scott
Re: 4AGZE GEARBOX SHIFTING PROBS Wed, 24 November 2004 04:59 Go to previous messageGo to next message
dude - it would take you some SEVERE abuse to break an E series box, these are the same series as used in GT4 celicas, behind 3S-GTE's and 4A-GZE's.
As for the 1st-2nd gear change thing... well thats a matter of opinion and shit. The most common advice i get is try a different oil - a full synthetic 75W-90 like Guklf Western "waterclear" or Castrol "Synrtax" might help fix the problem.
In fact my friend who has an St185 is VERY happy with the improvments in shift from 1st--->2nd gear when he changed to the Gulf western waterclear full sythetic gearbox oil.
Toobs
Re: 4AGZE GEARBOX SHIFTING PROBS Wed, 24 November 2004 05:11 Go to previous messageGo to next message
The problems are caused by the synchro's which inevitably wear out in almost all gearboxes.
Also quite often people don't ever change their gearbox oil, however, it should be changed approx every 20,000kms in most cars according to factory service intervals.... yes I know its expensive stuff but it is cheaper than a gearbox or diff rebuild.
GUN METAL 87 SC
SYDNEY
Dood,
Thanks for the quick reply !
I have some Syntrax allready on order so keen too see how it goes.
What have you heard about the 2nd gear syncros on these 4 AGZE boxes.
My naturally aspirated 4AGE MR-2 box is fine after much racing ( it is also running Syntrax.
It only has about 1/2 the power to deal with however compared to the supercharged engine!!!
Regards,
Scott
Toobs
Re: 4AGZE GEARBOX SHIFTING PROBS Wed, 24 November 2004 05:19 Go to previous messageGo to next message
The E series boxes which are used in the GT4's, GZE's etc. are known for chewing through synchro's.
Also when you've got a heavy arsed rig like a gt4 and a high reving engine you are more likely to keep the rev's up which causes more wear on the synchro's.
GUN METAL 87 SC
SYDNEY
Re: 4AGZE GEARBOX SHIFTING PROBS Thu, 25 November 2004 05:06 Go to previous messageGo to next message
Appreciate the info !
Do you have any contacts on who can put some new syncros in it for me in Sydney, if the new oil does not help.
Preferebly someone who may have worked on these boxes before ?
Also do you know how different thede boxes are compared to the NA 4 AGE box ?
Thanks,
Scott
Toobs
Re: 4AGZE GEARBOX SHIFTING PROBS Thu, 25 November 2004 05:44 Go to previous messageGo to next message
Never actually got one rebuilt myself... I have all the manuals for it but haven't found the need as yet.
Do a yellowpages.com.au search for gear box and you should get a few listings.
e.g.:
C & J Transmissions Pty Ltd
Specialists In Repairs & Changeovers To Suit All Cars & 4WDs
13 Clarke St Guildford NSW 2161
ph: (02) 9632 9810
Gear Box Factory
Repairers & Manufacturers Of Manual Gearboxes & Parts. Est Over 30 Yrs
80- 82 Rosedale Ave Greenacre NSW 2190
ph: (02) 9790 2342
A Allgear Transmission Service
56 Rosedale Ave Greenacre NSW 2190
ph: (02) 9790 0155
Hornsby Differential & Gearbox Specialists
2/ 11 Leighton Pl Hornsby NSW 2077
ph: (02) 9477 6396
A1 Leichhardt Automotive Specialists Pty Ltd
689 Parramatta Rd (Cnr Tebbutt St) Leichhardt NSW 2040
ph: (02) 9569 9964
Note: I have never used any of these companies so do some shopping around and get yourself a good deal... usually you can tell if they know their stuff because of the number and types of cars in their carpark.
Re: 4AGZE GEARBOX SHIFTING PROBS Thu, 25 November 2004 09:57 Go to previous messageGo to next message
boxes are VERY VERY VERY VERY different to a 4age C series box. Its like comparing a T50 and a W58!!
C52s weigh about 20kg... E58's weigh more like 50kg!!
GUN METAL 87 SC
SYDNEY
Re: 4AGZE GEARBOX SHIFTING PROBS Thu, 25 November 2004 22:02 Go to previous message
Thanks for the info, much appreciated.
Scott
Previous Topic:lexcen v8 2wd hilux
Next Topic:My AE82 hatch keeps stalling
Current Time: Fri Nov 20 10:24:38 UTC 2026
Total time taken to generate the page: 0.0191330909729 seconds
